What Did You Do To Your House Recently?
Re: What Did You Do To Your House Recently?
ElGuappo wrote:I even scored some foot operated pedals, like hospital or restaurant sinks use, cheap on CL. So no hands required when I'm covered in grease. :up:
Nice. :cool:
wkohler wrote:I bought one of those Costco lights last night. It's pretty friggin' bright. I'd actually say it's brighter than the two fluorescent lights I've got hanging in the garage right now.
Unfortunately, for me, the big drawback on this is that there is no switch on it. My other lights have a pull chain. This one has to be hooked up to a switched outlet or something and there's no way to hard wire it in from what I can tell. I was thinking a few of these on the ceiling could give me all the light I'd ever need, but I'm on the fence.
ElGuappo wrote:Charles, I've not seen the cast iron tee like that, its much shorter.
This picture is a bit distorted but the fittings in your house probably had lead and oakum joints and trust me, you don't want to go there. It involves the oily rope that they used to seal the seams of wooden shops with and every old wheel weight you have melted down to liquid form. :shock:
ElGuappo wrote:The drain stack is for the washing machine, and at least an upstairs sink if not also the toilet. Sure sounds like it when its flushed anyway.
My bad. I didn't think they built 2 story house in the cast iron era in California. Do you think there's any chance the laundry drain downstairs was added after the house was built? The fact that you say it's noisy makes me think so and it's probably not to code. It shouldn't come directly off the large stack if there's 2nd floor drains also tied directly to it.
ElGuappo
Post by ElGuappo »
House built in 1985, so you would think ABS, but the stub out of the drywall for the washing machine drain is cast iron.
I still need to cut into the drywall and expose what I'm working with, there could be multiple drain lines coming from upstairs.
Chris, you can splice a switch, either toggle/rocker or pull chain easy enough into the cord.
Also easy enough to wire in a switched outlet in the ceiling for them, I seem to recall you were sans drywall in your garage?
ElGuappo wrote:House built in 1985, so you would think ABS, but the stub out of the drywall for the washing machine drain is cast iron.
If it was built in '85 the then we're talking about a 2 hour fire wall (or possibly one hour in '85) between a garage and living space (hey, it was the '80s, it's a miracle I remember ANYTHING). You'll be cutting through 2 layers of 5/8" Type X drywall and I'm pretty sure you'll find ABS behind it. Plastic isn't allowed for stub-outs in a fire wall so cast iron, steel or copper is usually used.
It was too cold and windy to paint or play with cars. I decided to de-lint and redo our dryer and vent. The last rendition of the vent required getting up on the roof 28" at the ridge. I'm a lot more careful on ladders now. Best not to be using them if other means are available. I use 4 " thin wall PVC drain pipe. It is about 16' long total. I tucked the vent into a wall. Bad idea. but I'm stuck with it now. I cut the pipe about a foot above the dryer. I can unhook the vent from the dryer in less than a minute now. Re-attachment is enhanced as well. I took the dryer apart and cleaned the lint out of all the places it collects. I greased the drum running blocks with Sil-Glyde and put it back together,then called it a weekend.
Post by unt0uchable »
Oh holy hell. I'm going to have to start posting my home projects. This is all I needed around here, lol!
wkohler wrote:Those are sweet.
A little late on the draw, but I've got several wireless switches of a different brand and they work great. You just plug the receiver in, then plug the lamp or whatever into it and mount the light switch where ever you want it. I ordered some replacement batteries last year but the oldest are now 6 and I haven't had to change one yet, there obviously being a battery in the remote wireless switch.
http://www.amazon.com/Heath-Zenith-BL-6 ... RRY2F3C3G2
ElGuappo
Post by ElGuappo »
On the cabinet above my workbench that has a 2.5" fascia at the bottom, I removed the hateful dual T12 48" fluorescent fixture that hung below the fascia, and installed 2, 24" T5 lights I had purchased for our closet a while ago, before we found better LED fixtures at Ikea.
They were individually switched, so I spliced in a toggle I had, and ran it thru the fascia with some galvanized steel to make it look cool.
I never thought it could be so satisfying to turn lights on and off, but you feel like Igor firing up the machinery for the good Doctor.
I installed a bunch of those Heath Zenith switches around the detached garage and downstairs in the house, and configured them to be controlled by the very old-school looking Master Command Lighting Control Panel. This is so that at night when I realize I left some lights on I don't have to go all the way outside to turn them off :) Works great!
