Road trip time -- what should I check before rollin' out?
Here comes spring break! 1 week away!
We got me and my girlfriend http://www.partyapp.com/photos/fullsize/124605.jpg
Our friend erin http://www.geocities.com/missusamagicd/ ... ions4.html
and my best buddy alex ('yellow' on these forums) http://www.partyapp.com/photos/fullsize/89891.jpg
are headed down to tampa, fl for spring break. We're looking at going from Boone -> Charlotte -> Atlanta (to get Alex) -> Tampa, FL
The car of choice? Mine.
So -- What should I check, double check, and triple check on my car before we go?
My current oil has about 3500+ miles on it (Mobil1 Synthetic -- changed every 5k). And I haven't experienced any problems with radiator fluid leaks or loss of oil. And 2 weeks ago I ran into a problem w/ my adjustable rear shock losing it's perch and bottoming out (and possibly blowing the shock).
In the back of my car I have wrenches from 8mm-17mm, shallow sockets from 1/4-3/4" and 10mm to 19mm (i think). I huge MOFO pair of knuckle busters 1 pack a metric allen keys ranging from 2mm-10mm, 2 extra quarts of oil, 1 liter of water, 1 thing of powersteering fluid, 1 thing of brake fluid, 1 propane torch, and 2 jacks (stock bmw jack and cheap autozone jack).
I'm still using snow tires -- but we're going to swap wheels w/ the turbo car when we get to Atlanta to get some fresher all-season tires on the car.
Any other suggestions along with what I should check over?
Thanks --
Tj
Thanks --
Tj
actually, i'm gonna go with brad on this one. and you should probably keep my cell number handy because i'll be coming down that way (miami) on fri, march 5 and i'll be around if you need me i guess :-) also, i'd ask some people around that area for some numbers for assistance if you need it and give your car a good once over (duh) just to make sure everything is alright..
and a new cd player would'nt hurt either.
seriously though, i doubt you'll run into any problem that you and alex together cant figure out, and if you do just add another alex to the bunch and i'm sure we can come up with something.
More tape, twist- ties, roll of wire and easy connects........
Hahahaha the truth is painful
I don't think I'm going run into problems with radiator hoses -- but thats my biggest concern thus far.
Almost forgot - a spare key!
Always got one in my wallet
I def got a handful of spare relays -- including a main relay. I'm not too worried a/b the main relay since I just put a brand new one on about 2 months ago. I got a lug wrench. I don't have any extra alternator belts.... Maybe I should grab one.
JUST IN CASE (I'm really worrying too much a/b this -- I did just do a 12 hour road trip this past weekend... but without a bunch of passangers) -- Do any of you know a "backyard" fix for a radiator leak? Say one of the main front hoses pops -- how do I fix it? I read somewhere about a combination of shirts/rags and duct tape will patch it for a bit.
Alex I always have your number on speed dial
Any FL guys mind giving me your numbers just in case? Especially the cool cats in Tampa?
And I'm not even too worried about the radiator hoses if you think about it. My car rarely gets CLOSE to 12oclock when driving. It usually stays only 1/4 on the temp gauge. Hell sometimes after hours of driving I can pop the hood and still touch the radiator hoses (for short amounts of time ) cause they never got all that hot. So if the hose is supple and never is exposed to super hot temps... it should last for a while right?
Emergency radiator hose repair kits like this one are widely available - Pep Boys, K Mart, Target, Walmart, AutoZone etc.
http://www.jcwhitney.com/autoparts/Prod ... 45/c-10101
And there is the 5er Fest Road Trip Guide. You might have some room left for your beach chair . . . . ..
