FUBAR 528e, Gauging Condition of the M90
Tiit
Re: FUBAR 1/8 Trackday/This guy is using film in 2021?
Post by Tiit »
Haha. I love it. I’ve been thinking to do the same. I’d love to develop film as well.
It’s tricky getting colours right at night with street lighting.
LeiseyJr
Post by LeiseyJr »
Bonsaibacker
Post by Bonsaibacker »
LeiseyJr wrote: Jan 10, 2021 11:09 AM ImageADC439D8-0462-448F-ABAA-C71DB725D9F3 by Kurvenkamph Motorsport, on Flickr
Great picture.
LeiseyJr
Re: FUBAR 2/1 Manual Window and Cassette Player
Post by LeiseyJr »
LeiseyJr
Post by LeiseyJr »
LeiseyJr
Re: FUBAR 3/30 3 clutch diff
Post by LeiseyJr »
Built a 3 clutch diff, Thanks to Jay for convincing me to upgrade from the standard two clutch.
Built a Test Thing
Image154889896_1885673444942899_6464526083569885719_n by Kurvenkamph Motorsport, on Flickr
Only Tested at 30 ftlb breakaway
Image154696002_1885673778276199_9017332079924066283_n by Kurvenkamph Motorsport, on Flickr
That's why...
Image155096015_1885672258276351_2929441072857179836_n by Kurvenkamph Motorsport, on Flickr
Image153177964_1885673581609552_8742800546759403023_n by Kurvenkamph Motorsport, on Flickr
Image154368294_1885673638276213_805346527142916284_n by Kurvenkamph Motorsport, on Flickr
Install
Image155353133_1885673861609524_7667024914707516184_n by Kurvenkamph Motorsport, on Flickr
So car has been open diff'ing. Swapped a healthy S3.46 into dads car. Rebuilt his old diff with 250k on it. We thought it was healthier then it was. So I ordered 2 clutch packs from FCPEuro, and I had a S2.93 parts diff with super nice clutches. Used the best one for my 3rd clutch and its dogplate. Reused/flipped the dogplates and then reassembled. It has been one of the best things I have done to the car. Very happy with it, other then it is leaking a bit. Had the new sideseal orings, but didn't install them like an idiot. Luckily just weeping, no drops on the floor.
LeiseyJr
Re: FUBAR 3/30 Track Event and 3 clutch diff
Post by LeiseyJr »
Did a trackday with PCA was good to finally be back at a HPDE. Car did great, the new 3 clutch diff feels super good. The Toyo RA1s are also very nice.
Gave some modern porsche hell and the olders one too
https://www.youtube.com/watch?v=1xubxMAT1kk&t=127s
https://www.youtube.com/watch?v=41iCd5w5ZnI&t=106s
This weekend I went without the ghetto catchcan, so I had to leave it in 4th through the slow section of the track, good way to practice carrying momentum.
Really Proud of this pic:
Image163304416_1901017500075160_961744329600746453_n by Kurvenkamph Motorsport, on Flickr
Enjoy the rest of the pictures:
Image164354392_1900947220082188_4932338448861197918_n by Kurvenkamph Motorsport, on Flickr
Image163394913_1900946776748899_1262301007011750578_n by Kurvenkamph Motorsport, on Flickr
Image163565193_1900946630082247_4903217465442937509_n by Kurvenkamph Motorsport, on Flickr
Image163523735_1900251133485130_8299332742995561966_n by Kurvenkamph Motorsport, on Flickr
Image163571853_1900251070151803_7697238196982871714_n by Kurvenkamph Motorsport, on Flickr
Image163687755_1900251200151790_2934937549752637728_n by Kurvenkamph Motorsport, on Flickr
Great photos.
Was the diff upgrade as simple as remove and replace the clutch plates? And what's the biggest advantage you have seen-- you mention it as a great upgrade but don't say why...
LeiseyJr
Post by LeiseyJr »
tschultz wrote: Mar 30, 2021 2:48 PM Great photos.
Yes there’s a 4mm space you remove and add a clutch disc/dog ear in its spot. They do wear a bit uneven but it’s cheap and easy enough to do.
I have noticed a lot more rear grip on corner exit. I thought the car would slide more but that is not the case. Actually using traction of both rear tires on corner exit, and car overall feels more mannered. It just made it way easier to drive. When I try to drift the car now when it is wet also no random one tire fire, both tires stay locked all the time.
