:wave:
In the mean time...
Delivered my spare S38B36 to Steve in DFW for stuffing into his '86 535i chassis.
az533
Post by az533 »
I'm replacing the leaky timing cover gasket in my brother's 2012 Chevy Cruze 1.4 turbo. It's a surprisingly easy job, considering the fact that the timing chain has to come off in order to do it. Also easy thanks to the YouTube videos. Also fabulous: for $206, I got a replacement timing cover, and it came with a new thermostat, water pump, oil pump, and crankshaft seal, all pre-installed, direct from GM. Wow.
austin8753
Post by austin8753 »
repaired the broken parking brake console in my 2002 pickup yesterday. a very common weak point on the early chassis cars. when the car belonged to my mentor still, he (self admittedly), was not quite so kind to the old girl, and had ripped the parking brake console off its spot welds. he repaired it once, but the repair wasn't well done and failed.
BKbimmer came up with a solution for my particular situation and made a new, custom platform, out of a piece of 1/8" plate steel, with custom uprights for the handle to sit in, and welded it in last night.
i hope to be as talented as him, some day. thankful to have a good friend like that. shitty picture, but you get the idea. another mark checked off, on the very long list of things it needs.
RoyW
Replaced complete OEM exhaust system with SuperSprint on my e39 M5
Post by RoyW »
Looking for more HP & torque, plus a deeper exhaust note, I had the complete OEM exhaust system on my e39 M5 replaced with a SuperSprint system, from the headers to the mufflers. The SuperSprint is beautiful, with great welds, stainless steel, and quality construction and fitment. :D :cool: It also weighs a whole lot less than the OEM system! Unfortunately, the exhaust note is not much different than stock :shock: ... probably have to delete the resonators to get louder and throatier! Oh well, my neighbors will appreciate it anyway :laugh:
Today, she goes on the dyno for performance tuning & optimization... expecting a 40 to 50HP gain. We'll see?
-RoyW
ImageP4131431 by Roy Wicklund, on Flickr
ImageP4131430 by Roy Wicklund, on Flickr
ImageP4131429 by Roy Wicklund, on Flickr
ImageP4131428 by Roy Wicklund, on Flickr
ImageP4131427 by Roy Wicklund, on Flickr
ImageP4131426 by Roy Wicklund, on Flickr
ImageP4131425 by Roy Wicklund, on Flickr
ImageP4131421 by Roy Wicklund, on Flickr
e24mpwr
Post by e24mpwr »
That's really cool Roy - I've never seen anything quite like that transition from the headers to the exhaust (springs/etc.). Very interesting!
Not today, but a week or so ago... but who's counting.
Had the driver's side headlight go dark on the wife's Lexus. And yes, it has the adaptive HIDs. I asked around and was told that, judging by the faint flickering glow remaining, the most likely culprit was the ballast, which is about $250 worth of bad news. After mulling over my options for way too long, I finally placed an order for a fresh HID bulb and ballast from Rock Auto.
The bulb showed up the following Tuesday, and a second box showed up by my front door on Thursday, which was a day earlier than I was originally promised, but the ballast I had ordered wasn't inside; it was a harmonic balancer for a Northstar V8. WTH??? The accompanying paperwork showed that somebody had just messed up and shipped me the wrong part. Great. So that evening I went to their website, set up a return and had them send out a replacement. And on Friday afternoon I found another box by the front door, and inside is the ballast: Woot! I didn't have time to dive into replacing it that weekend, so set the stuff aside, and in my spare time reviewed what needed to happen to get the light working again.
Step one: Remove bumper cover. Seriously. The headlight assembly has three bolts/nuts holding it in place, and one of them can only be accessed by removing the bumper, or by removing most of the fasteners holding the bumper to that side and prying the plastic far enough away to get at the hidden nut. So dumb. The rest of the process is pretty simple.
But on Monday afternoon, I get home from work and found another box from Rock Auto on my front step; it contained a second HID ballast! Seems that the package with the Northstar harmonic balancer was a total fluke; the original HID ballast was sent out on time and arrived on Friday as originally promised. The replacement that was sent out in response to my return arrived on Monday. Oh for dumb...
