Page 130 of 178
Posted: Nov 18, 2014 7:31 AM
by MicahO
Sadly, winter is upon us in the Great Industrial Northeast. The e28 was filled with fresh gas, treated with Sta-Bil, driven vigorously for about half an hour, and then parked deep in the garage so I can get the tractor/snowblower out the door.
The winter project list for the e28 is pretty short. The Touring will get most of the season's attention, so that one stays more accessible this year.
Posted: Nov 19, 2014 1:52 AM
by dland
Put new rotors and pads on my new (to me) IS. Thought the UCAs were shot from shimmy while braking but glad to discover they're good, it was just the canyon that had developed on the passenger side rotor. Next, motor and trans mounts and guibo...
Posted: Nov 20, 2014 7:05 PM
by dsmith
Ready for Snowmagedon 2!
Posted: Nov 21, 2014 3:35 PM
by Stevo12
Fixed the ignition wiring at lunch - the wire going to the column came out when I had the panel off last night
Also, I just searched my car's build sheet on BMWArchive, and found that the build date on the car is just ONE DAY shy of exactly 9 mos. before I was born. Creepy
Posted: Nov 22, 2014 11:36 PM
Installed my rear strut brace/towing reinforcement (PITA, though it wouldn't have been with stock parts or if I had done it when I put the rest of the suspension in). Then I decided to remove the window tint. Wow. Not much fun (two layers) It is nice to see out the rear window though.
Posted: Nov 23, 2014 5:24 AM
by bkbimmer
Bought scores of new parts from the dealer.
Posted: Nov 23, 2014 11:17 AM
by EvanJacob
Installed mwrench steering reinforcement and euro headlights.
Posted: Dec 13, 2014 11:00 PM
by DanOKC
deleted same msg
Posted: Dec 13, 2014 11:06 PM
by DanOKC
deleted same msg
Posted: Dec 13, 2014 11:09 PM
by DanOKC
Installed new water pump & thermostat, P.S. Belt & Alt Belt & new water pump bypass hose. I noticed since cold weather it was running a bit cold from temp gooahj, and since the heater valve leaking problem finally got fixed, the water pump barely leaking became more evident. My first M30 water pump replacement. Looked easy, was easy. My only slow downs were the stock size AC belt that's hard as hell to get on or off. and then I had a rag covering the front engine hook bracket that has 2 bolts. Didn't notice that as I was putting things back together, just got the fan back on & moved the rag & said Oh crap.
Slowed me down a bit more, to loosen the alternator & remove the fan & pulley to get the bracket & 2 bolts on, but I give myself a break every now & then.
Posted: Dec 14, 2014 9:23 PM
by JSmoove
I removed the brake booster and got it ready for shipping to be rebuilt. I really do hate removing things with hardline fittings.
Started with this...
... then this happened.
Then, a couple hours later after Alex was on his way with his M30...
... Sammy got his...
... and I got yard art + ca$h.
Posted: Dec 14, 2014 10:10 PM
by LeiseyJr
Joined the M30 club
http://youtu.be/2A-ZSam0Sz0
Thanks Sherman for the wonderful donor car.
Posted: Dec 15, 2014 12:28 AM
by geordi
Posted: Dec 15, 2014 9:07 AM
by Stevo12
Pulled the rest of the automatic wiring out, including the OBC relay module, which rendered the car inop. Plugged it back in and one of the legs burned up in the box, so I just did a bypass. I also taped up some loose connectors in behind the radio, which I thought may have been contributing to the blown-sounding drivers left speaker (it wasn't). So I'll just throw one of the speakers from the parts car in to see if that solves it. I need to replace the drivers rear speaker too which is inop. Oh, and in diagnosing my no-start this weekend, I killed the battery, I had to give that a good charge yesterday as well.
Nevertheless, it was back on the road to work this morning, so in all it was a good weekend.
Posted: Dec 18, 2014 8:15 PM
by JSmoove
Removed the dreaded cracked to shit pedal bracket.
Posted: Dec 20, 2014 7:58 PM
by dsmith
Redid my muffler to cat connection. Flanges weren't lining up and leaked big time. I cut them off, welded on connector pipe to the muffler and clamped the cat side. Fart free now! Me? Not so much.
