harrypalmer wrote: Oct 12, 2020 11:26 PM
Hi Andy,
Your signature mentions E28 front solutions, what’s this all about?
I’ve got Euro front headlights installed in my car, but the wiring is a US version, and would like to have access to a correct setup that takes into account all the wattage from Euros H1H4 bulbs, fog lamps, turn signals and side markers.
So have you got a solution for this? Or have you ever considered coming up and marketing a true Euro harness with correct upgraded gauge wiring and full relay setup? I’d be interested in a plug and play just like you did with the rear, if you offer a solution. Thanks and good luck!
Jack
Hey Jack, the 'Front Solutions' I used to offer included several items that have been discontinued... I guess I will revise my sig; this included:
>High Performance high and low beam H1 headlights - the lows are discontinued, NLA.
>High Performance H1 lamps, 2x brighter, same watts - the supplier closed their doors.
>38 mil headlight protection film - discontinued, NLA.
Some things I still have - few HO H1 lamps... thinner (12 mil) headlight film... H4 male connector - mates with US headlight harness connectors. Plus HO front turn signal lamps, single and dual filament, and plenty of rear lighting parts, HO Lamps, and upgrades.
I do in fact have a relay modification kit to make the Euro headlights work correctly. Your E28 already has relays for both high and low beams and for fog lights, so that part is fine -- as long as you don't install extreme high wattage lamps! The weak link is normally the connectors, and I have replacement terminals to bring them back to new. BMW normally crimps them; I solder and crimp, so a better flow of electrons is guaranteed. The wires are plenty beefy, as long as they are intact. Or we can run heavier wiring, if you really need it (or want it).
The relay modification turns the lows into full time lights, highs on or off doesn't matter. Euro lights never operate highs in the outer lamps anyway, US lights do. That's why US cars turn OFF the lows with the highs, to keep from overheating and burning out the H4 lamps.
Let me know how you'd like to proceed - DIY, at your usual shop, or here. You'll need to budget around 60-90 minutes for the job, unless you want more... believe me, I can talk for days about ways to increase light output.
By the way, how are your rear lighting upgrades - still working well? I have a note that you have my +4 kit with relays and working rear fog lights in an 86 535i... and were in Florida at the time of the upgrade. Now it seems you are in Denver. It's a short drive to Golden, Jack. You might want to upgrade to an Octopus... for even brighter lights! Besides, I'd like to see that rear fog light switch you installed, and how that all works with the lights.
Andy
