Page 12 of 17
Re: And so it starts, Maeve
Posted: May 26, 2023 2:39 PM
:wave:
gwb72tii wrote: May 26, 2023 2:28 PM Image
:wrenchtime:
Posted: May 30, 2023 1:55 PM
by camplo
Blue Shadow wrote: May 24, 2023 7:12 PM As John stated, the relay socket allowed the connector female spade to back out over the multiple changes of the relay. It made limited contact and powered the car until it lost connection. Car rolling along just fine, tach drops to zero and we roll to the side of the road. Touch stuff under the hood and it starts back up until it didn't.
Must have been a low current connection as the touching connection would not have supported the full power through the relay.
Maybe check the OBC relay under the dash? Have seen similar posts recently and this seems to be a common relay that goes bad.
Posted: May 30, 2023 3:38 PM
by Mdreamer
Whew! Those babies certainly are sexy!
Posted: Jun 03, 2023 11:17 PM
by gwb72tii
I drove Medford yesterday, and home today. Passing “the scene of the crime” coming north out of Grants Pass, I started thinking about possible issues with Maeve and why she’d quit running when given tooI much throttle. So here’s a couple follow up questions, and they may make no sense given my limited knowledge of e28’:
1. Is there such a thing as a throttle position sensor that craps out if you press the throttle too far? It allows the car to run like grandma is driving it, but the defect cuts off fuel supply if you gun it.
2. If the car was sitting flat, it would restart after dying. But parked on the side of the road going uphill out of Grants Pass it would not restart. Later, after getting flat towed to Roseburg, the car started right up after being rolled off the flat bed tow truck at the local o’reilly’s. If it were just a defective TPS it shouldn’t matter if it’s flat or at an angle.
Posted: Jun 04, 2023 1:07 AM
gwb72tii wrote: Jun 03, 2023 11:17 PM
No. On a manual car the TPS sees idle, where it will not allow speed over ~1300 RPM before it cuts fuel supply, only to start after it goes below to cause an endless cycle of up/down. But not dying. And in the middle where it does nothing, and wide open throttle, which is really more like ~3/4 throttle, where it goes to an open loop fuel map, ignores the O2 input and enriches things. But those 3 states, idle, no input, WOT.
Was it gradual or on/off. If gradual, it points towards fuel supply. If it just shut off, it points towards towards electronics. On my 535 several times it just shut off driving. Coasted to the side, after a deep breath I turned the key and it started up like nothing ever happened. 10s of thousands of miles later other things started to appear occasionally, including an idle that was just ever so slightly off. Problem was the AFM. Based on your symptoms I'd also suspect the speed sensor. At the least ohm both sensors out, wiggling the end as you're doing it and compare to spec. The speed and reference (and the reference is only used on starting) can be flaky and intermittent.
Almost forgot, there is the big transistor in the ECU that is prone to cracked solder joints. That's a very real possibility. Search on it a bit.
Posted: Jul 09, 2023 7:13 PM
by gwb72tii
I'm back after a long absence due to shoulder surgery, and my wife's project making it to the top of the list. This is what I've been busy working on in place of Maeve. Deer around here are pests. Cute and destructive to plants, so the need for a fenced in garden area. I'm almost finished with her project, and then back to Maeve.
Posted: Jul 09, 2023 7:21 PM
by gwb72tii
starting back in on the HVAC system. New parts etc, and probably the AC Solutions Sanden kit too. But here is where I get stumped, finding a list/diagram showing all the parts in the HVAC system. Real OEM helps, but when you get down to O-rings and small parts, real OEM is not always helpful.
I'm trying to spec thesis three o-rings that are part of the expansion valve installation. Any here with a list or hyperlink?
Posted: Jul 21, 2023 11:58 AM
by gwb72tii
starting to make progress again.
I have to say, with all the discussion about whose seat covers to use (GAHH, zoom zoom, etc) I am happy with zoomzoom off of eBay. I emailed Steven about headrest covers, and he suggested I mail him the headrests and he would make the covers and install them. Mail them there, he mails them back, and this is what I received in the mail yesterday, front and back that came with the car.
not perfect, but plenty nice for a daily driver. I'm starting on the sport seats this weekend after I got an estimate of $2000 for a local shop to install the new seat covers. Seemed a little high.
