I removed the brake booster and got it ready for shipping to be rebuilt. I really do hate removing things with hardline fittings.
Started with this...
... then this happened.
Then, a couple hours later after Alex was on his way with his M30...
... Sammy got his...
... and I got yard art + ca$h.
Nasty, rainy day. Decided to clay & wax the M in my too small of a garage. Life doesn't get any better than Vienna sausages, cigars and Meguiars
Pulled the rest of the automatic wiring out, including the OBC relay module, which rendered the car inop. Plugged it back in and one of the legs burned up in the box, so I just did a bypass. I also taped up some loose connectors in behind the radio, which I thought may have been contributing to the blown-sounding drivers left speaker (it wasn't). So I'll just throw one of the speakers from the parts car in to see if that solves it. I need to replace the drivers rear speaker too which is inop. Oh, and in diagnosing my no-start this weekend, I killed the battery, I had to give that a good charge yesterday as well.
Nevertheless, it was back on the road to work this morning, so in all it was a good weekend.
Removed the dreaded cracked to shit pedal bracket.
Redid my muffler to cat connection. Flanges weren't lining up and leaked big time. I cut them off, welded on connector pipe to the muffler and clamped the cat side. Fart free now! Me? Not so much.
Went to the top of my driveway to start mine. Tried to turn it over and clunk, everything went dark. Had to get a ride to work. Came home and pulled the battery to have it tested. Tested fine. So brought it home, cleaned the posts, put the battery back in, hand tightened the connections, and it started like nothing happened. Then after driving around, I brought it home and tightened the cables back to the post. Pop...
The connector cracked. So I guess Ill be replacing that next.
Moral of the story, clean the post before going to all the trouble I did haha.
Whatever connection you show to the positive terminal is highly suspect and should be replaced in its entirety ASAP. It even looks like there is another connection to the right wrapped with electrical tape.
Yeah thats the work of the previous owner. He said that he added this...
to the original connector because it wouldn't fit a normal battery, instead only fitting a BMW specific battery? I'd never heard that. So does the original connector fit a BMW specific battery or does it fit a normal auto battery? I've been fixing the hacks as they've presented themselves, such as the radiator hack that recently came up, where the top plastic hose port on the radiator had apparently cracked off, so three pieces of pipe were epoxied one to the radiator, one inside that hose, and one to connect those to together.
^^^ Yikes. Tell me you replaced that radiator. Good luck with the electrical stuff; that PO sounds like a genius.
I spent the better part of the last couple of days tidying up a number of things on the 528e; the big project was replacing the crappy old KYB strut inserts on the front of the car. The one on the right had blown out and was to the point where it would bang & thump every time you hit a bump. The new Billies are sooooooo niiiiiiiiice and smooooooooooth....
Thanks and yeah the PO was but he was really nice when it came down to buying the car from him, just had and liked e30's more. I replaced the radiator with a perfectly good one out of an '84 533i parts car for $20.00! It sucks seeing those cars abandoned to the point of disrepair but its awesome to be able to take a couple things off of them and give them new life in the next e28.
The reason the battery terminal "extension" was added is because the wrong battery is installed. The posts are reversed. To get the posts on the "correct" sides he flipped the battery around 180 degrees. Now, the posts are too far away for the original cables to reach, so he "modified" the positive side with that nonsense. Find a proper battery, install it the right way, and throw that junk in the garbage.
Note: if you don't, that positive terminal will ground out on that frame rail as soon as that tape wears through and probably burn the car to the ground.
Once that happens, a C101 rebuild is imperative.
Stock battery is a group 47, but a 48 and 91 work just as well.
Had this guy out yesterday afternoon to the hangar:
I was a little concerned about the diffused cloud cover, but I think it will work out (as opposed to the harsh, crystal blue skies of last week). It was a better neutral for the Arktisblau.
Perfect lighting. Can't wait to see those pictures show up in Eye Candy!vinceg101 wrote: I was a little concerned about the diffused cloud cover, but I think it will work out (as opposed to the harsh, crystal blue skies of last week). It was a better neutral for the Arktisblau.
Replaced the o-ring and the gasket to the oil return down pipe. Hopefully this will solve the oil leak. After that no more leaks I hope!
Today I dropped my 528i's oil pan to mend a dodgy patch made by the PO, and to see if I could find anything that caused the oil light to stay on for too long during startup:
Huh? What's that under the baffle?
a paper towel????????
Towel in oil pan, nice find.
All I did was go to dollar store to get another cheap turkey baster to remove fluid from PS oil carrier, so I could replace the 2 small lines that exit that back side. Then I did an "Oops" , realizing I forgot to get the slightly bigger hose 8 x 14 ahead of time. So I subbed in a new piece of 8x13 fuel line for now. I still have a couple more bits of PS hose to replace. Realized I still have a slight kink in the hose that exits the oil carrier & goes to one of the metal lines that run up to the PS cooler. Maybe that's my PS issue. I'll order more lines & tackle this in another week or two, along with the 2 sections up front behind the grill. They are hard as a rock.
I did the Ps hoses earlier this year, and those 2 lines by the cooler were very nasty.DanOKC wrote:along with the 2 sections up front behind the grill. They are hard as a rock.
After finding it was vary hard to pull them off (after loosening the cooler itself) I decided to just cut them up.
What a pain in the @#&!!!! those little bitches had embedded steel wires running lengthwise!
Note that my car is an early '82 528i; YMMV.
My 3/85 528i had that. I was angry. My 7/75 530i had normal hoses too. 3/75 date codes on them.
Have you tried reaching out to PML?wkohler wrote:My 3/85 528i had that. I was angry. My 7/75 530i had normal hoses too. 3/75 date codes on them.
Had it towed only to have it fire right up when it got home. It's been a shitty day.
ECU cracked solder?wkohler wrote:Had it towed only to have it fire right up when it got home. It's been a shitty day.
This is what I did today...
DSC_4332 by ericandshovin, on Flickr
Untitled by ericandshovin, on Flickr
Finally got around to fixing what was would be fire roasted e28, if it hadn't been solved.
This POS was removed...
and after cleaning the connectors, a new (correct) battery was put in place.
Have to say if I hadn't posted on this forum, I wouldn't have realized this problem.
So Thanks Guys!
So Thanks Guys!
Lot's of awesomeness here.
Added to the herd.
Added to the herd.