Other ongoing house tricks.... My plumbing list suddenly got long, so I've got a plumber in today getting a bunch of work done. The house has a pair of 40-gallon NatGas hot water heaters, in-line to each other. They've been there since the house was built ('96), and I've been on the watch for breakage. In addition, the house was not built with hot recirculating loops, so it takes a few gallons and a few minutes to get hot water 45 or so feet across the basement and two stories up to the master bathroom. That's not ecologically sound! Some minor drippage finally started at both of the HWHs, so it was time to get them done.
First, we're putting in a recirculating loop for the section of the master-bath run that goes across the basement. This takes up more than half of the run, and will be a great improvement in hot water access. Second, both of the 40's are coming out and a Navien NPE240 tankless heater is going in for the whole house. This should be a much more efficient hot water set up for both water and gas usage.
Third, the house humidifier that I've been nursing along with crazy glue and duct tape for the last 5 years is getting replaced. I was going to do that myself, but since Lloyd's coming to the house anyhow.... He's also going to move the feed for the humidifier to an internal, softened water line. The original installer (before I owned the house) tapped the main feed before the water softener, so the humidifier panel gets crusted solid after about 8 weeks. That will be a nice improvement.
Finally, inspired by demetk's discussion of the mini-split for his garage, I'm having them size up a dual-head mini-split for the 'other' garage. There's 1200 feet downstairs and 800 feet upstairs that I've kept somewhat warm with ceramic resistance heaters and cool (upstairs) with a window unit over the years. It's time to graduate to something more efficient. Again, I will not be installing that myself....
Yay house! Yay planet! :)
I put checkered tile in the workshop. I figure projects should go 25%-30% faster now.
Early reviews have been positive.
bbaxter
Post by bbaxter »
Have you tried the new LED lights. Those things are really bright. You can use a much smaller fixture because they are so bright.
bbaxter
Post by bbaxter »
I started building my new shop in the back yard. The foundation is in and the slab is poured. Lumber and trusses are on the site. Have a few walls layed out but none standing yet. 36 x 40 with a 12' ceiling.
ElGuappo
Post by ElGuappo »
Dude those are crooked and I'm not even leaning. I'll repeat this while leaning in March. :-)
grahamular
Post by grahamular »
Replaced the inducer fan motor and start capacitor on my furnace. I've had the part for a few weeks but had put off digging into the repair since the furnace had started working normally just after I bought the parts. But...a few hours after arriving at our cabin Friday night for a long ski weekend, I got an email from the thermostat that the house temp was down to 45F and dropping :( So had to cut the weekend trip short and drive 4 hours back home to do the repair in order to avoid the risk of pipes freezing. Good news is it seems to be working fine after the repair, and I used the "free" time at home to finally build my iRacing PC :)
Graham
Having reached the boiling point more than a few times on home remodeling projects, I can relate to the frustration that led this guy to bulldoze his house. I think he went just a tad too far though. :laugh:
http://launch.newsinc.com/share.html?tr ... d=28403485
That's only about 25 minutes from me. I have to say it's sort of unsurprising for Middletown... :laugh: :rofl: :cry: ;)
demetk
Post by demetk »
davintosh wrote:Having reached the boiling point more than a few times on home remodeling projects, I can relate to the frustration that led this guy to bulldoze his house. I think he went just a tad too far though. :laugh:
:laugh: I can relate to that. I got just a little carried away with was to be a little roof job.
Oh oh.
Now what?
Awesome new Master Suite?
Add some nice large dormers and windows for lots of light. Bedroom, bath, and study.
Lot's of potential.
demetk
Post by demetk »
vinceg101 wrote:^^^
Lot's of potential.
When you have an 80's house "potential" is a word you use a lot. :) Eventually a full dormer was born.
And you're right on the mark Vince, it will be a new master suite. I didn't realize it was going to be that much work though. I'm just finishing off the sheetrock work.
I think that's known as "project creep". ;)
This weekend I finished up re-grouting the tile surround above the tub in the main floor bathroom. Ugh. Now I know why my tile guy quoted me $800 to do the job. The tile was put in three years ago, but there were several places where the grout had popped out leaving a nasty gap, so we decided to bite the bullet and just do the whole works. Actually I only did it up to about eye-level because the upper ~2 feet doesn't see much water and was 99% intact.
I'd post a pic but it's really nothing to see, plus there's still plastic stretched over it so it can be used for showers again while we wait for the sealer to dry; the directions say to keep it dry for 72 hrs. I'm not sure how critical that is, but the plastic isn't much of a bother.
I also made a little more progress on clearing out some of the excess stuff clogging up my workroom; four old Macs that I picked up who knows how long ago for nothing, sold to a guy who went away smiling like he got the bargain of the century. Win-Win.
