Here's what my distributor cap looked like when I replaced it a couple weeks back; you can see daylight through that crack. No wonder there was lightning under the hood.
I did an oil change on the B7 and made a huge mess.
I also removed the Federalized charcoal canister and the related hoses.
Add where might one find this fancy thing for purchase?
DOH! missed the hidden link.
The clutch slave cylinder was spraying fluid all over when I checked it the other night, and the replacement I ordered came in today. Also got a set of rear rotors for it. As long as we're bleeding hydraulics...
Finally got to the rear glass lock strip done, not a bad job using the plastic jimmy stix winshield guys use and some dawn dish soap for lube. Also installed a footrest:
I also used the e30 part as it was one piece and cut to fit ( thanks for tip DanaR)
all the tools for the job, and difference between old strip and new:
Installed and welded in the mwrench steering box fix on the M5. The bracket had a crack, but not broken, so good timing.
Head gasket.
Well I installed the glovebox latch oldskool sent me.
Halfway installed the way it was before) a new antenna seal since the old one was cracked and missing parts of it. I need to figure out how to get that to properly seal since the antenna motor won't let the seal go down any further.
Also put in the "new" zhp knob I got from Chimi-Changa to replace the wooden one I had.
(please excuse the dirty floor mats and cracked dash)
Didn't realize it would match my steering wheel until I put it in.
Replaced the outer weather strip on the front passenger window. I didn't think it would be nearly as easy as it was. It looks completely different now too,
You need to unbolt the antenna assembly and pull it into the trunk. Then, install the grommet into the fender. Finish by inserting the antenna back through the grommet and bolting it back into place.
Thanks I'll do that tomorrow.Kyle in NO wrote:You need to unbolt the antenna assembly and pull it into the trunk. Then, install the grommet into the fender. Finish by inserting the antenna back through the grommet and bolting it back into place.
Starting replacing the windshield this week:
More here: http://www.mye28.com/viewtopic.php?f=3& ... d&start=50
Installed 6 cleaned and flow matched fuel injectors into the M20. (Thank you Rich at Cruzin' Performance) After a complete e2i engine rebuild two years ago I've been kicking myself for not addressing the injectors better at the time. A noticeable improvement - feels good.
Adjusted the passenger side hood catch to not bind (slightly) upon opening the hood.
Doused the squeaky urethane bushings in the rear trailing arms with WD-40. Didn't hear a peep out of them tonight, glad it worked for now. KMAC rear camber kit, your days are numbered.
On my 535is I did two things: replaced the foam strip near the leading edge of the hood, and lubricated the squeaky fresh air blower.
Lubricating the blower was a hassle. The car has a gasoline cooler, so I couldn't really remove the firewall cover, much less the motor itself. So I:
- Pulled the firewall cover as far forward as I could.
- Popped the motor covers.
- unclipped the motor.
- Rotated the motor a bit so I could see the bushings.
- Sprayed some Teflon spray at the bushings. I used a section of small brass tubing to extend the lubricant's spray tube.
- Dribbled some oil on the bushings with the dipstick.
- Buttoned everything up.
Getting everything in the audio department squared away. Factory premium system, updated with early e34 weather band radio, 6 disc factory changer in the trunk. The rear speakers needed the surrounds glued down to the baskets. All 4 tweeters are working now. A good test was cranking it to 10, no blown speakers.
After a lot of reading and looking at the wiring schematics I was able to tie into the rear channel speakers positives pre-amp. The center of the spliced rca's pick up the signal, and the shielding negative goes to chassis ground. 5v signal is going to the amp. A bit of voodoo wiring it felt like.
Ran a remote splice from the antenna/factory amp. Added a 400w mono amp and matching subwoofer in a truck box that fits cleanly behind the passenger seat. The gain is turned down to almost zero, and still has quite a bit of punch. Trying to get the best balance will take a bit of tuning, but it's not too far off. Probably just need a weaker amp.
Good job, Ron, I highly recommend the 4 oz of oil in a squeeze bottle with a 14" telescoping spout.I bought it at the local Ace Hardware for a couple of bucks. Shawn D, mentioned it yrs ago. The 535is is suffering from lack of use.That is going be the issue with that car. I bought a new pump oil can. The guts of one that I had for 30 yrs fell apart and I needed one. I've been using it on the hinges and stops. A few squirts .is all it took. Maybe get something for the rubber door gaskets ,etc..RonW wrote:On my 535is I did two things: replaced the foam strip near the leading edge of the hood, and lubricated the squeaky fresh air blower.
Lubricating the blower was a hassle. The car has a gasoline cooler, so I couldn't really remove the firewall cover, much less the motor itself. So I:It doesn't squeak anymore. We'll see how long it stays that way. My 535i with 578k miles is still on the original motor. I oil it whenever it starts squeaking, which is every couple of years.
For the umpteenth time I have the cat back on the ground. In all my wrestling with grafting an M5 exhaust onto a super eta cat. at the exhaust manifold ,I ripped the flange clean off the rear down pipe. Doh!.. I have the nose 2 feet in the air . I also flunked for a bad left outer tie rod end. I had a good set, originals from the '82 with castle nuts and cotter pin holes and the rondel stamped on the bottom. I freed them up and they were tight. I bought a set of boots for 6.95. I drilled 9/32 holes into the grease cap. I pumped fresh grease into the ball joint then I capped the holes with some rtv.
Then I took the original and traced its out line on a piece of plywood. I matched up the new ones to the marks for a ball park alignment.
Got that damn keyless entry system working...finally
Thank goodness for Chinese standardization!
Installed a more period correct radio (Bavaria Mono Digital), which replaced a crappy 90's Alpine one:
Did the vacuum brake conversion on my 535i. I had a high idle until I realized I forgot to put an o-ring on the master. I still have to get a PS hose made so for a few more days I have manual steering. I also need to get a PS reservoir bracket so I can mount it better than with zip ties. Overall it seems like a good mod and the braking feel is fine.
I gave my brother the down pipe with its broken off rear flange. His shop works in small stuff made of exotic metals. I just need a cast iron flange re-welded to an original Boysen DP
I finally installed the sport seats the other day (only took me a year...)
installed a new speedometer pulse generator. speedo etc. now working again.
