Page 5 of 9
Posted: Mar 28, 2012 6:08 PM
by DieselBoost
finally my car is in my work place....
it had lot of bird crap etc... not anymore
Posted: Apr 20, 2012 9:15 PM
by DieselBoost
My new 12mm 12.9 studs
I found some ventilation holes in bottom...
The exhaust
actually that silencer is dummy... with 3" straight pipe
Posted: Apr 20, 2012 9:19 PM
by mooseheadm5
What material are the studs made from? Studs like that with cut threads are not as strong as studs with rolled threads.
Posted: Apr 20, 2012 9:23 PM
by DieselBoost
mooseheadm5 wrote:What material are the studs made from? Studs like that with cut threads are not as strong as studs with rolled threads.
studs are made from 12.9 bolts... by local bolt shop
i know that cut thread is weaker but that is quite minor problem
Posted: Jun 15, 2012 10:50 PM
by DieselBoost
This is what im doing now... i was little bit bored...
The wicked twins mitsubishi td04 from 525tds and masterpower 70super
For the intake side
Flap on the place
Downpipe with flap valve
and yes it is variable turbo system!
Posted: Jun 25, 2012 4:19 PM
by DieselBoost
Moving on!
Posted: Jun 26, 2012 5:05 PM
by DieselBoost
Again little progress with boostpipes
Almost all boost pipes where made from scrap metal pipes etc...
needs only little bit grinding and paint...
Posted: Jun 26, 2012 8:07 PM
by Brad D.
I await dyno numbers. It looks really sweet. ````
Posted: Jun 27, 2012 9:05 AM
by Cooperman
Sweet build. Subscribed.
Posted: Jun 27, 2012 9:32 AM
by Eddie in TO
Wow, this is very cool! The torque will be very nutso. I like!!!
Posted: Aug 08, 2012 4:31 PM
by DieselBoost
Bmw club Finnland track day @ Kemora circuit 4.8.2012
Posted: Sep 10, 2012 5:43 PM
by DieselBoost
This is the reason for my stubborn gear box...
it is "quite" stuck...
Posted: Sep 16, 2012 3:23 PM
by insane524td
Wish i had the skills to do all of these mods!
Posted: Sep 18, 2012 5:54 PM
by DieselBoost
Actually these does not have anything to do with bmw's but...
Some people may like these...
So... This is exhaustmanifold for my 1700cc lada engine
Turbo is custom made racing hybrid turbo charger
(Holset H1C/H1E) turbine chamber is ported to larger scale but still smalle that in Holset H1D Made by Timo Lehtimäki
Posted: Oct 21, 2012 8:20 PM
by DieselBoost
Pneumatic cylinders for my biturbo system
These are operating flaps in exhaust and intake
Posted: Oct 24, 2012 7:25 PM
by DieselBoost
Operation biturbo continues...
downpipe is ready for test fire in my car
Fitting of pneumatic cylinder for intake flap
Posted: Nov 03, 2012 11:29 PM
by DieselBoost
New gearbox for my car
self made shifter (really short to shift!!!)
Old chrome fenders painted with body colour
Testing my shifter
Clutch assembly "tool"
Paint job for body
Posted: Nov 04, 2012 12:30 AM
by Brad D.
Awesome!
Posted: Nov 05, 2012 6:02 PM
by DieselBoost
Destruction derby continues!!!
again i has problems with starter
Posted: Nov 06, 2012 8:43 PM
by insane524td
Cant wait to see a vid of the 524td!!
Posted: Nov 07, 2012 7:22 AM
by DieselBoost
insane524td wrote:Cant wait to see a vid of the 524td!!
Soon... i just got my starter welded up...
we just got first snow in here.... im considering about changing small turbo for winter use... big one spools up too badly and i just dont have time to make my biturbo setup operational...
Posted: Nov 07, 2012 8:08 AM
by audioscience10
Sweet project man. I did something similar with a sequential turbo homeade jet engine. One thing I did different though is I had my small turbo forcing air into the big one instead of relying on vacuum, then an actuator opened once the big guy was boosting. I changed to this because I was getting a pressure lull when the big turbo was kicking in, because its still pushing air through the small one as well as to the motor. I don't have any pictures but if you're interest at all I can draw up a quick diagram of how mine went.
Posted: Nov 07, 2012 8:11 AM
by shagrath
Thread full of awesomeness!
Posted: Nov 07, 2012 2:20 PM
by DieselBoost
audioscience10 wrote:Sweet project man. I did something similar with a sequential turbo homeade jet engine. One thing I did different though is I had my small turbo forcing air into the big one instead of relying on vacuum, then an actuator opened once the big guy was boosting. I changed to this because I was getting a pressure lull when the big turbo was kicking in, because its still pushing air through the small one as well as to the motor. I don't have any pictures but if you're interest at all I can draw up a quick diagram of how mine went.
Gosh! i almost forgot those diy jet engines
we had parts for one.... size was huge
Holset 4LEK with combustion chamber made from 6kg fire extinguisher with afterburner made from 12kg fire extinguisher!!!!
Posted: Nov 07, 2012 2:21 PM
by DieselBoost
Starter is fixed now...