On a mostly street oriented car that has street tires, I don’t think the upgrade is necessary. Just fresh clutches should be more then enough.
Tiit
Post by Tiit »
Nice pics.
LeiseyJr
Post by LeiseyJr »
Made my own eprom today. Happy about that.
LeiseyJr
Re: FUBAR 5/3 Track Day Vids
Post by LeiseyJr »
Nothing much has changed. I installed a Euro ecu with a correctly adjusted AFM car likes it.
Had another track weekend. Had a lot of fun. It was raining Saturday and I was on really bad rear tires (heat cycled and low tread), so really interesting.
https://www.youtube.com/watch?v=Qthrko_S9aQ&t=62s
Sunday it dried out and had a lot of fun. I did miss a session because my key fell behind my grill, when adding oil. That took 30 minutes to figure out.
https://www.youtube.com/watch?v=TUpKNiL7TBU
https://www.youtube.com/watch?v=AcYoM2WY1p4
LeiseyJr
Re: FUBAR 5/3 Track Videos
Post by LeiseyJr »
Finally decided to trust my EPROM for a full track day day. Car did great ran all 70 laps without a real issue,
Only issue is the rear (shit reman driveshaft) u-joint is squeaking (was doing it before the track event) and y pipe fell off. Engine is still moving a bit too much.
Car has cost me a lot in consumables, which is killing me. Tires, brakes, etc.
Tire wear is Excellent, but they are dead so was a slidey weekend.
https://www.youtube.com/watch?v=IyQ3RBWjuUc
Lap with no traffic
https://www.youtube.com/watch?v=etqWM-wArFw
Chasing a Spec Miata
https://www.youtube.com/watch?v=RKcD2faYKKw
Good slide here at 2:00 min
Bonsaibacker
Re: FUBAR 6/8 Another Track Day
Great videos and pics. Subscribed.
Tiit
Post by Tiit »
What’s your current suspension setup? Is camber adjustable? Roll centre correction?
LeiseyJr
Post by LeiseyJr »
Tiit wrote: Jun 09, 2021 12:02 AM What’s your current suspension setup? Is camber adjustable? Roll centre correction?
https://www.mye28.com/viewtopic.php?t=150009
TLDR
Stock Geometry (no roll center correction, no eccentrics).
Camber Adjustable in the Front
Frankenstein Koni coilover setup
LeiseyJr
Post by LeiseyJr »
Bonsaibacker wrote: Jun 08, 2021 7:39 PM Great videos and pics. Subscribed.
Glad someone is enjoying it.
LeiseyJr
Re: FUBAR 6/22 Autocross! Brown Steering Wheel!
Post by LeiseyJr »
After last event, I broke the diff mount, and screwed up the rearmost U joint on the driveshaft.
Jay was kind enough to send me a new to me diff mount. Thanks Jay!
I cobbled together two driveshafts again.
ImageIMG_2208 by Kurvenkamph Motorsport, on Flickr
Car went on a roadtrip.
ImageIMG_2027 by Kurvenkamph Motorsport, on Flickr
ImageIMG_2033 by Kurvenkamph Motorsport, on Flickr
Car survived an auto-x. Really happy with how it did, competitive against an e30 with a s52.Hopefully next time with fresh tires and or a drivers mod, can match his time.
ImageIMG_2137 (1) by Kurvenkamph Motorsport, on Flickr
https://www.youtube.com/watch?v=awQta1Jkbwc
It now has a brown steering wheel!
ImageIMG_2202 by Kurvenkamph Motorsport, on Flickr
ImageIMG_2028 by Kurvenkamph Motorsport, on Flickr
LeiseyJr
Re: FUBAR 7/1 Dyno
Post by LeiseyJr »
ImageIMG_2458 (1) by Kurvenkamph Motorsport, on Flickr
My tune:https://www.youtube.com/watch?v=2TmRgFjM3SA
Stock 061: https://www.youtube.com/watch?v=VXCi0y_jaxA
Dyno'd!!!!!!!!!!!!
So I compared my chip tune to the stock euro tune. Those are the best of the 4 runs, two runs for each. Was pretty consistent, my tune more so.
+16 whp and +10ftlb for the peaks. The power under the curve is higher everywhere.
Assuming 15% drivetrain loss that is 230 crank hp with my tune and the stock euro ecu is 208 crank. A little upsetting to see it's less than 218 with stock DME but with 98 ambient the DME is probably pulling timing.
