Operation: Parking Lot Hartge: Update 9/21/22, Back in the saddle
alpinass
Great find!
Post by alpinass »
front spoiler
IF you end up needing one.
landspeed
Re: Great find!
Post by landspeed »
alpinass wrote:front spoiler
I will let you know when I have the cash.
landspeed
Post by landspeed »
Turns out the rust wasn't as bad as previously thought, but I'll be needing a new one of these:
The rest turned out pretty decent, a little more cleanup before the Por-15.
Post by Coldswede »
Be sure to use some kind of sealer, ie: caulk, with the new hole plug.
landspeed
Post by landspeed »
It will be coated with Por-15, top and bottom too. Just gotsta get a new plug.
:pimp:
Congrats on the find. Subscribed.
gwade
Post by gwade »
Awesome find, congratulations!
I have a complete upper H5S head, intake, AFM, DMW, dist, and harness for sale here: http://www.mye28.com/viewtopic.php?t=11 ... rtge+parts and a matching M90 L-block too.
Here is a list of all the p/n's for an H5S, Best of luck!!!
Hartge 3.5 liter L-Jet engine conversion – P/N 11 31 0500
M90 L-Block, 9.34 bore x 84mm stroke, 10:1 compression
Hartge ported & polished BMW 3.5 head & port matched 2.8 intake manifold
+1mm intake valves, +2mm exhaust valves
Hartge .292 degree camshaft
Hartge valve cover
Hartge AFM (M535i) Bosch 0 280 203 002
Hartge ECU (M535i) Bosch 0 261 200 061
Hartge distributor (M535i) Bosch 0 237 302 008
Auxiliary oil cooler
Rising rate fuel regulator
Hartge header front & rear – P/N 18 31 0562 & 0563,
Getrag 262 close ratio sport transmission “Dogleg”
Differential 3:07 ratio
Hartge front brakes four piston 282mm (M5) – P/N 34 31 0100
Hartge stabilizer bars – kit P/N 31 31 0535
20mm front – P/N 31 31 0531
15mm rear – P/N 33 31 0532
Hartge front strut brace – P/N 31 31 0555
BMW rear strut brace – P/N 71 60 1 126 613 BOE
Hartge suspension – kit P/N 31 31 0500
Hartge/Bilstein front struts - P/N 31 31 0501
Hartge front springs – P/N 31 31 0502
Hartge/Bilstein rear shocks – P/N 33 31 0503
Hartge rear springs – P/N 33 31 0532
Negative camber front strut mounts – P/N 31 22 0200
Hartge wheels – (OZ) aluminum staggered
Fronts 7.5”x16” ET13 – P/N 36 31 0755
Rears 8.5”x16” ET25 – P/N 36 31 0855
Tires
Front – 225/50 16
Rear – 245/45 16
Hartge spoilers
Front spoiler – P/N 51 31 0500
Rear Spoiler – P/N 51 31 0600
Hartge mono wiper – P/N 61 31 0505
Hartge body decals anthracite – P/N 51 22 0920
Hartge steering wheel (Momo) – P/N 32 22 0400
Hartge shift knob – P/N 99 49 0140
Hartge speedometer 280kph – P/N 62 31 0010
Hartge instrument cluster - P/N 62 22 0100
landspeed
Post by landspeed »
That is a much appreciated list gwade. I have been looking at you head and block for sale, unfortunately I don't have that kind of money right now. Hopefully I can find the right parts when I do, but I might just build a Hartge "spec" motor using newer technology.
Post by Coldswede »
gwade wrote:Awesome find, congratulations!
Here is a list of all the p/n's for an H5S, Best of luck!!! ....
Slight highjack maybe but: Gwade are you saying you can order those part numbers from Hartge (Or someplace)? Or was this just info for Landspeed to check on his existing parts?
I don't want to question anything but I don't see how the H5s would run a Motronic ECU and an L-Jet AFM and distributor.
gwade
Post by gwade »
All those parts are NLA. The p/n's are taken from Hartge literature for reference.
