John in VA
Post by John in VA »
e28Sean wrote:I started off the day with chrome trim that all looked like this:
Then i used a shocking amount of Blue Tape:
By now, you should see where this is going...
And yes, I did the other side.
No newspaper for masking? It helps to keep the overspray to a minimum, but a clay bar should take care of it.
e28Sean
Post by e28Sean »
It's plstidip. The overspray rubs right off with a lint free cloth and leaves no residue.
dhdrums
Post by dhdrums »
Took the valve cover off New Years eve, prepped it to paint it black that night (I know, its probably the best way anyone could ring in the new year), decided I'd rather just clear coat it since I thought it looked good as is, painted it this morning, got off work and installed it in the dark in my driveway.
Now it makes me want to do that to the rest of the engine bay, especially the intake manifold, since it all looks dirtier.
Before
During
(notice the nice lamp freezing in the cold last night)
After
dhdrums
Post by dhdrums »
When I did that with the trim around my windshields, I thought I used enough paper... Then I looked at the roof and saw a lot of overspray. I thought that plastic dip was a PITA to get off.
e28Sean
Post by e28Sean »
dhdrums wrote:I thought that plastic dip was a PITA to get off.
For overspray, there are two methods for removal that have both worked for me in the past:
For heavy overspray, mask off a square around the affected area, then lay on a few coats (as if you are painting the area). Wait a few hors, or even a day or two, then peel it off.
For light "dusting" overspray, let dry for 15 minutes, then gently rub in a circular motion with a soft towel. It comes right off.
PlastiDip is pretty awesome. It drys and is ready for another coat in 15 minutes. After 7-10 days, it is "fully set" and will survive a high pressure car wash hose. Even after "fully set" you can peel it right off to change the look of your car. So long as you properly clean and prep the surface, it won't harm paint or chrome.
trevmmeister
Post by trevmmeister »
Does plastidip come in regular sized aerosol cans? I have been wanting to shadowline my car for a while, but haven't been able to decide between plasti and paint.
Starting 2015 off right. ;)
e28Sean
Post by e28Sean »
trevmmeister wrote:Does plastidip come in regular sized aerosol cans? I have been wanting to shadowline my car for a while, but haven't been able to decide between plasti and paint.
Yes, it does. It's as easy to use as paint, and non-permanent.
AdamL
Post by AdamL »
Tested my new toy. A milestone for the garage project! Now if I can only get the plumber back to finish the heat...
waynet1
Post by waynet1 »
Haven't I seen that car somewhere before ?
Post by Coldswede »
Disconnected the batteries on both the e28's and the M7 (I know it is not an e28 but it's pretty much adopted into this forum) and hooked the battery tenders up. Damn! I have got to get that garage built this year! :roll:
e28Sean
Post by e28Sean »
I've got an aftermarket AM/FM/CD in my car. It was installed when the OE AM/FM/Tape unit died. It works, but, there was always one thing that bothered me about it. ...The display. It's easy to read and clear, however, it seems to have been designed by the battleship searchlight department! It's distracting as shit at night, and it doesn't dim on the dimmer when you turn the headlamps on.
So, today, I set about a 5 minute fix for that:
Step 1 - Remove the face plate:
Step 2 - Pop the somvabitch open:
Step 3 - Spent an hour combing the carpet in your home office for the tiny spring that whizzed across the room during step 2.
Step 4 - Apply a layer of tinting film directly to the face of the OLED panel.
Step 5 - Reinstall.
Result: The display is now juuuuust bright enough to see during the day, and should be perfect at night. No more bright blue searchlight on the dash! :rofl:
I thought you were going to show us how you found the circuit that powered the OLED and put a resistor in to dim it. Cheater. (but nice work anyway).
e28Sean
Post by e28Sean »
cek wrote:I thought you were going to show us how you found the circuit that powered the OLED and put a resistor in to dim it. Cheater. (but nice work anyway).
Thanks! A) I didn't want to spend forever poking around the board (this literally took five minutes), and B) my ancient and dusty oscilloscope died when I moved and I haven't replaced it because good scopes are expensive as balls. :?
Vlad just got a long-overdue bath. Now doing the interior...
All clean and conditioned. Still in love with these seats.
JSmoove
Post by JSmoove »
cek wrote:All clean and conditioned. Still in love with these seats.
What car are those seats original to? They look fantastic.
Yesterday I spent about 6 hrs doing the following.
1. Installed new clutch pedal bracket with reinforcing piece. Old one was cracked to shit and had a shitty weld job.
2. Installed refurbished brake hydrobooster from JCS.
3. Installed master cylinder.
4. Replaced all power steering hoses with new lines and hose clamps.
By far and away the most frustrating was the hose job and installing the hard line that goes from the hydrobooster to the regulator. Absolutely hate working in that area of the car!
JSmoove wrote: What car are those seats original to? They look fantastic.
They are E34 sport seats. This pair was created out of two pairs. One from a US 540 Sport and one from an Irish (RHD) M5.
Read this thread for the gory details: http://www.mye28.com/viewtopic.php?t=120566
momo2ls
Post by momo2ls »
So it's not today, but since its purchase.
Here in autumn 2012 ... for 360$ US.
And here now. The engine runs very well. We have some concerns about the heat in the passenger compartment and the fuel gauge.
Otherwise the track soon to discover the propulsion.
Decided to clean a little before flipping it.
dsmith
Post by dsmith »
1st 5er wrote:Decided to clean a little before flipping it.
Did you miss something on the PPI? :laugh:
A PPI would've doubled the price of the car. ;)
Rev-match shifted Snob home.
trevmmeister
Nothing because I was at work all day :bawl: :zzz:
nik77356
Post by nik77356 »
I can't wait to work on my E28 again. It's currently in the garage at my father's house with a space heater next to the block. Won't start either. Needs brake work too.
foolish
Post by foolish »
Before work I replaced the oil pressure switch that had begun to leak and cause the light to flicker at idle.
LarryM
Post by LarryM »
Bought a set of RS061s to eventually replace my M5 wheels. The RS's centers were painted white ( :roll: ) and I'll be bringing them back to their original gold along with polished lips and hex caps. I expect this will be a long-term project lasting a couple of months or more, but I still can't wait to see them on the car! I might keep the M5 wheels as "driver" wheels because they're not quite so desirable and can be easily replaced if stolen. Not so with the RS's! I might use them mostly for shows at least until I free up more garage space to keep the car inside full time.
bbaxter
Post by bbaxter »
While I was driving home last night the steering got real loose. I put Al on the lift to check out the problem and the aluminum bracket at the base of the steering column had separated. I removed it from the car. Rebuilt it and re-installed it. I guess it's good for another 31 years.
Fixed it, again.
dhdrums
Post by dhdrums »
Got to stare at it while going past the shop. Hopefully will get it back on the road by Thursday pending one that the parts come in on Tuesday and two that it is in time when the new chain and guides go on it. Even though this is only the second time its had to go off the road for three weeks for a repair since august, it still sucks every time.
