403 Forbidden
403 Forbidden
Record #:108161
Running:0.4.10a3 / 75c
Time: Tue, 03 Dec 2013 14:53:58 -0500
Host:54-240-196-186.amazon.com
IP: 54.240.196.186
Post:
Query: redirect=search.php&search_id=newposts
Stripped Query: redirect=search.php&search_id=newposts
Referer:
User Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/31.0.1650.57 Safari/537.36
Reconstructed URL: http:// www.mye28.com /login.php?redirect=search.php&search_id=newposts
Why Blocked: No registrations, or logins, from hosts listed as hostile on Stop Forum Spam (http://www.stopforumspam.com/removal) (local block).
---End of preamble, begin YOUR added comments below here---
I’m trying to access from the Amazon corporate network…
Try it with just the plain www.mye28.com without the additional queries.
It's working now, so if you did something, thanks. If you didn't then thanks too.
I can't do squat to the server side stuff, only Justin and Jeremy can do that. It might have just choked on the combination of query elements that were lumped together.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
That message tells what is going on, i.e. "Why Blocked". The particular IP address you were browsing from is flagged in the Stop Forum Spam database. It only worked later because your IP changed. I'm guessing you are behind a proxy server and a small pool of IPs thus serve a large group of users. Visit the URL to get the IP unblocked by SFS.
More than likely it wasn't a spammer at all, but in general SFS is good. Although anything AWS is totally blocked here by ZB Block, those IP ranges are full of nasty stuff.
