Over the weekend, drove it and took a couple of pics of das biest.
EricF wrote:Drove my first one home today. It has begun
You made it all the way?
Congrats and welcome.
Amazingly yes. Dropped some coolant when I parked it though... Came from a hose clamp at the t-stat housing which looked like a new clamp and housing gasket is new. Guessing since the car was off the road it just didn't heat cycle enough to show that clamp needed an extra 1/4 turn.
The fun begins
The fun begins
NIce seats 'Nutz!carnutdallas wrote:Last Thursday the Boys from Nebraska blew through town on their way to Texfest and dropped off some goodies. My new to me e30 Manual Sport seats in glorious leather from Mike H. out of his Zinno car turning tracker. Thank you for the door to door delivery. I hope you enjoyed our state and the rest of the trip. Your wife and daughter are troopers! Here is a pic or two. Will do full cover spread next year when Turbo goes in, in the Spring. Todd at TCD his helping secure the goodies now. -R
Thanks! ...and it drives better now
I wish it had driven farther.carnutdallas wrote:Thanks! ...and it drives better now
Drove her to the shop. Having camber plates installed. AND am beginning the Euro Bumper transformation
Picked my first e28 this weekend!
Sat in it and smelled the new leather.....ahhhh. Also ordered a new Head unit. I have Kenwoods in all of my other non-stock applications. Makes jumping from car to car easier. I have never liked the JVC in this car. the Kenwood I like is. BT 752HD. Got a refurb on eBay for $79 plus shipping.
Today I tried to replace my t-stat, amongst other related stuff, but had to call it off after snapping 3 bolt heads
I ended up using a heavy hammer and chisel to get the cover out:
I also found this cold war relic inside (it actually works well )
Drove it.
As to where... ... ...
Removed and replaced the old ignition cylinder which had a key broken off inside. Was a PITA, turning the key to the second position and inserting a paperclip didn't do anything to release the old cylinder as it was supposed to. I ended up drilling a small hole through the ignition housing to exactly where the release button was and it magically released. Everything buttoned up and now I don't have to start the car with the ghetto screw driver technique.
Did a little more good faith updates before Buzzbomb goes to it's new home. Aardvark makes these straps for anyone needing to do the same. They also have the securing clips but if you're handy you can just get some steel rod and make your own.
Just took an hour of eyeballing, bending and cutting. I'll miss the ole gal, but we went as far as we could go together and I have another something special in the werks.
It's too bad there doesn't seem to be a source for the proper Recaro webbing for the later seats.
I put another regulator and accumulator on Blucifer this morning. Now I can do panic stops! That has been my only issue in 4000 miles of shake down. Should be ready for winter now.
New guibo and new dogbones (Pitman arams/links). Didn't get to test the handling with the new dogbones as wife was in the car during test drive...
Not sure which one, but bought and brought this to ///M-Haus today.
^^^ Hmmmm... Flat six... Low CG... Hmmmm... ^^^
Arranged to sell one of mine today. It's official name is now "Boomerang."
Said goodbye to one of them today; Frank drove the 535is back home.
Back to the original owner huh? Good to hear you were able to find a home for it.
Pulled an M20...
If at first, you don't succeed... https://www.youtube.com/watch?v=nr_C3pb ... PvgNxSEFDg
... Try again (jack up off motor mounts). https://www.youtube.com/watch?v=o1WTPaE ... Dg&index=2
Installed my Airtex intank and Bosch inline pumps. Now my beater 528e with working AC is back. In September we had a spat of 100F+ days that I think took out my main pump...it still pumped, but the car ran like shit...low pressure. I think it sucked air. I had forgotten how solid and underpowered my e28 feels...like stepping back in time....waaaaaay back.
My first, the '85 eta, went bye bye. http://youtu.be/X0k9kygRkDE28
I'm using the last super e as a tool box, but I put a dozen miles on it and pumped up the skins I have on front, whilst I wait to get it aligned after replacing the right tie rods. The resonator is leaking too.
Drove it out to East County to visit my Dad, decided it wasn't loud enough, came home and put the B&B exhaust back on. It's finally cooling down enough where I hope to get a lot more stuff done on the whole fleet.
Duplicate post again. Sorry
Do you have any sound clips with the B&B exhaust. I'd love to hear it!Karl Grau wrote:Drove it out to East County to visit my Dad, decided it wasn't loud enough, came home and put the B&B exhaust back on. It's finally cooling down enough where I hope to get a lot more stuff done on the whole fleet.
