Front section of headliner / overhead panel
e28Sean
Post by e28Sean »
Before i do something stupid and headache inducing, i gotta ask... is the forward section of the overhead removable, independent of the rest of the headliner, and without having to remove Big Things, such as the sunroof assembly, etc... ?
I am referring to this part, the black part w/ the check panel, sunroof controls, and sun visors:
I ask because the vinyl (?) on mine has started to fall off, and i'd like to re-glue it before it gets worse.
freetoride
Post by freetoride »
Yes, it comes down without much difficulty.
e28Sean
Post by e28Sean »
::heads back outside::
e28Sean
Post by e28Sean »
freetoride, you rock!
That was actually quite easy, once i stopped overthinking it.
e28Sean
Post by e28Sean »
I very briefly toyed with the idea of peeling it & recovering it with the same material i used on the door panels. Having it off and having the lighter colored headlining going all the way forwards made the interior feel more open and airy.
That said... for now, i'm just going to re-glue the factory black vinyl-like-material.
freetoride
I wish it were always that easy to help someone!
e28Sean
Post by e28Sean »
Remember above, where I mentioned the temptation to use the same material i used on the doors?
Wellll...
:cool:
Waiting for the upholstery adhesive to set up in a nice worm closet to finish it off. ...
lilpoindexter
Post by lilpoindexter »
I'm glad you did the wrap. Looks much better than boring black.
e28Sean
Post by e28Sean »
I still have a bit of trimming and gluing to do, but, it should be back in the car by tomorrow afternoon.
I'll continue to post pics as I go.
e28Sean
Post by e28Sean »
For anyone still following this:
The panel, nearly done:
The wrinkles have all been smoothed out, and it's in a climate controlled space setting up right now.
The sunroof motor cover thinger:
e28Sean
Post by e28Sean »
Final update:
Mab1957
Post by Mab1957 »
:up:
