Page 2 of 6
Posted: May 21, 2013 10:13 PM
by athayer187
The rears look right, but the fronts are for sure meant for the larger M5 brackets.
Posted: May 22, 2013 8:53 AM
by 95maxrider
athayer187 wrote:The rears look right, but the fronts are for sure meant for the larger M5 brackets.
Even the rears didn't quite fit. The bushing wasn't long enough.
Do you know if I can get away with just buying the M5 bushing brackets or if I need to also get the frame mount for the bracket?
For example, can I just get #3 or do I also need #12?
http://www.realoem.com/bmw/showparts.do ... g=33&fg=45
In the rear, I don't even see the frame bracket as an option, so can I just get #3 and put it on the non-M frame mount?
http://www.realoem.com/bmw/showparts.do ... g=31&fg=10
Posted: May 22, 2013 9:41 AM
by 95maxrider
Ugh, did some more searching and came across some helpful threads on E24 forums regarding the FSB frame mounts:
http://forums.bimmerforums.com/forum/sh ... -in-635csi
http://bigcoupe.com/phpBB2/viewtopic.ph ... a6e49c7eb7
http://www.mye28.com/tech/rods_pages/si ... _mount.pdf
Now, my question is if I can use the non-M brackets and thin bushings, and just reinforce the stock non-M frame mount instead of trying to fabricate a new frame mount to accommodate M5 bushing brackets? Is the frame mount the weak point or is the bracket the weak point?
Posted: May 22, 2013 10:11 PM
by athayer187
http://www.mye28.com/viewtopic.php?t=63 ... light=sway
I don't believe that the thin wall bushings are of any use at all. The other limiting factor on stock 535i front swaybar brackets is that they are captured with one bolt, and one tab. If that tab bends, game over.
If you can - get the M5 pieces.
Posted: May 29, 2013 9:32 AM
by 95maxrider
I thought I had already posted pics from the second event, but I must have forgotten. Time for more pics!
On the smaller barn course:
And from the third event a few days ago on the big main track:
This is what happens after you lock up your brakes and try to correct:
Again, the results of more brake locking:
Hopefully ABS will be working again by the next race, because I was not prepared to race without it. I got much better as the day went on, but the first few runs were a little tricky. Still only hit one cone for the day, which was a direct result of the brakes locking up.
The car doesn't have a very smooth idle, so in addition to finally adjusting the vales after the head swap, I'm considering replacing my O2 sensor. With only one on the car, I figure it's probably pretty important to how it idles/runs at part throttle. If I can get all that done and find a set of big sway bars, I think I will be very happy with this car. The 3.73 diff really woke it up, and I really don't think I was ever wanting for more power/response at the race. The car has some severe problems with body roll/motion, as you can really feel the weight being thrown around, but I think sways will fix most of that. If not, I might consider cutting one coil from the front springs, as the pictures show it's riding unnecessarily high.
And a video from the third event with my best AM run and PM run:
http://www.youtube.com/watch?feature=pl ... 5_aBgRxhm8
Posted: May 29, 2013 2:31 PM
by NAH
Sounds just like you are running straight pipe exhaust in the videos ^^
What suspension and you running since it's so high?
Posted: May 29, 2013 2:46 PM
by 95maxrider
NAH wrote:Sounds just like you are running straight pipe exhaust in the videos ^^
Yeah, the exhaust was like that when we bought it. No cats in the system, and I think it's a single 3" after the straight pipes/cat delete (plus a muffler). I'm not a huge fan, but it works for now.
For suspension, right now it's on E28 springs (actually not sure if from a 535 or 528, also not sure if it makes a difference) and Bilstein HDs. I'm also a little surprised at how high it sits. Part of it may be from moving the battery to the trunk, and part may be from gutting the interior. Still though, it makes me think I've got 535 springs on it and they make it ride higher than 528e springs would. I'm considering cutting a coil off the front springs, because we simply don't need this much clearance.
Did a little digging only to find a myriad of spring options for the E28.
528e:
535:
So these are stock springs, I'm just not sure which.
It was lowered when we bought it, but that didn't work very well when playing in the dirt. Unfortunately now there is a tremendous amount of body roll, and I'm having a hard time finding a set of the big 25/19 sway bars.
Posted: May 29, 2013 5:38 PM
by tig
I love how this car and thread is like the honey badger. It just doesn't give a shit.
Well done! Very well done.
Posted: Jun 07, 2013 3:02 PM
by 95maxrider
Not much new here, still trying to figure out how to get big sway bars to work on this damn thing.
In the mean time, we prepped the car for the additional loads of the big bars by reinforcing the FSB end link attachment points on the struts, as it's a known failure point. We ran out of time, but the next thing to do is to reinforce the rear frame mounts for the big bars. We did at least get new Meyle end links front and rear. Our old rear links were pretty shot.
Welding!
And I got the rear section of the front fender liners installed:
And I'm not sure if this is from the dirt, or from driving too hard on the street, but the front Winterforce tires are chunking:
So that's cool.
ABS problems
Posted: Jul 10, 2013 9:43 AM
by 95maxrider
A few months back I had the front sway bar end link mounts reinforced on the struts by my mechanic, and when I got the car back he told me something happened to the ABS wire on the front of the car (driver's side). It sounded like the wires were only barely attached, and when he went to do his work, they came apart. The story didn't quite make sense, but either way, this is what it looked like when I got it back:
And so for the last two rally-x events I've been running without ABS, and while I can stay out of ABS most of the time, there were a couple of times I really could have used it, and I lost time without it.
So I picked up a used sensor from south26 on here and got to installing it
But unfortunately, even after disconnecting the battery overnight to let the ABS module reset, I'm still getting the ABS light come on after I drive the car ~50', and ABS is inoperative. I'm kind of at a loss as to how I should approach this problem. I've read that other people have had the same problem, but haven't come across a solid solution. Any tips on this would be greatly appreciated!
Posted: Jul 10, 2013 9:44 AM
by 95maxrider
Like most E28s, my car was blessed with the chrome accents in the tail lights, and they don't exactly match with all the blacking out of other trim I've done, so it was time to tackle two projects at once. What was the other project? Water leaking into the trunk around the tail light seal.
I took out the lights and inspected the original insulating foam, and it had seen better days. I read a thread on here talking about a 3M product that is great at sealing things, and is likely the same stuff used to seal around the tail lights on my I30 and many other cars. Enter: 3M Strip-Calk.
We applied this liberally to both the lights and the body, and from what I can tell, it makes a good seal.
So after much cleaning, taping, sanding, and painting, I ended up with this:
Hooray!
On another note, we tracked down another water leak a while ago, and it turns out the large puddles of water on the floor are coming from the lower window seals on the doors.
This part:
It clearly needs to be replaced, but I'm not sure which part is which in looking at the Real OEM diagrams.
For the front, I think I need part #5
http://www.realoem.com/bmw/showparts.do ... g=41&fg=40
And for the rear, I think I need #4
http://www.realoem.com/bmw/showparts.do ... g=41&fg=45
Are those the correct parts? Is there anything else I should replace in there while I have everything apart? Are there any tips on how to best do the job?
Posted: Jul 10, 2013 10:29 PM
by winfred
once the key is cycled the abs is reset, if the light comes on after you start moving you have a dead or really weak sensor, a quick and dirty test is hook up to sensor with meter set to AC, you will get a volt or two when you spin wheel, you can check one side against the other
Posted: Aug 05, 2013 9:46 AM
by 95maxrider
Hrm, I'm in a bit of a dilemma, and I could use some opinions.
I've found a set of 24/18 Whiteline sway bars for $360:
http://www.energysuspensionparts.com/pr ... rod=BBF34X
http://www.energysuspensionparts.com/pr ... rod=BBR34X
But since the front bar is so large, I'm pretty sure I would need the M5 frame mounts for it not to fail quickly, and these are simply not available.
My other option is to get a used set of a 22mm ST front bar and an 18mm rear M5 bar that I found.
Doing my reading here:
http://www.digest.net/bmw/archive/v7/msg03531.html
and
Tells me my '88 (late model) has 19mm front, 15.5mm rear bars, so the 22/18 would probably be different enough to be worth the effort and money. Additionally, the 22mm bar might be small enough to not put too much load on the mount, so maybe I could get away without dealing with the M5 mount headache.
What do you guys think? Is the 24mm front bar worth the extra effort of somehow getting M5 frame mounts on the car, or will the 22mm be enough of an upgrade? Or, is the 22mm bar big enough that it too will rip off the front frame mount, thus negating it's only redeeming quality?
Fixing the axles
Posted: Aug 30, 2013 9:37 AM
by 95maxrider
A few weeks ago while under the car trying to fix the ABS issue I discovered the DS rear outer axle boot was ripped and was spewing out grease, so I wanted to get that fixed before the next race.
After looking at the price of new axles on Pelican and the reviews of the $60 remans at parts stores, I decided to just get the boot kits from Pelican and rebuild mine. Four $15 kits ain't so bad. Unfortunately, they decided to only send two, so now we'll have to take the axles out again sometime to do the inner boots. I decided to replace both outer boots since they were in much worse shape than the inners.
Thankfully I have good friends who were willing to lend a hand with the job, so I went the Patrick's place and Josh came out too. Bobby (the co-owner) was nowhere to be seen :x Before doing the work I had Patrick drive the car around and he picked up on a clunk coming from the rear end when getting on and off the throttle at low speeds. In his semi-professional opinion, the whine I'm hearing from the rear end on the highway is my diff and not the carrier bearing on the driveshaft, so I was worried that the clunk might also be coming from the diff. Apparently some diffs whine and some don't, and there's nothing you can really do about it except shut up and take it. So naturally, I'm going to install more sound deadening and carpet this weekend, because it is damn near unbearable.
Anyway, the point of all that is the clunk from the rear was actually coming from the PS axle. When Josh took it apart and tried to reassemble it, the bearings wouldn't all go back into the carrier thingy. He did some filing work, but I don't think that did much. Eventually, and I'm not sure how, it went back together and seemed to rotate more freely. IIRC the grease in that boot was much nastier than the grease in the ripped DS boot. Now I'm curious to see how bad the inner joint is for that axle. So for once, we solved a problem we didn't intend to, which is much nicer than the usual finding more problems while simultaneously not fixing anything.
Anyway...
Obligatory jacking off picture
Ahhh...
Well, it's half-nice
This is what the PS inner looks like
And the PS outer before we replaced it
So...who thinks we need new pitman arms?
Big thanks to Patrick for offering up his garage, lift and time, and thanks to Josh for all the help!
Big sway bars!
Posted: Aug 30, 2013 9:39 AM
by 95maxrider
Holy shit, it actually happened!! The car has some properly sized sway bars!
After months of searching, I came across a set of used sway bars that were just right. Let me recap:
First idea- Get the ST 25/19mm set. Oh, but wait, it's no longer being produced and nobody seems to be selling used ones.
Second idea- Buy a used set of M5 bars and figure out a way to mount the front one. Oh wait, the guy who sold me the set lied and they turned out to be from an E12 or something and weren't even close to fitting the E28.
Third idea- Buy a new set of Whiteline 24/18 bars. Oh wait, they're out of stock and not sure when they're getting more.
Fourth idea- Just freaking get the medium ST set that's still supposedly available. Oh wait, the rear bar is only 0.5mm larger than stock. That's not worth $180.
And yet a few weeks ago the clouds parted and I got a PM from a gent here who had the perfect set: 22mm ST adjustable front bar and a 18mm M5 rear bar. Hooray! Those are respectable increases over the stock 19/15.5mm bars.
On to the install!
Patrick noticed the upper bolt for the DS FSB end link (about 2 months old) was very loose, so he snugged it up, but aside from that the install went pretty well. Pics!
New bars
Rear installed with new PowerFlex bushings
The front bar came with poly bushings that were slightly worn but still stiff, so I reused them to save the $50 for the new PowerFlex bushings I bought just in case.
Installed!
Dear god, these transform the car. All that slop and wallow I was complaining about is all but gone. It's not quite as nice to drive as it was on the lowering springs and stock bars, but it's close. I can't wait to get more seat time and really feel what the bars do, but for now, let's just say they were worth the wait. Now let's all pray I don't rip off the frame mounts! :banana:
Posted: Sep 26, 2013 9:19 AM
by 95maxrider
Got a few updates on the car, so I figured I would post up.
We finally got some carpeting down over the sound deadening in the trunk and back seat to keep the SD from getting damaged or torn up when putting things in the car. The carpet in trunk and on the lower portion in the back seat aren't glued down, due to ongoing water leak concerns, but at least the SD is protected.
We also installed some HD roll cage padding at helmet level.
And then we did some redesigning of the interior. We removed the remainder of the center console that housed the window switches and the tacked on aluminum dash panel that our ex-third member installed to make room for a storage container. Oh, and some much needed sound deadening on the firewall and trans tunnel! Bobby (the co-owner) had a spare set of floor mats from his E46, so we threw those in the car as well. Every little bit of sound deadening helps!
