Page 1 of 2
Posted: Jan 18, 2009 6:18 PM
by Jordanmilos
I've been looking at the plate for about an hour now, trying to figure out whether I like the whole relocation idea. I think I need to look at my E24 a bit more and figure out if the Trans-Dapt kit is the way to go. I could always modify the plates to accept a spin on filter but then it loses its effectiveness when it comes to running a cooler. The only thing I can think of is making a simplified version for those who never wanted a cooler to begin with and just need a place for senders and sensors. The remote filter idea would make oil changes easier and at the same time, provide a good system to add a cooler to. You could run the cooler after filtration and keep the pressure up. Just thinking aloud here.
Re: Sandwich plate adapter
Posted: Jan 18, 2009 6:26 PM
by Jordanmilos
paul burke wrote:
Keep carving , I am anxious to see what you come up with.
I am making a complete replacement billet filter unit and it is a cumbersome task. Yours may be more sell able, as mine starts out with a 4x4x4 chunk of 6061 and will probably cost more than people will want to spend.
Paul
Thanks for the encouragement. I agree on the cost. Once you add the time up, you laugh at your "profit". I'd still much rather do this than bore out throttle bodies, less flaming and more CNC fun :-)
finished product
Posted: Jan 20, 2009 8:14 PM
by Jordanmilos
So, here's the final product. I put the senders in to give an idea of what the extra ports can be used for. In this case its oil temp and oil pressure. Hoses are 30in long and at this point, mounting location looks to be on the drivers wheel well. I would envision the coolant expansion tank bracket as a good place.
Posted: Jan 20, 2009 8:31 PM
by Brad D.
That looks fantastic. Any estimation on price?
Posted: Jan 20, 2009 8:42 PM
by Jordanmilos
Everything you see in the pic will run you $195. Take away the senders and the price comes down to $155. I will include the hardware needed to finish the job. You can use the stock bolt to put it in place but it sticks out a bit. I made a mistake in ordering the replacement bolts and actually got longer ones instead of shorter ones. That however gave me another idea to make these work on the B35 motors as well.
Posted: Jan 20, 2009 8:52 PM
by Brad D.
I'd say that's a good deal.
by Shadow
Is that a remote mount kit so you can use
a spin on?
Is the stock drop in not a good one?
Stock is fine
Posted: Jan 20, 2009 9:12 PM
by Jordanmilos
Big Bronze Rim,
Thanks for the kind words. I'm not looking to get rich off of these, just covering my expenses and time.
The stock one works just fine. I prefer spin on filters because they facilitate easier oil changes. This also adds the option for an oil cooler as well as the two ports which could run senders or feed lines for the guys out there who have turbos. I can throw in a small oil cooler into the deal if anyone wants one. I'll dig them up and snap some pics. Right now I can offer a complete system minus a couple of feet of hose and some fittings for under $200. Get yourself some senders and gauges and you can have gauges, a remote filter, and an oil cooler for under $300.
Posted: Jan 20, 2009 9:17 PM
by Scottinva
Um where do I put an application, I want one =D
Posted: Jan 20, 2009 9:47 PM
by Shadow
Cool.
What filter will you use?
Those big "racing" v8 ones would
be sick.
How much longer does it take to
get to operating temp with no thermostat?
Can the oil be overcooled with no thermostat?
thanks.
Will this work for the b35 block?
Posted: Jan 20, 2009 10:19 PM
by Jeremy
All stock oil and water thermostats are retained in his setup. The device bolts on where the canister normally goes using a similar method, and the oil thermostat is in the housing.
Posted: Jan 20, 2009 10:22 PM
by Jordanmilos
I was just about to mention the thermostat bit but Jeremy beat me to it. The oil filter used comes from Ford V8 engines. The most common one is the PH8A from Fram. The one I would recommend using is the Mobil M1-301. You can get them on Fleabay (item #330285359214 at $7 a piece with a minimum order of 6). Its where I get mine from and its half the price versus getting one from Advance Auto for $13. Most of the better filters are made by Champion Labs. This kit will not work on B35 engines, at least not yet. I can make a block off plate with just the fittings, similar to the kit Bruno used to sell on BMWe34.net. I entertained the idea of making this fit a B35 canister as well, I'll see where it goes but the other kit would be at least $15 cheaper.
Posted: Jan 20, 2009 10:34 PM
by Jeremy
Just occured to me: is there any issue with mounting on a oil cooler vs non-oil cooler equipped car? One bolts in from the top, the other bolts in from the bottom as I remember. Is it as simple as using a nut/bolt for non-cooler equipped cars and a proper length bolt for oil cooler filter heads?
