Is the avatar picture size really supposed to be 20kb? That sounds absolutely tiny. I tried resizing my last pic to get under that limit and I had to make it like 20 pixels high. WTH?
20 kb is plenty for 100x100 pixel image. A lot of the avatars are under 5 kb. Use MS Paint and resize to 100x100 pixels or smaller. Make sure to save the file as a jpg. That should put you at around 15 kb, tops.
Jeremy wrote:20 kb is plenty for 100x100 pixel image. A lot of the avatars are under 5 kb. Use MS Paint and resize to 100x100 pixels or smaller. Make sure to save the file as a jpg. That should put you at around 15 kb, tops.
Agreed, Jeremy is right.
I'm surprised at how small files can get after I run them through an image program like gimp or Snagit which we use here at work. I can usually get them down to 100-200k easy, and those are decent size like 640x480.
Yeah im still having problems even with "paint". I reduced down to 100X66 pixels and still 61.4 kb. I guess its such a badass car that even a pic must by a proper size. haha.
