M30 turbo manifolds GROUP BUY ENDED
Thanks everyone, if you have any questions or issues please let me know. You can email me at Panayiotisx2@gmail.com
No mock up yet - probably won't get there for a bit myself. Need to get the cooling system straightened out, then the megasquirt conversion done.
Until then, starting to plan out parts. Going to go with a gt3582r 1.06. Seems like a good option for ~400hp.
Can someone confirm what set of options for this turbo would be appropriate for this manifold? For example, looking on atpturbo.com:
http://www.atpturbo.com/mm5/merchant.mv ... RT-TBO-006
Options:
1) Turbine Housing A/R: 1.06
2) Please Specify Turbine Housing Style: Undivided T4 flanged turbine inlet with 3" V-band
Thoughts? Other options? "3" V-Band ADD-ON for GT 4 Bolt 3" Selection"? Is this for the compressor/intake side?
Other vendors for this turbo? Want to buy new.
Aaron
Options:
Aaron
Re: M30 turbo manifolds GROUP BUY ENDED
I just finished my build with my manifold from this group buy, will start a thread outlining my build but here are a couple pictures. Waiting to figure out maf issues and will then throw her on the dyno for a tune.
Sweet! What turbo did you end up using?
I went with a comp 61mm from TCD. For the price I couldn't beat it and it should meet my goals of about 400whp.
Thanks for posting install pics. Looks great...!!!!
looking good. makes me want to jump the gun and start bolting mine together
Anyone making power on one of these yet? Mines still on the shelf waiting
butt dyno feels like it added about 10HP to my setup.
i wonder what'll happen when i move it from the trunk to the engine.
Mine will be running here in the next couple of days as well! I'll post a pic once it's done. Shooting for ~500whp once my engine is broken in..... We shall see how it goes
Hey tcturbo, where did you route your wastegate exhaust? Recirc or open? I wanted mine open, but couldn't find a location for the exhaust out of it (frame rail way too close to go next to engine)..... So i ended up pointing the wastegate toward the fender well and ran my exhaust through there down next to my strut and front wheel haha
Im digging this one out
Did anyone finally used this turbo manifolds? Im looking for some pictures in E28 and mostly E24 shell just to prepare few bits for my project.
Any help? Anyone....?
