I bought a new rallycross car. A 1996 BMW 318ti.
After about 6 months of searching, I found one with no sunroof, no traction control, a reasonable interior, and working AC. The only thing it is missing is an LSD. This is not normally an issue for BMWs but this car has an E30-ish rear suspension that doesn't fit standard E30 diffs or E36 diffs. It does have a hatch and fits eight tires in the rear
I was planning on running the car in stock class. It is one of the few cars with fully independent suspension, an OEM LSD, gearing that works for rallycross (55mph 2nd gear), and enough head room for me. The only problem was this car came with sport seats which take up some headroom. They are attached to trim packages in a way that I can't swap them out and stay in stock class. I emailed the rallycross board and couldn't get an answer about how much foam I could cut out of the seats.
While reading up on the rules, I learned you don't need to run headlights in stock class. You just need a strand of Christmas lights that can be seen from the front of the car. I don't even think they need to be attached to power. I don't think I will take advantage of that while I am driving
to events.
On to plan B. This car isn't as ideal for prepared class but it should work ok. The class allows tunes that change boost so turbo cars or very light cars are the ones to have. 2700lbs and 145hp aren't quite right. Here is what I have done to the car so far.
- water pump, thermostat, radiator hoses, coolant
- engine and transmission mounts
- lower control arms with offset bushings for more caster
- lightweight single mass flywheel and M3 clutch
- x-brace with a skid plate attached
- Corbeau A4 from the 5 series
The guy that runs bimmerbum.com lives in Central Florida and he was a massive help finding parts for the car. He specializes in the semi-trailing arm E36s. If anyone has a ti or a Z3 that needs work, I recommend talking to him.
I got one of the older symmetrical X-braces and it works pretty well for a skid plate. At some point, I need to add a bit more metal to the front because dirt is getting stuck between the skid plate and oil pan.
The first event in the new car was at The FIRM. They ran their standard course that used the skid pad and part of the kart track. I did about 25 runs which helped a great deal in getting used to the car. The course degraded a lot by the time I got a video so I slowed way down for the rutted sections
https://www.youtube.com/watch?v=2W8UVQnvTqc
They also had a
water splash. I put together a quick video of
pendulum turns while I was figuring out the car.
I managed to catch half of the SCCA rallycross in June. I work as a musician on the weekends and had to leave early for a gig. I wasn't very happy with my driving. I am having trouble adjusting from the E28 where I had to stand the car on it's nose to make it turn. The 318 is much more balanced and the fast way around a corner seems to be a small four wheel drift.
https://www.youtube.com/watch?v=cRMxPGZO3L0
A few weeks later, my wife and I left for the Rallycross East National Challenge. We stopped for a day and a half in Asheville, NC. We drove through the mountains including NC 226A and the Blue Ridge Parkway. My favorite bit was a small gravel road around Lake Tahoma. In Asheville, we enjoyed the Biscuithead cafe, Hole Donuts, the Chocolate Lounge, and Burial Brewery. We have a bit of a sweet tooth. The next day we drove across Virginia to the Rally Farm.
The competition didn't go well for me. I started off slow with cone problems and ended up reasonably fast with cone problems. There were glimpses of speed though. I think the car will be competitive once I figure it out.
https://www.youtube.com/watch?v=ZlxiE_o5z0E
I somehow got 5 cones on this run. Even with the near spin it was my fastest run on the third course.
https://www.youtube.com/watch?v=qnPHW1FdKmY
During the event, I found that my rally tires rubbed on the top of the fender liner under full compression. For now, that is fixed with some rubber spring spacers. I am riding on the bump stops on some of the faster turns.
At some point, I am going to replace at least springs with something a little more stiff. That way, I can get off the bumpstops and maybe disconnect swaybars. The other weakness of the car is the open diff. I haven't figured a reasonable cost way to get a diff and stay in prepared. Otherwise, the car feels great.
