Dieselboost's 524Compound Biturbodiesel
My new 12mm 12.9 studs
I found some ventilation holes in bottom...
The exhaust
actually that silencer is dummy... with 3" straight pipe
- Beamter
Actually these does not have anything to do with bmw's but...
Some people may like these...
So... This is exhaustmanifold for my 1700cc lada engine
Turbo is custom made racing hybrid turbo charger
(Holset H1C/H1E) turbine chamber is ported to larger scale but still smalle that in Holset H1D Made by Timo Lehtimäki
Sweet project man. I did something similar with a sequential turbo homeade jet engine. One thing I did different though is I had my small turbo forcing air into the big one instead of relying on vacuum, then an actuator opened once the big guy was boosting. I changed to this because I was getting a pressure lull when the big turbo was kicking in, because its still pushing air through the small one as well as to the motor. I don't have any pictures but if you're interest at all I can draw up a quick diagram of how mine went.
Gosh! i almost forgot those diy jet enginesaudioscience10 wrote:Sweet project man. I did something similar with a sequential turbo homeade jet engine. One thing I did different though is I had my small turbo forcing air into the big one instead of relying on vacuum, then an actuator opened once the big guy was boosting. I changed to this because I was getting a pressure lull when the big turbo was kicking in, because its still pushing air through the small one as well as to the motor. I don't have any pictures but if you're interest at all I can draw up a quick diagram of how mine went.
we had parts for one.... size was huge
Holset 4LEK with combustion chamber made from 6kg fire extinguisher with afterburner made from 12kg fire extinguisher!!!!
