Recommended E28 instrument cluster repair shop suggestion...
Cluster in my M5 needs a rebuild. Who have you fine folks used for repair and rebuild?
AB
AB
Re: Recommended E28 instrument cluster repair shop suggestio
After seeing the attitude from the bavrest guy in the S14 Facebook group, I wouldn't do business with them.
There is a spot in Redondo Beach 'CA called Pauls speedometer. He isn't cheap but he is the best, been doing it for 40 years and on a side note he shared his lot with an independent BMW shop so he knows them.
Jeff from Odometer Gears rebuilt one for me at The Vintage. I do not believe they do that on the regular though. On his website he has a list of repair shops. There is one in Portland as well as many others on the west coast. Can anyone vouch for Portland Speedometer Inc?
Yeah, had a similar experience with that guy years ago. Not a pleasant fella to deal with.wkohler wrote:After seeing the attitude from the bavrest guy in the S14 Facebook group, I wouldn't do business with them.
I called a few times and left two messages - nobody called back. Not much I can do with that, unfortunately :/Bonsaibacker wrote:Jeff from Odometer Gears rebuilt one for me at The Vintage. I do not believe they do that on the regular though. On his website he has a list of repair shops. There is one in Portland as well as many others on the west coast. Can anyone vouch for Portland Speedometer Inc?
Awesome, thanks for the suggestion.Cgailbmr87 wrote:There is a spot in Redondo Beach 'CA called Pauls speedometer. He isn't cheap but he is the best, been doing it for 40 years and on a side note he shared his lot with an independent BMW shop so he knows them.
Unfortunately bimmeronly doesn't work on cars older than the 1995 7 series. I got bad vibes via email After asking for a quote from bavrest. YMMV, but I'd rather send my money elsewhereJohn in VA wrote:Check with http://bavrest.com/instrument-clusters.html or https://www.bimmeronly.com/.
Have had speedometer work done by Hollywood speedometer
I believe related to Palo Alto Speedometer
Was pleased with results
Saw a FB post today on the E30 page. They recommend e30_dad - email bimmerhead1@gmail.com. Maybe he works with E28 clusters, too.
Ivo Christov (user ovide)is the man. He's in the Netherlands, so shipping might add to the cost of a rebuild, and the turnaround time, but might not hurt to check.
https://www.e28.nl/en/tellerbak-reparatie/
Have you thought about doing it yourself? I did mine and it was pretty easy. Bought replacement gears from someone on here, i believe it was odometer gears
Re: Recommended E28 instrument cluster repair shop suggestion...
@dabimz, where did you get your gears from and what year is your e28?
Jeff at Odometergears.com has great products:Phil DM wrote: Aug 06, 2023 5:16 PM@dabimz, where did you get your gears from and what year is your e28?
https://www.odometergears.com/products/ ... 8+82-88/27
https://www.odometergears.com/howto/BMW ... cement.pdf