And we finally got back to doing some more blackout work on the chrome trim. I used more of the blackout tape around the windshield and paint for the front Roundel, which had completely stripped down to the chrome. From 5' away it all looks good enough for me!
Oh, and we took the car through a car wash after the last event. Doesn't it look nice?
Posted: Sep 26, 2013 10:52 AM
by Drew in NYC
I'm liking the milk crate mod :rofl:
Good stuff!
Posted: Oct 09, 2013 2:03 PM
by 95maxrider
Got some pics from the last race!
Finally, some updates!
Posted: Dec 10, 2013 10:08 AM
by 95maxrider
Well to celebrate the snow day here in DC, I'll be doing some long overdue updates to my build thread!
Due to a combination camera malfunctions and poor video quality (vibrations) resulting from too many hinges in my GoPro mount, I haven't really had many videos to post, but I got things straightened out by the end of the season, so I've got vids from the last two events of the year, plus one bonus event!
Rally-X #6 10/20/13
By this point we had our 25/19 sway bars on the car, and were loving the body control. No other mods had really been done to the car.
So coming into this event I was pretty solidly in third place for the season behind Roberto in 1st (2nd gen RX7) and Josh (E30 318 w/M42) in 2nd. The wild card in our MR division was Chris, who had previously ran a V6 swapped MR2 (and done very well with it) but the motors kept dying and he sold it, leaving him without a car for the season. For the 4th event I let Chris co-drive the E28 since my co-driver was out of town, and Chris beat me pretty handily in my own car. I watched him drive, and I learned I simply wasn't abusing the car enough, so I've tried driving more aggressively since.
Anyway, for this event, Josh let Chris co-drive the E30, and guess what? Chris smashes Josh in his own car and comes in 1st for the day, earning himself enough points to tie me for 3rd for the season! I came in 4th, behind Josh and Roberto.
Here are the results.
http://www.wdcr-scca.org/RallyCross/Res ... lt.aspx#MR
After 13 runs of about 60 seconds each, Josh was 12 seconds behind Chris, Roberto was 2 seconds behind Josh, and I was 11 seconds behind him. I only hit two cones for the day, which is quite a bit less than others in my class. Maybe I need to drive even more aggressively!
Towards the end of the day, the gas pedal was coming off the floor and flopping around, occasionally making the throttle stick, which added a few seconds to my final runs. The metal bracket the holds the pedal to the floor had rusted off, so there wasn't much holding the gas pedal in place. We had planned to get a hinge from Home Depot and do a quick fix before the next race, but never got around to it, and it came back to bite us. More on that later.
Another problem area with the car was the lack of ABS. There were a few sections on the course where I really was going easy on the brakes for fear of locking up, which was costing me valuable time. As of right now, the issue still hasn't been resolved. I also got tired of having my foot to the floor for so much of the run, and starting wanting more power. But what else is new?
Here's a video of my best run in the AM, followed by my best PM run.
http://www.youtube.com/watch?v=3EvNIYJ1 ... D7LGc5McKA
Rally-x car at auto-x??
Posted: Dec 10, 2013 10:10 AM
by 95maxrider
For whatever reason, I auto-x my Infiniti I30, but when the final Solo event came around, my front brakes were metal to metal and the new Wilwood pads/rotors hadn't arrived yet, so I decided to bring the E28 out on its snow tires and have some fun. I'm pretty sure I set the slowest times of the day, but the car sure made people laugh! Three other people from rally-x also come to Solo events and they got a kick out of seeing the E28 come out. Anyway, times didn't matter this day, so I'll let the pics and video do the talking. Watch the video to the very end!!
One of these things is not like the other
Here we go!
Posted: Dec 10, 2013 10:11 AM
by 95maxrider
And finally a video of that magnificent run
http://www.youtube.com/watch?v=Nl9QvVek ... D7LGc5McKA
Rally-x #7, final event
Posted: Dec 10, 2013 10:14 AM
by 95maxrider
After all that hoonin' around, our tires were in pretty miserable shape, and although we now owned a near-new set of REAL rally tires, we didn't have any wheels to put them on, so we finished off the season on our balding snow tires in a class full of cars on rally tires.