Posted: Jul 21, 2023 12:51 PM
by Blue Shadow
gwb72tii wrote: Jul 21, 2023 11:58 AM I got an estimate of $2000 for a local shop to install the new seat covers. Seemed a little high.
I don't know prices for this work. I do recall decades ago the San Diego area had new leather installed in an M5 or something for maybe 1500 but included the rear seats. Believe there was some cross-border connection to keep the price low. Maybe your quote is close to the new price, especially in the more expensive places to live in the US.
Posted: Jul 21, 2023 1:35 PM
by gwb72tii
alas I think you're correct, shadow man
Posted: Jul 30, 2023 8:44 PM
by gwb72tii
Finally, back at it.
Started reassembly of my AC box, with a new evaporator and expansion valve, complete with new o-rings (thanks Mike W).
new o-rings assembled with Nylog Blue
old o-rings cross sections weren't "O" shaped any longer
removing this clip is harder than it could be, but necessary
re-insulated the pipe coming out of the expansion valve
with this
amazing how fragile the cooling vanes on the evaporator are. I spent about 20 minutes with a small flat head screw driver straightening them.
most of you know all this stuff but I'm adding pics and descriptions for future noobs to the e28 like me
Posted: Aug 20, 2023 8:09 PM
by gwb72tii
Good news, bad news.
Good news is my wife's garden shed is almost done.
Bad news is it's not done, and for some reason my wife believes her shed takes precedence over working on Maeve. Go figure!
But I did get a couple things done later this afternoon.
First, I reinstalled the trunk lid cover and tool box. Maeve came with a complete set of tools!
Then I removed the left rear wheel to get a better look at the brakes and suspension bits. Look what I found:
Not one, but two spacers
Together they measured 0.244" thick, or 6.2mm. I will be the first to admit confusion here. My wheel is 8x16 et15 (I thought it was et20), which effectively adjusts the offset to ET8.8! On the drive north from Mesa, AZ I never noticed any rubbing, and the tire shows nothing either.
Here is the right rear side, with a 10mm spacer adjusting the wheel to et23! My car should have looked a little off center for those that followed me on I5 north.
I have been curious about the shocks and HR springs on Maeve. Turns out the shocks are Bilstein sport shocks, which is good. The H&R springs are spec'd to an e28 also so looks like I'm good to go if the shocks are good. My problem is unknown mileage on the springs and shocks. Kohler mentioned some time back that H&R hasn't made black springs for some time.
Posted: Sep 23, 2023 2:48 PM
by gwb72tii
This came in the mail yesterday, from reyno in Latvia. Maeve came with the same Mtech 1 wheel but after years in the AZ sun it is dried out and the sewing threads are coming undone. Sils (reyno) does really nice work and I could not be happier.
Posted: Sep 23, 2023 6:55 PM
by John in VA
Looks great - thanks for not adding a boy racer stripe at 12:00 to it!
Posted: Sep 26, 2023 4:18 PM
by szacsi72
John in VA wrote: Sep 23, 2023 6:55 PM Looks great - thanks for not adding a boy racer stripe at 12:00 to it!
I feel attacked! :)
Good job gwb. Happy to see some progress!
Posted: Sep 27, 2023 12:59 AM
by Mdreamer
Looks great! Thank you for keeping us updated. I am anxiously waiting to see her when you finish.
Posted: Sep 27, 2023 9:56 AM
by gwb72tii
Yes, thanks. Up here in the great Pacific Northwest we’ve had an epic summer with 80* days and I think only two days of light rain. Until now.
As the saying goes, someone threw the switch from summer to fall, and now the high temps are in the low 60’s and it’s been raining for the past week. My wife’s garden shed was number 1, and frankly playing golf sounded better than working in the garage. So the motivation has been lacking somewhat. But the MM motor should be here in January so the push is on now to get the car ready.
Posted: Oct 03, 2023 7:54 PM
by gwb72tii
Starting the reupholstery of my front and rear seats.
