ISO: Photos of Supersprint setup on a M30B35-swapped E28
Foonfer
Post by Foonfer »
I'm opening a request for photos of the underside of your M30 car with a full Supersprint exhaust setup:
header (Supersprint #781401)
"front exhaust" (SS #781582) --- is this the "resonator" --?--
"centre exhaust" (SS#781523) --- or is this one the "resonator" --?--
rear muffler (SS #781626)
If you can show or point to your location of O2 sensor(s), even better.
If you have the Supersprint cat (SS #781532), or any other catalytic converter, that's of course OK too.
Thanks in advance! -F
uzayas
Re: ISO: Photos of Supersprint setup on a M30B35-swapped E28
Post by uzayas »
It`s not the same exact combination you want, but I hope it gives an idea
Foonfer
Post by Foonfer »
Thanks uzayas, that setup looks very very clean and well done. As you say it's not exactly what I asked for, but close. At least you have the SS#781523 part, the one Supersprint calls the "centre exhaust".
That figure next to the gearbox, is that an "X-pipe"? How do you like the whole thing, does it flow well? Also, the wrapping of the headers with that insulation, wow.
uzayas
Post by uzayas »
There are no issues with the exhaust flow.
However, I still hear a bit of bass, especially at idle speed, but overall, I’m satisfied.
I'm not sure if we can share links via Instagram, but in the attached link, you'll find three videos:
one of a cold start, one at idle, and one with a bit of throttle so you can listen to the exhaust sound.
https://www.instagram.com/p/DCrO7AUtGRJ ... BiNWFlZA==
Foonfer
Post by Foonfer »
Thanks uzayas, I saw the videos. What I like about the sound is how smooth it is. No popping, no pauses, just fluid. That is exactly what I need to achieve with mine.
