My bad idea build thread.
So, ive been lurking for a while learning everything i can about m30's thanks to you guys.
Ive built turbo hondas, owned turbo subarus so wrenching is nothing new to me.
So much so that i have begun an oddball swap involving one. A M30b34 to be exact.
Quick break down.
I own a 1978 chevy nova/omega equipped with a horrible small block chevy.
I purchased an 87' 535i ex rally car with 5spd trans. (Floors were rotted so dont yell at me for what ive done to it)
After driving in a friends turbo e32 i fell in love with the m30. So I decided the m30b34 would and should fit in my nova.
So i have a motor. A rather large turbo, megasquirt ecu and wasted spark planned m30 in a classic chevy.
Pics
The nova
The e28
Quick break down.
Pics
The nova
The e28
Re: My bad idea build thread.
Motor and trans are now in thier final resting spot.
Manifolds flipped for fabbing a mule manifold to get me througj the summer. Next winter i plan to build a full tubular.
E28 rad was the perfect width and thickness.
Now hiding a larger intercooler behind the factory grille. 4 inch core.
Hardly noticable.
Gm 3 coil wasted spark thanks to an e28 writeup.
Hopefully where i will mount the snail.
Thats all ive got so far. Any ideas or tips, lets hear em!
Hardly noticable.
I don't know what to say about this....
I doubt it will spin the tires at all!
Badass!!!!!
Shouldn't the engine be mounted much farther rearward though? You could use an engine driven can that way.
Jboye. I think your right lol
Kyle, the motor is where it is because i am firmly against cutting any crossmembers. The car will be driveable with the position easily, just need the custom driveshaft made longer.
The trans fits perfect. The m30 is much longer than the chevy motor was.
That's awesome, I'm sure that will confuse some Chevy guys.
Unique, thats for sure!!! How much does the nova weigh??
With the bmw motor, 2750lbs. Best guess.
Started at 3100lbs. Bmw motor and trans is 200lbs lighter than the old iron block and turbo 300 trans.
Then heater core delete and other luxury items scratched.
2700-2800lbs is my best guess.
Love it!!!
Any updates?
Any updates?
Wow, creative and I love it. And at that weight it ought to scream even in N/A form let alone with a snail attached.
Neato! Looking forward to seeing it completed!
Nice to see someone stuffing a turbo M30 in a GM rather than the other way around.
So where's the bad idea?
Have you thought about using a b35 pan. Maybe it could have you more room to back it in more.
If you scroll up you will see that i have swapped to a b35 pan and oil pick up tube already.
The only way to set it back would be cutting the subframe. Which i am firmly against. This motor can literally be unbolted and i can bolt another small block in, or go LS later down the road.
Been making very slow progesss. Between a really cold snap of weather and the low canadian dollar, ive been holding off on ordering more parts.
Going to hopefully start fabbing the exhaust mani with a spare head we have laying around.
Double post
This is fantastic.
cek Likes this.
Subscribed. Don't get me wrong the S5x swaps are really cool, but this one's gonna be really unique to watch!
You're nuts like us. Cool.
I pulled these coils off a supercharged 3800 series v6 buick.
Junkyard special. Msd coils will happen if and when these fail.
I have. But the GM coil is only 3 or 4 wires once you strip out all of the extra mess in it.
Plus it was free... Lol
Did the exhaust manifolds still fit nicely flipped upside down or was there further modifications to that?
Manifolds actually fit fine flipped. Ill get some pics once i start fabbing it up some more.
My only clearance issue is the height of the motor. Ill probably have to cowl the hood 2-3 inches to clear the intake manifold/throttle body.
Subscribed! This is gonna be sweet!
Im still alive guys. With the warm weather approaching i will finally be able to start making some more progress on the car.
Just a dumb question or 2. In the states that would be an Olds Omega. In the mid 70s you could get a 4 door with a 350 SBC. I Would a V*acht ( sic) fit better ? Do the Novas have a front sub frame that was bolted to the firewall? Like the Chevelles or the E 28? Or a E 34?
The front sub frame is actually identical to the 2nd gen f body cars. (Camaro, Firebird and trans am)
The rear subframe is taken from the 1st gen F body platform.
So yes, front crossmembered chasis.
Moar!!!!!
Soon i promise. Cant find any time away from work and husbandly duties to get any work done. Sooooooon.
Anyone else other then whatisthat had this dream of a project?
But I would do it in a more classic car like a old el camino or classic mustang, then just show up to some muscle car meet up.
See what those die hard domestic guys think.
turbo honda k engine in a 69 camero or something.
I already get "spit at" by chevy purists lol.
My Generation of nova is actually gaining popularity quickly up here. Ive pissed off quite a few old dudes who walk by the house while im working.
GOOD. Fuck those guys.Whatisthat wrote:I already get "spit at" by chevy purists lol.
Alright. Finally some progress. Jboye32 and i got to work on the manifold.
http://i.imgur.com/M9W6Jkx.jpg
http://i.imgur.com/tj9sekO.jpg
http://i.imgur.com/rSEMxZE.jpg
http://i.imgur.com/hfJBmtk.jpg
98% of the welding done by jboye32. 98% of the bitch work done my me lol.
All of that resulted in the first ever "1974-79 chevy nova M30 turbo manifold".
Needs some finish welding, grinding and we will figure out the wastegate location.
Then paint and heat wrap.
This thread just got interesting...
