I spilled a little redline this morning on the exhaust. Needless to say its pretty smokey as it burns off. Is it best to just let it burn off (like oil), or should I use a degreaser like simple green (which will probably cause more smoke) to get off the redline?
Rich
Red line spill question
[QUOTE="Rich in Savannah"]I spilled a little redline this morning on the exhaust. Needless to say its pretty smokey as it burns off. Is it best to just let it burn off (like oil), or should I use a degreaser like simple green (which will probably cause more smoke) to get off the redline?
Rich[/QUOTE]
Most of the constituents of synthetic oils, including Redline, have been used as additives, as detergents and viscosity stabilizers, in mineral oil for decades, so you've spilled these materials back when you were using mineral oil. Clean up is the same as mineral oil.
Rich[/QUOTE]
Ok.. since I have never used mineral oil.. that method would be ???
You haven't used mineral oil? All motor oils prior to synthetics were mineral oils, and those are still being manufactured today. Perhaps you simply aren't familiar with the term. Mineral oil comes out of a hole in the ground, hence mineral oil. Synthetics are created by various manufacturing processes, but they're not a product of the refining process, hence they're synthetic oils.Ok.. since I have never used mineral oil.. that method would be ???
So, my guess is that you have used mineral oil unless you've used synthetics exclusively in your cars from the day you first acquired a car.
[Edit by fastpat on [TIME]1108257166[/TIME]]
