Thanks David! I appreciate you offering that panel to me. Will help to make this that much better.
So, most of the stuff I've been doing lately has involved making sure all the wiring I need is where it is inside the car. As I've said before this car once had a big stereo and an alarm, so now that all of that wiring has been removed and no one ever responded to my request for some non-premium sound wiring, I had to take matters into my own hands and went to the yard.
I came back with remnants of stereo wiring from a few cars, none of them E28s as our yards had exactly one E28 and being a super eta with premium sound, it will not work for me. I did get the antenna wiring from this car though.
So, I ended up pulling the harnesses out of an E30 and all the wires are the same as E28. It was a little screwed up from douche-nozzles destroying the dashboard, but with cheating off the 533, I got it figured out without much issue. Fortunately, the rear speaker harness was complete in my car, so I got everything working and can put that all where it needs to go, then put the interior back together.
With that sorted, I decided to spend a bit of time on the front of the car. The valance had a bit of overspray on it from the chip guard, so before I did anything with it, I said, "This is Mike's problem" and drove out to Mesa. He took care of it no problem. little thinner, some wet sanding and buffing. Came back home and bolted it up. Forgot my phone had a camera so no photos.
Then I put the bumper together last night. Disappointed that the right front corner has a couple marks in it and my new bumper trim has a bunch of sharp indentations/impressions in it, but I can't afford to keep buying stuff I've already bought.
Still forgot photos. I started getting antsy. I decided to call the dealer this morning and buy the ten expanding nuts to put my lights in the valance. They've used them on every car since these were made, so they have to stock them and stock them they did. At $.36 each, I decided you can never have too many, so I bought 16. Not sure how I arrived at that number, but it was more than 10 and less than I needed to do two cars, so seems about right.
Three years ago, I bought brand new turn signals and grilles. Never looked at them. Found out a few weeks back that whoever "built" the assemblies was a moron and put E23/E24 plugs on them.
The yellow connector is correct.
I had some pigtails from the signals that I used on my 535is. I searched everywhere for a tool to take them apart, but I didn't want to pay $60. Then I looked at the wiring on the car and I noticed the Federalized running light was actually done nicely with heatshrink, etc and runs off of the city light circuit, so it can't be that bad to keep it. My housings were nice, too, so I cleaned them up and just used the new lenses. This meant removing them from the 528i, replacing those with another okay set I had and moving on. Fogs installed and time for a photo.
Then I said, "I can't just leave it there, so I need to put my lights in."
I had bought some lamps from Ivo. I didn't like the French high beams for this car, but wanted them for something else. I dipped into my newly delivered set of lamps from Schmiedmann and replaced the high beams. Twice. I installed them upside down only to find the spring wouldn't connect. So, I did it over. Replaced the bulbs and installed the wiper motors, etc.
Then I figured we need grilles. So, I grabbed those grilles I bought a few years ago and put them in.
Then I looked at it harder and said, let's put those wipers on.
I also decided that the photo would look stupid without the roundel, so I set one on the hood.
The anchors for the screws for the spoiler survived removal, but only three came back from the shop. I went searching for a suitable option, but every "expanding nut" was square. I had round holes and learned at an early age that it doesn't work.
I bought something out of boredom, but no worky. I decided on the way home that if this doesn't work, Machine screws, fender washers and nuts were the solution. Precisely what I did using metric stainless stuff, but I kept the nuts zinc plated.
And here's the spoiler.
After that, I grabbed my real camera, pushed the car out and took a few photos of the progress so far.
I've got the tow hook extension, but it's in Georgia right now. It was in two pieces, so I offered it for duplication, and it should be repaired and I should be getting one of the duplicates if I understood the arrangement correctly.
Then, I got an idea.
That's all for now.