As you might remember, Chris won the 6th event in a borrowed E30, tying me for third place for the season, so I had to beat Chris if I was going to win anything. Josh, knowing this, decided against letting Chris co-drive again, so Chris was forced to drive his clapped out 80s Celica that he had mostly broken at a previous event (control arms, steering links, etc). Apparently those old Celicas are no match for rally-x. I had beaten him before in that car, so I knew it was possible, but our tires were in worse shape than ever, and Chris had more seat time in his new car, so anything was possible.
Thankfully the water truck gods smiled upon me that day, and we made it an entire event without the water truck coming through to wet down the course (to keep the dust down from coming onto the main track at Summit Point). Our car (big, heavy, on snow tires) is at a huge disadvantage after the water truck comes through, often falling 20 seconds behind after a single run compared to the 400+ pound lighter cars on rally tires. So a dry course gave me the best shot possible at holding onto third and getting close to Josh and Roberto ahead of me.
By the end of the very short AM session (with only three runs), I was in 4th behind a guy who had never beaten me before (Jim) who has an E30 on rally tires, but I was still ahead of Chris and the Celica. I really wanted to beat Jim, so I drove like a madman in the PM session. I quickly pulled ahead of Jim, but was still losing a little time to Josh and Roberto on each run. On my third run, semi-disaster struck; the throttle got stuck, and badly. At the beginning of the run it was justly mildly stuck, adding something like 5-10% throttle when I let off, but as I drove it got even more stuck to the point where I was braking with my left foot just to keep the car on the track. After one WOT section it got so bad that I almost lost control of the car, so I threw it in neutral and shut it down in the middle of the course. The throttle cable had gotten pulled out of the rubber grommet on the throttle cable bracket on the throttle body and was getting hung up, so I pulled it back out and was able to limp the car to the pits. But I still had two runs left to do, and no car to run in, and if I didn't get those runs, I would be disqualified for the day, thus ruining my chances of getting third for the season.
Luckily, Josh is a generous fellow and allowed me and my co-driver to use his car for the last two runs. His car is fully prepared in terms of suspension tuning, and he has nice rally tires. The car is just very tight compared to our loose E28, and drives completely different. I had only driven the car for about 2 minutes on the street earlier this year, so I wasn't sure if I was going to know how to drive it in the dirt with all that grip and response. I got in, and drove the piss out of it, and ended up setting the fast time of the PM session for a 2WD car on my first run! Apparently all that fine tuning Josh has done paid off, because that car is stupid easy to drive fast. The grip from the rally tires, combined with the tight suspension and responsive steering, plus very low weight equals a formidable package. Unfortunately for Josh, I beat his fast time by over a second on my first run in his car, and after having the same thing happen when he let Chris drive it earlier in the year, he wad forced to concede that he's better at building cars than racing them. Still though, I know Josh is going to be my main competitor next year now that Roberto sold his RX7 and is moving on.
Results:
When the dust settled, I was in third place for the season, feeling pretty good about the way I finished the day and the season. I now know that I can set fast times given a properly prepared car, so my goal is to get the E28 to the level of Josh's E30 by the beginning of next season.
Oh, one thing to note. At the lunch break we threw a set of spring spacers/deadeners in the front springs in an attempt to firm up the front of the car, as I haven't been happy with the feel since we put on stock springs. They WORKED! The front end was tighter and there was less dive under braking. Whether or not they contributed to the other problems that showed up, I'll never know, but we had other problems once we were back in the pits, aside from the stuck throttle cable.
First, the trunk latch mechanism decided to separate from the body ever so slightly, making it impossible to open the trunk. After much jiggling and pushing the button it caught and opened, but not before something else broke. We had to do a drive through of the course to find a number that flew off, and while on the slow cruise I noticed a clunk from the front end. Oh shit, is that the dreaded sound of a broken sway bar frame mount??? We get the car back to the pits and I start yanking on things until I realize the PS front end link is loose. We said "fuck it" and decided to fix it later. Then, when we got on the road, we realized our old exhaust hanger problem was back, and the exhaust was hanging on the freaking drive shaft. If you're ever heard the sound of a drive shaft rubbing against an exhaust while going 60 mph for 1.5 hours, you will know how terrible a sound it is. Oh, and then the throttle cable we thought we had fixed decided to unfix itself, and the car was back to driving itself. A few zip ties later and we were back on the road, but damn was that a stressful end to the season.