I finally got around to the job on Tuesday evening, and first thing I found, after getting the bumper out of the way, was that there was an obvious issue with the bulb. I popped in the new bulb before unpacking the ballast to see if I'd get lucky, and the thing lit up. Woot! Got everything buttoned up, and got on the computer to see what I needed to do to return the TWO ballasts. And of course, Rock Auto's website is designed to make it easy to deal with what their web design team imagined was possible, but for those issues that don't exactly fall within their idea of possible, there doesn't appear to be any way to actually contact a real person to get help. So, I just packed the two up with a note explaining the situation. Pretty sure that was the toughest lighting issue I've dealt with. So far...
gadget73
Post by gadget73 »
Chevy Malibus require removal of the front bumper cover to change the halogen headlamp bulbs.
and yes Rockauto is very difficult to deal with for any non-standard issues. I've had issues getting things that were just a wrong cross-reference. Their site said it fit, the box was the item I bought, but in person it was very obviously not what it was supposed to be. Convincing them I didn't want to be sent two more struts or oil filters or whatever that were clearly not the right item was a hassle.
e28Sean
Post by e28Sean »
Not strictly speaking a car, but.... Wracked up my 300th mile on my e-bike today!
Not today, but recently. Replaced the Rack and Pinion on the Datsun, AKA Infiniti QX4. I'd made the mistake of not noticing a torn boot and on vacation last year on the way back I was greeted by the grrrwoowsrrggg sound of a low P/S pump. I've done a bunch of boxes, but this was my first R and P. This R and R at least was easier than I feared. Biggest problem was the brand new Chinesium part (much cheaper than a rebuilt unit) was close, but not quite the same as original. The lack of a centering marking and oddly bent hydraulic line cost me hours. Still, not too bad. And... it doesn't leak!
Then some E36 love. The car that nothing goes wrong with is becoming needier. NBD, just front brakes because the rotors were warped, not wear, but I had a siezed caliper too I had to rebuild. The dust boot was cranky, but eventually I persevered. What was weird was the break in instructions for the pads. Ceramic, as I've come to like, but break in was 30 stops from 30-5 MPH. 30 friggin' stops? I made it to about 20 before I lost patience, so please guys, don't rat on me if I need to warranty them. :roll: I was surprised though, around stop 10 or 12 I noticed a significant difference in initial bite.
gadget73
Post by gadget73 »
bought an ozone generator and stuck in the Towncar to try to get rid of the rodent pee smell that I haven't been able to eliminate. Seems to have helped but now it has a vaguely metallic smell. Better than the ammonia stink of mouse pee though. Have to put it out in the sun and let it cook a while to see if the stink comes back.
gwb72tii
Post by gwb72tii »
short story:
I wound up leasing an Audi A5 Sportback for a variety of reasons, mostly family related, and I my lease is over July 9th. The e28 I'm restoring is going to be my new DD, but it's not going to be ready until October, I hope. Between these dates I'm driving my 2002tii which I restored some years back, but haven't driven much for the past few years.
On my way to the body shop repainting Maeve, my friend was following me and let me know my brake lights were out. Checked the fuses, all were ok. So it must be the brake light switch. I took it out today and sure enough, no workie. I new one will be here Friday from Amazon. Easy fix.
My friend and I were talking about it, and we are both old enough to remember when fixing your car was common, shit like the brake light switch used to need attention all the time. Adjusting brake shoes, adjusting the timing, checking valve clearances etc. Back when my 1972 2002tii was a fairly new car.
Today if you had to do anything to your car, like my A5, you'd be disappointed (mad) with your car.
Man how times have changed.
Did one additional thing on the tii. My wife and I drove to the Vintage at the Vineyards in 2010, all the way from Seattle and back. I still had the Toyo tires on my tii from that trip and they're dried out, so I bought new Pirelli Cinturato tires that look like they came with the car. baby has new shoes!
on the trip
and if anyone can tell me who is standing next to my wife you get a bonus point!
Blunt himself, Stevie boy. 😘
gwb72tii
Post by gwb72tii »
one bonus point for you!
gwb72tii wrote: Jun 07, 2022 12:33 AM one bonus point for you!
Was 2010 the Shelton Vineyard year,
where all the 02s were parked up on the hill?
Reason I ask, I recall, as I was taking the 02 tour through that maze on the hill, talking to a couple who had driven thru from Washington state to the event, and IIRC, w/o working a/c, as wifey and I had driven our Das Biest over from Tejas w/o working a/c, and it was rather warm.
gwb72tii
Post by gwb72tii »
I don't think so. The entire 2002 fleet was parked on the grass, mostly level. We did win the prize for longest travel to and from the Vintage.