You got it.
Posted: Jan 20, 2009 10:47 PM
by Jordanmilos
Yup, simple as that. I provide the copper washers and locknut. I can tell you that when the adapter is mounted, it adds 1.150 inches to the thickness from the lip of the mount. I suppose you coule always fit it and mark the original bolt to see what length you need.
Three kits ready to roll
Posted: Jan 21, 2009 9:59 PM
by Jordanmilos
I have three basic kits ready to go at $155. For these first three, I'll drill out the two extra ports any way you want them. I also have two sets of VDO pressure and temp sensors (NEW) for an extra $40 (below my cost). I can install these and give you a head start with gauges. I was also told by my powder coater that he'd be willing to coat them at $22.50 a piece, which is a pretty good deal compared to what he charges me for throttle bodies. I will make more if there is a demand for them, otherwise they'll become another demo part for visitors to stare at when they come through the shop :-)
Posted: Jan 21, 2009 11:26 PM
by George
Milos, any pictures of this thing mounted up on the block?
Posted: Jan 22, 2009 4:33 AM
by red535t
paul burke wrote:Image
Have been making these for a while, this is the one on Ken H's motor. I am going to make a billet spin on filter adapter that bolts in the stock location. It will have in/out ports and provisions for turbo oil, sending units etc. Will post pictures soon.
Paul
out of curiosty and part dumb Q, which of the two oil port's comes directly from the oil pump.
top or bottem??need to locate the turbo oil feed.
cheers marty
Posted: Jan 22, 2009 7:26 AM
by e30-m30_kid89
Would this adapter like this allow one to run an oil cooler on a B34? If so I may be interested. Just need to find somewhere to put it....
Re: Stock is fine
Posted: Jan 22, 2009 9:03 AM
by Jordanmilos
From my previous post.
I'll throw some pictures up over the weekend, time permitting.
filter
Posted: Jan 22, 2009 9:32 AM
by Bill in MN
I should have read further. I'm guessing this won't work with the 745 setup, correct?
Re: filter
Posted: Jan 22, 2009 10:03 AM
by Jordanmilos
Bill in MN wrote:I should have read further. I'm guessing this won't work with the 745 setup, correct?
I have a 745 mount and cooler, I will check to make sure. I don't see why it wouldn't as most of the canisters from the early M30's had the same dimensions.
Posted: Jan 22, 2009 6:32 PM
by e30-m30_kid89
My apologies, i must've missed that part.
Once i get my setup going and working well, i think this will be a great addition.
now just where to mount it.... between the intercooler, charge pipes and electric fan i'm literally running out of space in and around my engine bay... :shock:
B34/B35 adapter plates
Posted: Feb 12, 2009 5:12 PM
by Jordanmilos
I just finished up run of adapter plates similar to Bruno's design. A bit thinker (1.25in) makes it possible to add a feed line or senders. Pics up tomorrow for anyone still interested.
Posted: Feb 13, 2009 1:38 PM
by Jordanmilos
Here's one that just came out of the sandblaster. The finish came out rough on the cut edges, I was going full blast with the cutter. They will all probably be powdercoated black or red. Anyone still interested in these?
Posted: Feb 14, 2009 12:22 PM
by Badger
how much?
What size are the holes? 10an?
Posted: Feb 14, 2009 6:04 PM
by Jordanmilos
The holes were drilled 23/32 for a 1/2-14 NPT fitting. The hose side can be whatever you want so long as someone makes an adapter for it.
For the basic adapter block kit with fasteners, $85. The kit will cost $140 and will be a bolt on with no other parts needed except for the filter itself.
Remote Oil Filter adapter
Posted: Sep 20, 2012 10:30 PM
by rwpg
Jordanmilos
Are you still making the oil filter adapter plates that replace the canister and provide fittings for an Oil Cooler and Remote Filter?
The link to the finished items picture on page two no longer works, do you by any chance have a picture of the finished part that I can check out?
Thanks in advance
Re: Remote Oil Filter adapter
Posted: Sep 23, 2012 4:21 PM
by Rich Euro M5
rwpg wrote:Jordanmilos
Thanks in advance
Did you notice you're replying to a thread which is 3-1/2 years old?
:rotz:
Posted: Sep 23, 2012 4:57 PM
by Jeremy
The one I have is still for sale.
