PEDAL BRACKET Reinforcement / repair - REV. 6-welded tab
order placed
order placed via paypal
post subject
THE BEND IS INTENTIONAL, ITS HOW IT FITS AROUND THE PEDAL SUPPORT BRACKET, IT ONLY TOOK ME A FEW HOURS TOO FIGURE OUT HOW TO BEND IT SO IT FITS FLUSH AROUND THE CURVE, THE REV 3 HAD A PREFORMED SS TAB, REV 4 HAS A REFORMED WELDED TAB, EVERY BRACKET IS PREFIT BEFORE SHIPPING, THANKS DAVE
post subject
bump, have a few rev 4 brackets left, dave
post subject
PICKING UP 60 PARTS WEDNESDAY, CAN SHIP ASAP, DAVE
Re: post subject
What? No Rev 5?DAVID PEPIN wrote:PICKING UP 60 PARTS WEDNESDAY, CAN SHIP ASAP, DAVE
Thanks for mine David- I got it a few days ago.
Got my parts FAST from David...and I'm so glad I did.
I started developing a slooooow clutch master leak that I would guess equaled around two drops per week. Bought this kit on a whim thinking it would be good preventative maintenance if nothing else.
When I got in to install it; I had a moment of fear that David perhaps sent the wrong piece as what I had absolutely wasn't going to fit. I quickly found that wasn't the case; rather someone had attempted a far cruder reinforcement technique before my ownership and that piece would need to be removed before I could install the new. The old piece wasn't attached on the firewall side, only the master cylinder and a number of washers were used as spacers. Not at all well thought-out. You can check out the flat, thick, HEAVY piece below:
With that out of the way I found I had a nice big crack. With darkness setting in, I moved ahead and got Dave's part on. Fit like a glove and has made a very big difference in clutch feel. I'm hoping this will take care of the master cylinder leak as things are certainly more aligned for success now.
Thanks again Dave! Great product.
I had some clutch issues and decided to change the Master and Slave cylinders and as it turns out, my pedal bracket is indeed cracked. Ordered and received my pedal bracket reinforcement from David which saved me from having to swap out the bracket.
It's a solid piece of metal and I expect that it will save me from having to revisit this tight working space again. I did indeed lose one nut behind the carpet, so the extra one came in handy. The nut next to the firewall really needs to get started using a magnet to hold it as it's difficult to get it started by hand or on the end of a socket because you have to place it precisely in a tight area by feel. Also, aligning everything is much easier with the bolts going in from the bracket side per the instructions. A good product!
post subject
BUMP, CAN SHIP ASAP, DAVE
post subject
BUMP, install one for a smoother clutch ///
