Oil Filter Adapter
I've been looking at the plate for about an hour now, trying to figure out whether I like the whole relocation idea. I think I need to look at my E24 a bit more and figure out if the Trans-Dapt kit is the way to go. I could always modify the plates to accept a spin on filter but then it loses its effectiveness when it comes to running a cooler. The only thing I can think of is making a simplified version for those who never wanted a cooler to begin with and just need a place for senders and sensors. The remote filter idea would make oil changes easier and at the same time, provide a good system to add a cooler to. You could run the cooler after filtration and keep the pressure up. Just thinking aloud here.
Re: Sandwich plate adapter
Thanks for the encouragement. I agree on the cost. Once you add the time up, you laugh at your "profit". I'd still much rather do this than bore out throttle bodies, less flaming and more CNC fun :-)paul burke wrote:
Keep carving , I am anxious to see what you come up with.
I am making a complete replacement billet filter unit and it is a cumbersome task. Yours may be more sell able, as mine starts out with a 4x4x4 chunk of 6061 and will probably cost more than people will want to spend.
Paul
finished product
So, here's the final product. I put the senders in to give an idea of what the extra ports can be used for. In this case its oil temp and oil pressure. Hoses are 30in long and at this point, mounting location looks to be on the drivers wheel well. I would envision the coolant expansion tank bracket as a good place.
Everything you see in the pic will run you $195. Take away the senders and the price comes down to $155. I will include the hardware needed to finish the job. You can use the stock bolt to put it in place but it sticks out a bit. I made a mistake in ordering the replacement bolts and actually got longer ones instead of shorter ones. That however gave me another idea to make these work on the B35 motors as well.
Stock is fine
Big Bronze Rim,
Thanks for the kind words. I'm not looking to get rich off of these, just covering my expenses and time.
The stock one works just fine. I prefer spin on filters because they facilitate easier oil changes. This also adds the option for an oil cooler as well as the two ports which could run senders or feed lines for the guys out there who have turbos. I can throw in a small oil cooler into the deal if anyone wants one. I'll dig them up and snap some pics. Right now I can offer a complete system minus a couple of feet of hose and some fittings for under $200. Get yourself some senders and gauges and you can have gauges, a remote filter, and an oil cooler for under $300.
I was just about to mention the thermostat bit but Jeremy beat me to it. The oil filter used comes from Ford V8 engines. The most common one is the PH8A from Fram. The one I would recommend using is the Mobil M1-301. You can get them on Fleabay (item #330285359214 at $7 a piece with a minimum order of 6). Its where I get mine from and its half the price versus getting one from Advance Auto for $13. Most of the better filters are made by Champion Labs. This kit will not work on B35 engines, at least not yet. I can make a block off plate with just the fittings, similar to the kit Bruno used to sell on BMWe34.net. I entertained the idea of making this fit a B35 canister as well, I'll see where it goes but the other kit would be at least $15 cheaper.
Just occured to me: is there any issue with mounting on a oil cooler vs non-oil cooler equipped car? One bolts in from the top, the other bolts in from the bottom as I remember. Is it as simple as using a nut/bolt for non-cooler equipped cars and a proper length bolt for oil cooler filter heads?
You got it.
Yup, simple as that. I provide the copper washers and locknut. I can tell you that when the adapter is mounted, it adds 1.150 inches to the thickness from the lip of the mount. I suppose you coule always fit it and mark the original bolt to see what length you need.
Three kits ready to roll
I have three basic kits ready to go at $155. For these first three, I'll drill out the two extra ports any way you want them. I also have two sets of VDO pressure and temp sensors (NEW) for an extra $40 (below my cost). I can install these and give you a head start with gauges. I was also told by my powder coater that he'd be willing to coat them at $22.50 a piece, which is a pretty good deal compared to what he charges me for throttle bodies. I will make more if there is a demand for them, otherwise they'll become another demo part for visitors to stare at when they come through the shop :-)
out of curiosty and part dumb Q, which of the two oil port's comes directly from the oil pump.paul burke wrote:
Have been making these for a while, this is the one on Ken H's motor. I am going to make a billet spin on filter adapter that bolts in the stock location. It will have in/out ports and provisions for turbo oil, sending units etc. Will post pictures soon.
Paul
top or bottem??need to locate the turbo oil feed.
cheers marty
Re: Stock is fine
From my previous post.
I'll throw some pictures up over the weekend, time permitting.
filter
I should have read further. I'm guessing this won't work with the 745 setup, correct?
Re: filter
I have a 745 mount and cooler, I will check to make sure. I don't see why it wouldn't as most of the canisters from the early M30's had the same dimensions.Bill in MN wrote:I should have read further. I'm guessing this won't work with the 745 setup, correct?
B34/B35 adapter plates
I just finished up run of adapter plates similar to Bruno's design. A bit thinker (1.25in) makes it possible to add a feed line or senders. Pics up tomorrow for anyone still interested.
Remote Oil Filter adapter
Jordanmilos
Are you still making the oil filter adapter plates that replace the canister and provide fittings for an Oil Cooler and Remote Filter?
The link to the finished items picture on page two no longer works, do you by any chance have a picture of the finished part that I can check out?
Thanks in advance
Thanks in advance
Re: Remote Oil Filter adapter
Did you notice you're replying to a thread which is 3-1/2 years old?rwpg wrote:Jordanmilos
Thanks in advance
