PEDAL BRACKET Reinforcement / repair - REV. 6-welded tab
Re: PEDAL BRACKET Reinforcement / repair - REV. 4-welded tab
Payment just sent via paypal for Rev 5 bracket with tab, e28 M5.
Thanks -- looking forward to it.
You have paypal!
Yes I have paypal, dp1019@gmail.com, can ship this week, thanks dave, this is also a personal email,easier too connect
Just received Rev 5 bracket with welded tab for my M5. Products looks like OEM, excellent quality, very well made and presented! The instructions are very precise.
Dave
Dave
hi guys. I have a 87" 535i, I looked underneath the steering wheel, and i feel so stupid, i have no idea what i am looking for, and i dont see any 'bracket' that looks like what OP is selling. I also did not see anything cracked, or broken. But if you watched the video below, that's the problem i am experiencing.. Extreme stiffness on the clutch, also the grinding sound. No leaks anywhere, so it shouldnt be Master Cylinder or Slave Cylinder problem. Any suggestion?
View My Video
View My Video
i spent some time today looking underneath again, with good lighting, this is what i saw (sorry for the large and many pics)
is this the crack that this pedal bracket is for?
Yes sir. No problem seeing that one.
I had two previously that were faint lines as the crack stayed tight.
A third one opened up like yours.
about to order one right nowMr_Squishy wrote:Yes sir. No problem seeing that one.
for your 3rd one, did you only need to use this bracket reinforcement and that was good enough? Or did you have to re-weld the cracked bracket or replace it?
paypal-ed $44 to dp1019@gmail.com, hoping this will fix my problem.
Your crack is pretty bad.. I would re weld it or get a new pedal box. The bracket sold in this thread is more for prevention... although I guess you can put it on and see if it fixes your problem.
Is the part number 35111157728 correct for the bracket replacement? What's the best place to order one?RondoAcapriccio wrote:Your crack is pretty bad.. I would re weld it or get a new pedal box. The bracket sold in this thread is more for prevention... although I guess you can put it on and see if it fixes your problem.
That # looks right. It's a dealer part, but places like BluntTech.com, ECSTuning.com, etc., can get it.blackwidow.666 wrote:Is the part number 35111157728 correct for the bracket replacement? What's the best place to order one?
Try using http://www.furiousmethod.com/ to check pricing.
No new clutch slave?
BK
BK
So after a few hours today in the afternoon, i finally finished installing the new bracket, the reinforcement, put everything back into place. Was all excited about to start the car to do a test drive, car wont start
The car has power, all the dashboard lights came on, but the car just wont crank up. No sound, nothing. It's behaving as if i m trying to starting the car without engaging the clutch (but i did obviously). I checked the little red button switch that's touching the clutch, when i press the clutch, the red button 'releases', so i guess thats normal right? But yet, the car just wont start.
What the hell??!! Any idea?
Is your car 535? .. on my 528 .. and I think 535 is same, does not require you engage the clutch to start the car. Secondly installing this should not have an effect on starting the car. Something else broke while the car sat or w.e imo.
RondoAcapriccio wrote:Is your car 535? .. on my 528 .. and I think 535 is same, does not require you engage the clutch to start the car. Secondly installing this should not have an effect on starting the car. Something else broke while the car sat or w.e imo.
yes, mine is a 535i.
if what you saying is true, then what is the red button/switch for near the clutch pedal?
Turns cruise control off.blackwidow.666 wrote:RondoAcapriccio wrote:Is your car 535? .. on my 528 .. and I think 535 is same, does not require you engage the clutch to start the car. Secondly installing this should not have an effect on starting the car. Something else broke while the car sat or w.e imo.
Maybe a weak battery, or something in the area of the OBC control box got disconnected.
OP:
These still available and ready to ship?
Thanks in advance
Thanks in advance
Re: PEDAL BRACKET Reinforcement / repair - REV. 5-welded tab
Revision #5 parts now ready too ship, new pics up soon, sorry my post is lacking updated info, will try too get current, thanks dave
bump for new batch in stock, can ship asap, new pics up soon, dave
any black friday deals? JK do you have any in stock for the e28 im interested
- Location: Iowa, no Wisconsin. No, Colorado, but moving shortly to Minnesota... yep, I'm here again. still.
Pm'd from St. Paul to St. Paul. Want...
And, Got my Revision 5. Looks quality. Thanks Dave!
Forgot to ask,
Will this fit '87 e24?
Edit: just saw it does. $ coming in!
Thanks
Thanks
Just sent PayPal for one. Thanks David.
paypal sent! Looks like a great product
Order placed via Paypal. Looking forward to it! Thanks!!!