Torque Curve is healthy, but will need bigger valves to have less of a taper after 6000.
Tiit
Re: FUBAR 7/1 Euro M30 Dyno
Post by Tiit »
Solid gains. Are the gains in ignition timing?
LeiseyJr
Post by LeiseyJr »
Tiit wrote: Jul 02, 2021 5:12 AM Solid gains. Are the gains in ignition timing?
Yes ignition timing is everything. Mainly what your paying for in any tune is the ignition map.
BMW or BOSCH cut it pretty hard in that area on the stock euro DME looking at the .bin I have.
LeiseyJr
Post by LeiseyJr »
Update.
The camshaft begin to fail around October...? Tracked it in August and oil pressure light was coming on at idle. Glitter upon oil change.
TLDR changed oil pump and the whole cylinder head. Got oil temps too hot and valve spring pressures were too high and eating camshaft alive. Brand New schrick Lasted 2 years and 30k miles.
Car was down for awhile. 1-1.5 month? Someone gave me an e46 330i 6 speed for free. So daily'd that until I finally found a b35 camshaft. Cylinder head is now all stock components. B34 head with b35, cam valves and springs. But all stock stuff, rocker arms, no rocker locks etc.
It doesnt really feel down on power still feels quick.
Had a blast with it at TexFest.
Other than that car is pretty much the same. Still doing track events with it. Did two in November, and two this month.
Last event while trail breaking, LF strut housing failed. Tore the tube.
So that is now repaired and reinforced. Found a Koni was blown so that was replaced with my old Bilsteins.
So idk what I plan to do with car now. Still daily it sometimes, forcing myself to drive e46 more. Shell is cracking in a lot of places. Cowl is cracking, bulkhead is cracking, b pillars are cracking.
Pushing this old shell hard with probably 300k on it. Current plan is to keep band aiding it together and keep driving it.
https://www.youtube.com/watch?v=je4Jv0Q49IQ
School has been hectic. But still making progress there. Have a full time job at NOV and I moved out with my girlfriend.
Will probably follow this post with picture dump. Have to remember Flickr log in and all that. but for anyones curious, I still own it. Still being used, broken and repaired.
athayer187
Re: FUBAR 1/25/21 Tearing Metal from Grip, New Cylinder Head
Post by athayer187 »
Pics of the failed strut tube? Curious to see what failed and where.
My opinion - drive the crap out of it. You're having a great time, fixing what needs to be fixed, and likely embarrassing cars worth 10x or more what yours is. It may never win a beauty pageant, but it sounds like it still puts a smile on your face.
LeiseyJr wrote: Jan 25, 2022 2:52 PM School has been hectic. But still making progress there. Have a full time job at NOV and I moved out with my girlfriend.
Props to you! Learn me your ways on fun time management.
LeiseyJr
Post by LeiseyJr »
Still locked out of my Flickr. Update.
I had some major breakthroughs in terms of lap times. Finally got the car down to the 51s, it is just a 1:51.9 but still a 51. I got some Toyo RR takeoffs and a rabbit to follow this is what I needed to push just a bit more. Didn't get go pro footage of a full 52 before go pro died or the 51, but here is some of the 52 behind my friend Chris in his Z3M.
Here is footage tho:
https://www.youtube.com/watch?v=hOYxH2NZAvw
My goal is still a 1:49.9. I have talked to some drivers I really respect. There is still another second in driving and getting the perfect lap. No one knows where the other second will come from without adding lightness, grip or power. Maybe a set of sticker tires and a cold day?
I will keep pushing, the cracks in the chassis don't look like they are spreading yet. Once I can consistently get in the 51s, or 50s. I might consider another modification.
Engine seems to have survived the weekend?
I did make some tuning changes and seem to be keeping up with my friends e36 m3 a lot better. Also have a lot more low end torque for around town. So very happy with that. On the straights we were about even, I was also maybe in his draft. So could be illusion of that.
https://www.youtube.com/watch?v=3humPs_YU5Y
Other things that have happened:
car got rear ended, euro bumper got a bit mangled so cleaned up my spare set super happy with how it came out
brand new nissen radiator
Genuine 1982 E24 Recaros, I found a set getting one reupholstered right now for passenger. O bought them for instructor training school with PCA, wanted a set of matching seats that were easy to get in and out of. These seats are also somewhat sentimental, update to follow.
I post updates pretty frequently here:
https://www.instagram.com/sam.the.jam/