There were however 4 e30's parked on the hillside that reflected in the lake. One was a bright metallic Colorado color that, IMHO, was pretty much the perfect color.
*"long sloping flat slight rise in elevation hillside" better describes it.
It was some 02 anniversary meet, again, IIRC.
Must have been ~ 150 02s.
They covered the whole hillside.
Is that the only one you attended?
gwb72tii
Post by gwb72tii »
It is in fact the only one. Just a long way to go in my tii, especially with a lowered suspension and sport shox.
I installed a 5spd tranny for the trip to cut down on noise and vibration. Even so when we were done driving for the day, we'd rock like we just got off a boat.
We were stopped entering the Badlands on the way back due to road construction, waiting for a lead truck. I was first in line talking to the flag lady when it was time to go. The lady asked how the car was running (perfect so far) and Cindy said "fine if it starts". I just looked at her and asked why would she jinx the car? Guess what, car would not start for about 30 seconds until I just floored it. You never say stuff like that about your car! I later opened up the fuel tank, with a turkey baster, and sucked some rust flakes out of where the fuel pick up resides.
Once Maeve is up and running going back is an option.
gwb72tii wrote: Jun 07, 2022 3:55 PM It is in fact the only one. Just a long way to go in my tii, especially with a lowered suspension and sport shox.
Had to of been you then.
Those Vineyard settings were much preferred over the current Hot Springs venue, with the exception of our E28 Hooters who hang out in HS all weekend.
Looking forward to meeting Maeve.
TexFest might just be a bit closer, and it's in October.
gwb72tii
Post by gwb72tii »
October might be a push, but looking forward to Maeve being up an running
tseohs
Post by tseohs »
Porsche used paper-thin leather to cover 911 shift knobs. That, combined with the small size and shape of the knob means that drivers likely grip tighter which leads to them wearing. Mine was peeling and the sharp edges of the plastic knob made shifting less than a pleasure. I couldn't find a reasonable replacement or someone to recover, so I gave it go.
I sourced very thin leather, not as thin as the original, and I think it was lamb. First I was trying to do it in 2 pieces like the original which required sewing 2 seams and getting them to line up just right so the inner seams could be tucked into the 2 channels in the knob. After cutting some test pieces and trying to come up with a plan, I scrapped that approach.
Instead, I cut a single piece roughly in the shape of a curved funnel that was wide enough to span the circumference of the knob. I then mounted the knob on a long bolt through a board so it was immobile and fully accessible. Next I tucked and glued one edge of the leather into the channel. After it dried completely I clamped that glued section with ~3 small welding clamps, applied glue to about the next 5mm of the knob, stretched the leather as much as I could and clamped that section.
I really couldn't tell if it was doing what I wanted until it was like 1/2 way around when I could see that the leather was getting tight enough to follow and snug to the taper below the ball of the knob. After about 20 more rounds of stretching and gluing, the seams met and I was able to carefully cut, tuck, and glue the end into the same channel. I then laid a simple cross-stitch over the seam. Last step was to trim the top down to ~2mm so it would tuck but not be too bulky under the cap.
What you see was done with no water or heat to shrink the leather. The result is a very comfortable slightly cushioned knob that provides for a no-slip grip. It has really transformed the driving experience.
tseohs wrote: Jul 01, 2022 6:14 PM
Not a fan of the white, which for all I know is original, and in my paws it wouldn't stay white very long, but other than that, I like, I like it a lot! :up: Nice work.
That's seriously impressive.
For my '88 with Linen interior, I used a leather recoloring kit with pretty good results:
I also re-did my steering wheel
Chased down a vacuum leak on the e39. How did I make it so many years without a smoke machine?
Lower intake boot.
John in VA
Post by John in VA »
Karl Grau wrote: Jul 23, 2022 8:43 PMHow did I make it so many years without a smoke machine?
Which unit are you using?
John in VA wrote: Jul 23, 2022 9:00 PMWhich unit are you using?
From Amazon and it looks like it's gone up $20. https://www.amazon.com/gp/product/B07JV ... =UTF8&th=1
It appears to have been assembled from off the shelf parts that probably cost less than $50 but I didn't mind paying $100 for someone else to source the parts, assemble it and ship it to me.