Post by Coldswede »
I did the Heat loss calc to see how much Ptex I have to run under the floors.
Seems like it will be a lot of work... maybe I'll just have a beer instead.
I am kidding, except about the work. :laugh:
I replaced a couple of light fixtures in the basement bathroom. I started out intending to replace the fixture over the vanity; the old one was a track light that didn't do a very good job of providing light for that spot, plus it used some halogen bulbs that were about $7 each. Replaced it with a regular 3-bulb vanity light that does the job much better.
But while I was shopping for that fixture I stumbled across an LED fixture that matched the style of the vanity light; for $20 I couldn't pass it up.
Instead of light bulb sockets, it's got this inside:
And when it's connected & turned on it does this:
Image[
The color is a bit harsher than I'd like, but it just provides light over the stool and for the shower, so NBD. No bulbs to replace, and it does its job without generating a lot of heat; I had it on for the ~2 hours it took to install the vanity light, and when I put a hand on the glass dome it was no warmer than the ceiling around it. And no bulbs to change, ever.
Pretty cool that LED has reached the point where fixtures are being designed around them and work this well.
We recently started on a Kitchen & Laundry Room remodel; we had been procrastinating too long and had to get over some work hurdles at the end of last year.
The Kitchen was one room that we didn't touch when we bought the house 16 years ago mostly because it was functioning and there were other spaces and items in the house that needed attention first. Well, time marched on and the economy took a dump and we procrastinated some more and blah blah blah...you know the drill. You've all been there at one point.
There are actually three rooms/spaces in all but are all connected along this side of the house: Laundry Room, Kitchen, and Breakfast Room. The house is a mostly original 1927 Transitional single story house pretty typical for the housing stock in the Hollywood area of Los Angeles. The house and garage were moved to its' current location (West Los Angeles) in 1950/51 when the Hollywood Freeway was built through the middle of the city; not knowing exactly where it came from, that move was approximately about 15 miles. (We recently did a major foundation & Living Room repair discussed here:http://www.mye28.com/viewtopic.php?f=2& ... n#p1226645 and here earlier in this thread.)
Anyway, the spaces were in desperate need of a remodel since the last time it was done back in the '70's. We really wanted to get our Breakfast Room back (the small room has been home to the refrigerator, toaster oven, and microwave). The cabinets and sink were original from 1927 and were rather crude field built units, but made out of the clearest, cleanest Vertical Grain Douglas Fir you have ever seen. Pretty typical for this era house. All the tile work on the counters and backsplash were original as was the sink; all pretty beat up after 86 years.
A few right before photos just after/while we were emptying the spaces; it's amazing how long it took to pack these rooms:
Shot looking down with the Laundry Room in the background:
Shot looking up into the Breakfast Room at the top of the photo:
Demo: Boom
Bam:
Crash:
Here it was cleaned up:
The things you find hidden: The instructions written by the foreman 86 years ago:
Roughs are done: Plumbing, Electrical, and HVAC.
Framing for the new arches into the Dining Room:
Drywall and Plaster are underway and the finish coat is being put on as I write this:
One to the big hidden infrastructure costs was re-wiring this side of the house. We had a new 200A Service Panel installed last year but never parsed out the circuits and wire runs; with the new Kitchen needing a pile of dedicated circuits, we had to have this done now. It was an expensive, major PITA as they had to work in the attic and under the house running new conduit, isolating neighboring rooms, bypassing old ones and running new wire. A necessary upgrade.
Next up is cabinet assembly and base installation. We decided to go with Ikea cabinets with a custom wood fronts (doors, drawers, and panels). It's a good compromise and economical to boot; Ikea makes a pretty good cabinet for the money and all the hardware is Blum (one of the best German hardware companies). For the money, you can't beat Ikea; they are a fraction of the cost of any custom cabinets or even what you get at Home Depot. We were going to do Ikea anyway but we had a client who wanted to replace her Ikea kitchen last November and we were very impressed by how they turned out as was the high end custom General Contractor who assembled & installed them (the only reason for the replacement was a water leak took out pretty much everything in the house).
After that: flooring
Our Dining Room is serving as our temporary Kitchen for the next few months. This room has gotten the short end of the stick lately: last year at this time it was our Living Room while the real one was being remodeled.
Anyone want a nice used original 40" Wedgewood double oven? It's too big to go where the range needs to go in the new design. I hate to give it up, but we have no choice :( .
Yikes! The guy that added the pass through at some point, really knew what he was doing. :)
vinceg101 wrote:Image