I cut & pasted the specs from my own project and see that I should have deleted the 533i flywheel, Quaife differential, and 540i rear brakes. I also can't confirm Hartge used the 210 "big case" differential but definitely used 3.07 gears to the dogleg.
Sorry for any misinformation.
landspeed
Post by landspeed »
wkohler wrote:I don't want to question anything but I don't see how the H5s would run a Motronic ECU and an L-Jet AFM and distributor.
Maybe a production split? Do the late cars run Motronic?
Every 528i right up until 11/87 was L-Jet and as far as I know, that's what they built all of their cars from, so I don't know.
None of the 528s came with big case diffs either, but before 9/84, there wasn't a rear cover that fit E24/E28, so they wouldn't have come with one.
landspeed
Post by landspeed »
Unless I'm mistaken, I think mine has a big case diff, looks larger than the diff in my IS, has a weird rear mount too.
Jelmer538i
Post by Jelmer538i »
Count the bolts of the side bearing carrier:
6 bolts = 188 diff
8 bolts = 210 diff
Drain plug on the side is a giveaway, too.
landspeed
Post by landspeed »
Damn! Mine is a medium case.
Should be as it's an '84.
landspeed
Post by landspeed »
Now I need to scrape the grease off the tag and see what it is.
TheE28Ranch
Post by TheE28Ranch »
landspeed wrote:That is a much appreciated list gwade. I have been looking at you head and block for sale, unfortunately I don't have that kind of money right now. Hopefully I can find the right parts when I do, but I might just build a Hartge "spec" motor using newer technology.
Actually, the head Greg has for sale used to be in my '83 Hartge. If anyone is interested in buying it, I'd suggest looking at the head thickness to see if it is still within spec tolerances. I recall it just being under, as it was blocked a few times, believed by a prior owner and prior to a 3.8 engine build I had done that didn't take (and maybe again after?). But it has been years. Either way, I then decided to go another direction myself as you can get more performance out of a newer technology engine. Hartge engines from '83/'84 are peppy but antiquated. And by the time you buy a green block, the $3,600 head package, headers (which you have already, right?) and get it built....well, come to your own math. I sold all that stuff for a reason. And all for about $1000 or so between what went to Gwade through TCD and what I hooked Gwade up with to complete the package he now has, after he sought me out for what he wanted in terms of Hartge. I took good care of him, and also gave him a stack of spec sheets and other information. I look forward to seeing what his hartge tribute car ends up looking like. But back on topic, I really like to watch your progress here, Landspeed.
landspeed
Post by landspeed »
Thanks for the info Trey. I'm not sure if I want to make the motor 100% correct in favor of more modern tech. I'm thinking maybe a b35 built to Hartge specs with a maf. I will post a progress update tonight.
gwade
Post by gwade »
Trey, your post smells. I don't appreciate you plopping all over a perfectly straight and re-worked Hartge H5S upper motor available for sale. Dissuading a fellow H5S owner from a proper restoration. Your costs date back seven years and your choices to gut your own rare car are just that. I even gave you first offer at a lower price in an attempt to reunite the motor to its momma. What gives?
email gwade9@yahoo.com or
call 310 890 6797
If I had an H5s that didn't have the original motor, I'd do what I could to get the right stuff. Sure there are better options by now, but that's just how I am I guess.
landspeed
Post by landspeed »
wkohler wrote:If I had an H5s that didn't have the original motor, I'd do what I could to get the right stuff. Sure there are better options by now, but that's just how I am I guess.
I definitely hear what you're saying, I just don't have that kind of money right now, I have a baby on the way. My wife would slaughter me if I dipped into savings for car parts. I would love to buy Greg's top end setup and make a complete car, I just doubt I could find the parts I need when my finances stabilize. Plus, I still need proper wheels and an airdam.
Mind holding on the those parts for a year, Greg?
J/k
TheE28Ranch
Well
