blkbmw
Post by blkbmw »
Not much, its been sitting in the garage for the past 2 month, i think i'll take it out sometime next week and then do an oil change......
KillerPM
Post by KillerPM »
A better story is what I did to Ted's E28 last weekend..
Still waiting for those pictures.
Let me just say working on a Dirty Euro M30 has its additional challenges. Stupid oil cooler always getting in the way.
frink84
Post by frink84 »
put in a power front seat, matching passenger headrest (old one was from an e30), driver side door pull that wasnt broken, center vent w/ open/close feature, left rear US bumper covering. all thanks to mr. ronp!
Xenocide
Post by Xenocide »
Abused the fuel injectors again, trying to get the flyback circuit to work on megasquirt :evil:
Post by C.R. Krieger »
Rolled out at oh-dark-thirty to Badger Bimmers' OktoberFAST at Road America. Got snowed on. Got cold. Had a nice dinner with good friends. Went home.
Follow up, I did a pre- reinspection light check . 2 side marker lights were bad, so I replaced them. All other lights appear OK . BB Shiftless is gonna need SF bushings by spring.
'Twas a pint low in ATF, making it shift funny when cold. Aired up tires , but the swoopy rear end just gots to be SF bushings.
Paul in N FL
Post by Paul in N FL »
Looked at it in the driveway waiting to be towed to the shop in a day or two for a valve job, new water pump, and thrust and control arms, alongg with tie rod ends... :( :( :( :( :( :( :( :( :cry: :cry: :cry: :cry: :cry:
Went on a local BMW outing and meet today and discovered that my water pump gasket is toast.
Pissed.
Bimmerguy2002
Post by Bimmerguy2002 »
I adjusted my poor b35s valves to .010" and dumped a bunch of marvel mystery oil into the crankcase for no apparent reason.
Getting ready for the SoCal Vintage BMW Show in 2 weeks so I was busy both Saturday and Sunday:
1. Finished installing the new Fuel Injectors. Had only one left because one of the new ones had a bad O-ring (which is kind of ironic considering that was why I was replacing them in the first place). But I upgraded to the newer style with the 4 nozzles.
Here's a shot of the old set; all 6 looked this way. Kind of mucked up, huh? (Off to Cruzin' they go; anybody need a set of re-manufactured Injectors?)
2. Ignition and Vacuum Lines: New set of Ignition Wires from BMP and new Vacuum hoses (I like the blue accent). Also a general engine detailing and re-paint of the air box. There's still a bit of dirt in there, but a real wash detail comes next week.
fxe28
Post by fxe28 »
Spent about 8 hrs repairing the rusted out rear valance. Still not finished.
RVigre
Post by RVigre »
Installed new steering wheel. Spent about 2 hours washing and detailing. Then parked it in the shade for the rest of the day as its's still way hot here in Florida........I really ought to clean out my garage.....
bwenham
Post by bwenham »
drove my 528e to class and pondered installing the flip out screen dvd deck sitting in my closet. it would be nice to at least have a cd player...sigh.
duggi
Post by duggi »
Today, I put in a rear shelf with the built-in sunshade, replaced the oil pressure sender and put in a new fuse box lid =)
EZE84WIP
Post by EZE84WIP »
Finish a little bit of wet sanding so I can lay down a coat of clear on a few sections of the car & sand down the hood and apply another coat of paint.
Thinking about starting work on the rear end body work...ugh
Drove it to work.
alijonny
Post by alijonny »
looked at it. shed a tear. hopped in my 745i and drove it.
Post by slammin_e28 »
alijonny wrote:looked at it. shed a tear. hopped in my 745i and drove it.
Same here, but I hopped in the 330i and drove it. One day, I tell myself, one day I'll drive the e28 again.... :cry:
Brushed the snow off it this morning :evil: :evil: and drove it to work. Went home for lunch & answered the door for the UPS guy who had a package from Autohaus AZ containing a shiny new front wheel bearing for the 735 :banana: and some replacement intake boots/hoses for both cars.
Had the intake boot for the 735 sitting next to the same for the 528 and was amazed at the size difference! :shock:
Then I went out to the store where I'd earlier seen a set of large-size metric sockets for $55, and they were sold out. So tonight I get to do the drivearound again to see if I can buy or borrow a 46mm socket and breaker bar to get that wheel bearing nut off the seven. :roll: I have half a mind to just stop by the repair shop & ask them how much they'd charge to change it for me.
Drove it to the yard. Put a G265 in the trunk with shifter-console, bellhousing, inspection cover and the driveshaft. Drove it home. Parked it on the street.
Built a roofrack for it. Put my Alpinas on it and did burnouts to use up the old tyres that are on them. Drove it to the kebab van, drove it home and put it in the garage.
wkohler wrote:Drove it to the yard. Put a G265 in the trunk with shifter-console, bellhousing, inspection cover and the driveshaft. Drove it home. Parked it on the street.
Nice score.
Put about 65 miles on it driving it for work. This is the 528eA.
Xenocide
Post by Xenocide »
GOT MY MEGASQUIRT PROBLEMS FIGURED OUT!! :banana: :banana: :banana:
Now I gotta put it in and see if it works.
I think I finally figured out my screwy idle problem on the 528... Last night I replaced the cracked intake boot and the hoses from the intake to the idle control valve and to the valve cover, but it was still revving up & down between 1500 and 800. Gave the ICV one more good cleaning, shot some WD-40 in it and left it sit overnight, and it was much better this morning. Still not perfect though, so I may need to replace the ICV, but I'm closing in on it!
