My M5 S54 Build is DONE
Chuckne
Post by Chuckne »
That is interesting. I wonder if the springs got swapped at some point. They were rusty/cruddy when I pulled them out so I assumed they were the originals. I have the original Canadian dealers paperwork (including the lease) from 1987 with the specs on the car which has the mtech body kit and suspension options listed as being on the car. From about 1994 until I bought the car last year there is a void of what was done to it other than the importation/federalization of the car in 2002. I have the original KPH speedo in a box that was swapped out for the MPH when it crossed the border. If the springs turn out to be too soft, I can always swap to something different in the future but thank you for the adding to my knowledge.
Devinder
Post by Devinder »
Chuck,
I don't think the fronts will be "too soft". Springs with 5.5 turns should be pretty stiff unless the wire is really small. If you can measure the wire size (within 0.1mm) and the total number of turns (coils), I should be able to give you approximate spring rates.
Devinder
Chuckne
Post by Chuckne »
Thanks....I'll see if I can get the diameter measured.
rcbmw
Re: My M5 Build...Sneak Peak (Updated 1/27)
Post by rcbmw »
Chuckne wrote:The car came from the factory with the mtech/bilstein suspension...no self leveling system.
Not so. All DC93 North American specification E28 M5 examples were built with twin-tube gas pressure Boge front shock absorber inserts (31 31 1 133 517) and the same front coil springs used on all North American Spec 535i and 533i models (31 33 1 126 024). In the rear, all North American E28 M5 examples were equipped with hydraulic self-leveling suspension. Bilstein shock absorber inserts were only used in European specification E28 M5 examples produced up to 10/1986 (front: 32 2 225 016 and rear: 33 52 1 129 241).
Can you verify if your stabilizers are adjustable and confirm what color the coil springs and stabilizers were prior to refinishing them?
Best,
RCBMW
Chuckne
Post by Chuckne »
I'll have to post my paperwork from the dealership. I tried taking a picture to post but that didn't work. Ill bring it to work and scan next week.
Black Steel
Post by Black Steel »
Watching with interest. Great work so far :D
rcbmw
Post by rcbmw »
I noticed that you perviously referenced these Bilstein Part Numbers in another post:
Chuckne wrote: Front F4-P36-0243-H203
Rear F4-B46-0607-H002
The Bilstein part numbers you listed are in the old Bilstein part number format and correspond to the (B8) Sport version. BMW used the (B4) OE twin-tube series only in European specification M5 models up to 10/1986 production and the part numbers you provided confirm that the Bilstein absorbers were installed by a previous owner. I have a suspicion that your car was modified with an early Dinan suspension system.
I would love to see more photos of your amazing work on the M5. Great job!
Best,
RCBMW
Chuckne
Post by Chuckne »
Updated in the first post. RCBMW, I'll check my paperwork. I know the ECU has a Dinan chip so maybe you are on the right track with the springs. Thanks.
Teilegott
Post by Teilegott »
:shock:
Awesome...
100% respect... :alright:
E.rouzbeh.28
Post by E.rouzbeh.28 »
That engine will make the car crazy good! Can't wait to see it finished. Great job on the build so far, looks clean.
Love this project.
You had me right up until the S54. Great attention to detail, though.
ealoken
Post by ealoken »
what i great build :)
Nice to see that the car is beeing buildt like this :)
Great inspiration :)
dunnojack
Post by dunnojack »
this project is completely nuts. i love it! How do you plan to run the S54? euro harness with oem ecu chipped or stand alone? that's what i would love to do... the s38b36 is just a fix for my power desire for now lol
Chuckne
Post by Chuckne »
Running stock ECU that has been burned to eliminate EWS and any inputs from the body side. Had to go with a DBW throttle pedal. From a functionality standpoint, I will have full dual vanos and the only thing I loose is cruise control. Engine will probably have to come out one more time to clearance the tunnel for the 6 speed as I'm not happy with where things are. Otherwise all is sorted.
BMWJustin
Post by BMWJustin »
When I did the 6 speed swap in my Hartge H5s and my fathers 666csi, I simply cut a section of the tunnel approximately 8 by 10 inches out up near the bell housing. I made all of the necessary adjustments using a hammer and dolley, then fabricated a 20mm oversize replacement panel. I welded (now) captive metric nuts to the underside of the tunnel drilled holes in the replacement panel, lined the replacement with closed cell foam and bolted the new cover right on. BTW it makes getting to those top transmission fasteners a bit easier. Just a thought though.
It looks like you started with a nice chassis, and motor. Keep up the good work and keep us updated!
Best Regards,
Justin
dunnojack
Post by dunnojack »
Chuckne wrote:Running stock ECU that has been burned to eliminate EWS and any inputs from the body side. Had to go with a DBW throttle pedal. From a functionality standpoint, I will have full dual vanos and the only thing I loose is cruise control. Engine will probably have to come out one more time to clearance the tunnel for the 6 speed as I'm not happy with where things are. Otherwise all is sorted.
oh man, that's sweet. I wasnt sure if the burn was more refined. when i first looked at the swap, i guess there were a lot of questions about how well the ecu would function, but this is good news!
Keep us posted on progress!
Murfinator
Post by Murfinator »
You got the jump on me with the Dynaliner on the firewall. Doing that now.
Could you please elaborate regarding the teaser pics of the brake/fuel hard lines? Interested in the larger diameter lines: OE from another model or custom?
Thanks
Chuckne
Post by Chuckne »
Brake and fuel lines are all stock. Stripped them down to bare metal, primed and painted. Must be the camera angle that makes them look larger.
thrty8street
Post by thrty8street »
this is insane
thrty8street wrote:this is insane
Understatement of the year!
Black Steel
I would go SMG with CSL airbox to knock it out of this world.
I thought about such a conversion before doing mine....Decided the S38 was a little more period correct. They sound good at 9000rpm too :D
Chuckne
Post by Chuckne »
Update 8/21
Sam 84, 533i
Post by Sam 84, 533i »
nice work! my 28 could only dream
CSBM5
Post by CSBM5 »
Chuckne wrote:Update 8/21
Awesome project. Thanks for the update -- looking forward to more.
Chuckne
Post by Chuckne »
2012 update in first post
Almost like it belongs there!
Let me know about those mounts.
Holy crap! I just realized you have an S54 in there! Is this the first time this has been done in an e28 or has anyone ever been brave enough to attempt it in the past? I thought it was impossible to fit one of these in there.
E.rouzbeh.28
Wow, that's some good stuff right there. 0-60 in what, less than 5 seconds?
ealoken
Post by ealoken »
Nice :) i just bought my self a s50b32, and then you do this ;)
I have some questions.
1. What did you do to the oil pan and oil pickup ?
2. How did you solve elecrtic and ecu?
3. What kind a engine mounts did you use / build?