Posted: Dec 20, 2014 9:05 PM
by dhdrums
Went to the top of my driveway to start mine. Tried to turn it over and clunk, everything went dark. Had to get a ride to work. Came home and pulled the battery to have it tested. Tested fine. So brought it home, cleaned the posts, put the battery back in, hand tightened the connections, and it started like nothing happened. Then after driving around, I brought it home and tightened the cables back to the post. Pop...
The connector cracked. So I guess Ill be replacing that next.
Moral of the story, clean the post before going to all the trouble I did haha.
Posted: Dec 20, 2014 9:19 PM
by Kyle in NO
Whatever connection you show to the positive terminal is highly suspect and should be replaced in its entirety ASAP. It even looks like there is another connection to the right wrapped with electrical tape.
Posted: Dec 20, 2014 9:40 PM
by dhdrums
Yeah thats the work of the previous owner. He said that he added this...
to the original connector because it wouldn't fit a normal battery, instead only fitting a BMW specific battery? I'd never heard that. So does the original connector fit a BMW specific battery or does it fit a normal auto battery? I've been fixing the hacks as they've presented themselves, such as the radiator hack that recently came up, where the top plastic hose port on the radiator had apparently cracked off, so three pieces of pipe were epoxied one to the radiator, one inside that hose, and one to connect those to together.
Posted: Dec 20, 2014 10:45 PM
by davintosh
^^^ Yikes. Tell me you replaced that radiator. Good luck with the electrical stuff; that PO sounds like a genius.
I spent the better part of the last couple of days tidying up a number of things on the 528e; the big project was replacing the crappy old KYB strut inserts on the front of the car. The one on the right had blown out and was to the point where it would bang & thump every time you hit a bump. The new Billies are sooooooo niiiiiiiiice and smooooooooooth....
Posted: Dec 20, 2014 11:30 PM
by dhdrums
Thanks and yeah the PO was but he was really nice when it came down to buying the car from him, just had and liked e30's more. I replaced the radiator with a perfectly good one out of an '84 533i parts car for $20.00! It sucks seeing those cars abandoned to the point of disrepair but its awesome to be able to take a couple things off of them and give them new life in the next e28.
Posted: Dec 21, 2014 2:04 AM
by Kyle in NO
The reason the battery terminal "extension" was added is because the wrong battery is installed. The posts are reversed. To get the posts on the "correct" sides he flipped the battery around 180 degrees. Now, the posts are too far away for the original cables to reach, so he "modified" the positive side with that nonsense. Find a proper battery, install it the right way, and throw that junk in the garbage.
Note: if you don't, that positive terminal will ground out on that frame rail as soon as that tape wears through and probably burn the car to the ground.
Posted: Dec 21, 2014 10:41 AM
Once that happens, a C101 rebuild is imperative.
Stock battery is a group 47, but a 48 and 91 work just as well.
Posted: Dec 21, 2014 4:00 PM
by vinceg101
Had this guy out yesterday afternoon to the hangar:
I was a little concerned about the diffused cloud cover, but I think it will work out (as opposed to the harsh, crystal blue skies of last week). It was a better neutral for the Arktisblau.
Posted: Dec 21, 2014 4:03 PM
by MicahO
Perfect lighting. Can't wait to see those pictures show up in Eye Candy!
Posted: Dec 21, 2014 6:10 PM
by OcCoupe
Replaced the o-ring and the gasket to the oil return down pipe. Hopefully this will solve the oil leak. After that no more leaks I hope!
Posted: Dec 21, 2014 6:15 PM
by Federico
Posted: Dec 21, 2014 6:17 PM
by OcCoupe
Wut?
Posted: Dec 21, 2014 7:13 PM
by DanOKC
Towel in oil pan, nice find.
All I did was go to dollar store to get another cheap turkey baster to remove fluid from PS oil carrier, so I could replace the 2 small lines that exit that back side. Then I did an "Oops" , realizing I forgot to get the slightly bigger hose 8 x 14 ahead of time. So I subbed in a new piece of 8x13 fuel line for now. I still have a couple more bits of PS hose to replace. Realized I still have a slight kink in the hose that exits the oil carrier & goes to one of the metal lines that run up to the PS cooler. Maybe that's my PS issue. I'll order more lines & tackle this in another week or two, along with the 2 sections up front behind the grill. They are hard as a rock.
