PEDAL BRACKET Reinforcement / repair - REV. 6-welded tab
indycar89
Re: PEDAL BRACKET Reinforcement / repair - REV. 5-welded tab
Post by indycar89 »
David - I sent you a PM on the 10th. Did you get that?
Thanks,
Dave
indycar89
Post by indycar89 »
paypal sent
DAVID PEPIN
Post by DAVID PEPIN »
BUMP, CAN SHIP ASAP :laugh:
DAVID PEPIN
revision #5 in stock, and ready too ship asap, rev #5 change is minor enlargement of 6mm slots, dave
revolve40
Post by revolve40 »
Payment sent! Thanks!
DAVID PEPIN
BUMP
man03999
Post by man03999 »
Payment sent. Thanks David!
DAVID PEPIN
BUMP
DAVID PEPIN
BUMP---BUMP
psbirch
Post by psbirch »
Payment sent -- thanks!
DAVID PEPIN
BUMP
EvanJacob
Post by EvanJacob »
Paypal sent. Thanks!
norcale28
Post by norcale28 »
received my revision 5 bracket today. can't wait, actually i can, to install it. not looking forward to contorting for the install. i did notice, however, an inch and a half or so crack. i'm hoping this bracket will help resolve this. or do i need to replace the clutch/brake pedal bracket completely? that seems like a major PITA.
norcale28
Post by norcale28 »
UPDATE:
installed my roth pedal bracket reinforcement. took a wee bit longer than i'd anticipated, about 2 hrs. there's not a whole lot of space underneath in the pedal area. i used a 10 ml offset box wrench to remove the original bolts (# 2&3) in dave's installation instructions. #1 came off easily with a 13ml deep socket.
reinstallation was a bit dicey as well. #1 screw went on pretty easy. #'s 2 & 3 were trickier. i had to remove the nut/bolt from the master cylinder piston to in order to line everything up to reinstall dave's bolts. if you don't you'll be spending way too much time and energy trying to force them to realign. it took me about 10 min to figure this out. i was able to get #3 nut to go on the bolt but lost #2 nut and the extra one as well. i couldn't get my fingers around the mc to install the nut. i'll get it on there, it'll just take a few more attempts.
clutch pedal play feels solid. my pedal doesn't return all the way, however. i think i may have a bad slave. going back under in a few days to check this out.
btw: my original bracket has a 1 1/2 inch crack in it and i realize that there was more play when engaging the pedal than i thought now that the roth bracket is installed.
big thanks to dave for his insight in making this bracket and making it available for the rest of us. :thanks: :clap:
allenfarmelo
Post by allenfarmelo »
Mine went in a couple weeks ago and it's a great improvement! Thanks Dave.
dcains
Post by dcains »
I've got an '85 Euro E24, so if one of these will fit, and if one is available, please send me a PM with payment instructions and I'll send the PayPal ASAP. Thanks.
dcains
Post by dcains »
Hi Dave:
PayPal on the way - thanks for the quick email reply.
doug
Post by doug »
Payment sent.
I haven't looked at my e23 pedal bracket yet to check for myself, but are they also prone to this failure?
Edit: Thanks, Dave. I got that part in the mail before I even started looking for it.
DAVID PEPIN
BUMP
DAVID PEPIN
new batch of parts in process, have non tab in stock, tab part done in 2 weeks, dave
carlb
Post by carlb »
Payment sent!
alkalineom3n
Post by alkalineom3n »
Do you currently have any tabbed brackets for an E28 available?
Pattonky
Post by Pattonky »
Just sent my payment via PayPal. Please let me know that it is happening.
Nice elegant solution, never saw this thread. Hi from MN, I'm in Mendota Heights!
Doublechecked parts CD to see if pedal bracket was shared with the E12 but they look completely different so since I'm E28-less I don't need one of these.
delvin
Post by delvin »
Paypal sent
Pattonky
Post by Pattonky »
Endorsement/Testimonial: I am very happy with this as my clutch has never felt better, nor have I ever felt more confident in it. As everybody seems to say it is only a matter of time before they crack. Solid Seller!
DAVID PEPIN
Have plenty of both in stock can ship asap, thanks dave
tesko
Post by tesko »
I'll take a Bracket with welded tab up to Canada, wanted to post here to confirm before sending payment - a total of $50 shipped? 1987 528e
buddha
Post by buddha »
Payment sent for two brackets with tabs, one each for e28 & e30.
buddha
Post by buddha »
Received..thx
