Own Threads?
Own Threads?
There has been a convenient search feature that let you search for your past created threads with a single link.
Is this still possible to enable? I found it very convenient, and also like searching other user's created threads if possible...
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Re: Own Threads?
Post by Justin_FL »
Nope, never coming back...
Just joking, it will come back I think, should be able to code it for this version with some research.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Re: Own Threads?
Post by Justin_FL »
Use this link for now:
http://www.mye28.com/search.php?search_ ... =firstpost
I will add it to the interface sooner or later.
Re: Own Threads?
Thanks! Convenient feature, but only if it doesn't take too much time to implement :)
I am getting used to this new format now, as it was a bit of a change at first...
Re: Own Threads?
IIRC, this was mentioned by me initially a few years back. Quite handy!
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Re: Own Threads?
Post by Justin_FL »
Now the link is in the UI:
Re: Own Threads?
Woot!
Re: Own Threads?
Thanks for adding this functionality!
Re: Own Threads?
Ditto, thank you!