35 year old rear seat. Actually in pretty good shape other than faded and a little discolored.
Here you can see the difference between a newly recovered headrest and the seat:
Bending up the sharp pointed ears that hold the leather skin in place:
Here you can see the dried out horsehair pad. I'm going to need to replace it with either foam or rubberized horsehair:
And here you can see some of the dust from disintegrating old dried out horsehair:
Posted: Oct 03, 2023 11:05 PM
by Mdreamer
Is mixing original horsehair and foam or rubberized horsehair an option? I ask because I've read that the original stuff has a smell and feel that new padding can never offer.
All, is there any truth to the latter?
Posted: Oct 04, 2023 9:14 AM
by John in VA
Years ago, in my 2002, I added a layer of carpet to the bottom of the horsehair seat pad to help keep it from being destroyed by the springs. With the cost of the gummihaar pads many have resorted to multiple layers & densities of foam sculpted & glued together to fill out the seat cover but the formed pads do the best job.
Posted: Oct 04, 2023 9:59 AM
by topher800
Mdreamer wrote: Oct 03, 2023 11:05 PM I ask because I've read that the original stuff has a smell and feel that new padding can never offer.
I feel there is truth. I re upholstered the front seats and the smell has never been as intense as it once was. I've always thought it was the loss of the horse hair padding. Maybe I'll get some horse hair from etsy and put it under the seats. I just tried a goodle search and came up with this, but the link is broken:
finkbuilt.com
› blog › bmw-2002-seat-covers
January 29, 2006 - I’ts a very complex, sort of musty but not unpleasant aroma, somewhat organic and entirely automotive. You smell it when you first get into an old VW, Mercedes or BMW, most noticeably on a warm day after the windows have been rolled up for a while. One of the primary contributors to that distinctive smell, is the horsehair padding that was used in the seat cushions in these old cars...
Posted: Oct 05, 2023 4:29 PM
by gwb72tii
Thanks to my friends over at bmw2002faq.com for the thread on reupholstering seats.
I've ordered 2 rolls of the 2x24x72 so I can do both the bottom and seat back rear seats.
https://www.onlinefabricstore.com/produ ... =affiliate
plus natural burlap to lay down over the springs to limit damage to the pad:
https://www.onlinefabricstore.com/natur ... abric-.htm
https://www.bmw2002faq.com/forums/topic ... -hair-pad/
Posted: Oct 05, 2023 8:52 PM
by gwb72tii
I continue to run across surprising things when working on Maeve. From common things like dried out rubber bits, missing fasteners etc.
And then things like this:
I'm starting to get everything disassembled in the engine bay so I can remove the motor/tranny in a few weeks. Took off the air cleaner/air flow sensor only to find the bottom open to the atmosphere. I'm pretty sure it should have a cover, no?
Please advise.
Posted: Oct 05, 2023 9:02 PM
by gwb72tii
I'm also realizing that I have a LOT of work to do before Maeve is on the road. Much more than just swapping motors.
I'm not someone to do something half way, so when the motor is out it's time to replace the firewall shielding with something else. Multiplied by 10 with other areas of the car and my goal is to have my car on the road sometime in late spring. I still have a day job so my time is limited to a degree.
ugh...
I will get her completed and drive her for a long time. But after Maeve, my 2002tii is going to be completely disassembled and repainted after I mashed in her passenger side. Smaller car, I know everything about the car, no computers etc. Straightforward. But a lot of work too. So my spare time is pretty much spoken for over the next three years. I'm going to be 70 this January and will move to other things in life when I turn 73, so with a little perserverence both my cars will be ready by then.
Then I'm going to buy my dream car, a Citroen 2CV
Posted: Oct 05, 2023 9:24 PM
by Galahad
gwb72tii wrote: Oct 05, 2023 8:52 PM I continue to run across surprising things when working on Maeve. From common things like dried out rubber bits, missing fasteners etc.
Please advise.
Yeah there's supposed to be a cover. Normally it's glued on at factory, but you need to take it off to adjust the wiper if the track is wearing
