PEDAL BRACKET Reinforcement / repair - REV. 6-welded tab
rata3
Re: PEDAL BRACKET Reinforcement / repair - REV. 5-welded tab
Post by rata3 »
Hi Jerry, I'm rata3, Carlos Espinosa. Do you remember me?
DAVID PEPIN
Post by DAVID PEPIN »
Brackets still available, revision #6 is thicker, P S
I am not selling these clutch reinforcement brackets through ireland engineering! There part is not the same as the Roth Bracket and the hardware is differant and no tab,
David
krellboy
Post by krellboy »
I guess this post serves as the answer to the PM and personal email I sent.....DAVID
I wonder which of the members would be the best resource to read up on the diagnosis of these clutch type problems.....my car is like many on the board....250000 miles....second clutch, second transmission.
The clutch system has been working quirky lately....gradual and thought maybe it was just me. Seems like the pedal engages many times too close to the floor and just very recently 2 gear (sometimes 1 st) wants to nash and is hard to get into gear....often a double clutch maneuver will get me there. At first when I noticed the quirkiness I just thought it was the clutch being old and worn out. But after browsing thru the two primary threads related to this issue I see that the problems may be three or four fold.....clutch slave, clutch master, flex line, pedal bracket or maybe even the clutch itself.
If any prior subscriber could give me a heads up on the best path to test out the ideas sequentially I'd be very grateful...I'm not much of a diyer and the mechanics around here aren't very receptive to seeing my car show up to work on....and skill set is sketchy anyway.
Still good to know the bracket is still available if I need/want it.....never heard of that problem until a few days ago. Lots of reading to do....hoping I don't screw up my synchros in my tranny in the meantime.
Any input graciously accepted.
lswoboda
Post by lswoboda »
I feel very dense. I went to install this today in my 1988 535is and I couldn’t see where it should go.
My car has the cruise control tab above the clutch pedal, but I couldn’t clearly see where this bracket is supposed to go. I tried to use other pictures to figure it out, too, but no luck.
Does anyone have any picture to get me started to identify clearly where the bracket goes, please?
Thank you in advance.
DAVID PEPIN
Look at my post too see where it goes
David
DAVID PEPIN
Next batch of parts ready by July 15 2023
Thanks, David
tony-e30
Re: PEDAL BRACKET Reinforcement / repair - REV. 6-welded tab
Post by tony-e30 »
Just installed on my 279k mile 87 535is, and I'm very happy with the results. I installed it at the same time I replaced the clutch primary and secondary cylinders, and maybe there's a placebo effect going on, but the pedal action just feels more solid than it ever did. More importantly I don't have to worry about my pedal bracket cracking. Thanks to David for a great product and for making our community a better place.
DAVID PEPIN
Brackets in stock, can ship asap,
Thanks, David
DAVID PEPIN
BUMP for brackets in stock,
Can ship ASAP,
Artevanj
Post by Artevanj »
David,
I need two of your superior brackets.
Cost of brackets each and how much to ship to Ricmond VA 23235?
Thank you!
Jay
PS.......I am a repeat customer :)
DAVID PEPIN
Jay, thanks for being a loyal customer, 2 brackets including priority shipping too VA is
$140, JULY 1 they will be $75,
Paypal too this email,
Thanks, David
Fanclutchnut
Post by Fanclutchnut »
Hi David,
Are there brackets available for shipping?