Anyway, here's a video showing my best run in the AM, followed by the throttle stuck run in the PM!
http://www.youtube.com/watch?v=wrNBPLjX ... D7LGc5McKA
And here's what the throttle cable looks like. I'm not sure if the bracket is supposed to be bent like that or not, but I'm wondering if this might be the result of the 885 head swap raising the cable up a bit. There is just no slack in the line, and I'm not entirely sure how to approach this one. Any advice would be greatly appreciated.
This is after we took off the zip ties holding the grommet in place.
And here's my list of things I would like to have fixed before next season:
-Obviously fix the throttle cable/gas pedal
-Get those rally tires on some wheels
-Fix the ABS
-All new brakes
-Get some more spring isolator rubber for the rear springs, cut a coil from the fronts???
-Adjust valves, get an O2 sensor on the car
-Remove sunroof (save weight, get headroom)
-Make driver's seat height adjustable (car was built for a guy who was 6' 6", and my co-driver is some 5" taller than I am and our seat has no height adjustment, so I have to sit on three folded up towels just to be able to see where I'm going).
-Get proper hangers on the exhaust
-Get different style steering wheel
-Fix the god damn water leaks in the trunk, get turn signals to work
-Reinforce sway bar frame mounts
That's all folks, thanks for reading!
2014 update time!
Posted: Mar 04, 2014 10:22 AM
by 95maxrider
Picking up where I left off at the end of last season, we had a rusted out gas pedal hinge that might have been a cause of the throttle getting stuck open during one of my runs, a throttle cable that was inexplicably tight, and a broken exhaust hanger that we assumed was the culprit of the exhaust resting on the driveshaft. Driving home 100 miles at 70 mph with the exhaust on the driveshaft is not a pleasant experience. As the beginning of the season is quickly approaching, getting those items fixed were our priorities.
So this Saturday we took the car to a friend's garage and started looking things over. We had purchased new pitman arms since ours looked pretty beat, and decided to throw them on first since they were an easy job. I had no idea how completely dead ours were. The bearings were shot and moved around with ease. We replaced them with a HD set of Meyle arms, and my god is the difference enormous.
We also removed the FSB end links and reinstalled with blue loctite, since the upper nuts have come loose twice so far, and I don't want that to happen again.
And in anticipation of the E46 rally wheels and Style 4s, we got an extended stud conversion kit!
Here's the broken hanger we thought was behind our exhaust problems:
Alas, it would not be that simple. I was casually looking around the engine bay when we got it on the lift and noticed something slightly alarming:
Umm, yeah. We broke the PS motor mount support bracket. Too much powah!
Of course, BMW doesn't stock the part and it's a 3 week wait to get one from Germany. So off to the junkyards we went. In what must be the best luck I have ever experienced in working on cars, we actually found one E28 in the first junkyard we went to and we able to get it's bracket and mount. This junkyard had tons of E34s, E39s, E46s, etc, but no E30s, and just our one E28. I could not believe our luck.
Upon getting back to the shop, we quickly realized the other motor mount had broken, but thankfully the bracket was still intact. Oh, and we fixed up a very minor coolant leak.
Oh, and look, two broken trans mounts! So basically the entire engine/trans was being held in place by the crossmember and our super-duper skid plate bracing (see earlier in the thread for more detailed pics.) Amazingly, there were no weird noises or vibrations from this, and the car drove normally. How? I have no idea.
Of course no parts stores sell the motor mounts, but we were able to get a pair of cheapo trans mounts. I'm awaiting new motor mounts from Pelican that I ordered yesterday. Naturally, with the motor sitting in it's correct location, our throttle cable and exhaust problems pretty much solved themselves.
Oh, and we ordered new spring rubber isolators to try to increase the spring rates since the car is a little soft for my liking. A fellow rally-xer (Chris) gave us a single rubber that was cut in half at lunch on the last race and it firmed up the front of the car nicely. We ordered a pair of full/new ones, but they were too big to fit in the rear springs, so we pulled the half ones from the front and put the new ones in there. In an effort to stiffen up the rear, we moved up the spring perch one notch on the Bilsteins. I'm not entirely sure it did anything yet though.
Oh, and that broken gas pedal hinge? Since the floor is so rusted up, we didn't want to deal with cutting and welding a bunch of stuff, so...door hinge to the rescue! With the matching other half underneath the car for support.
Oh, did I mention we picked up a set of super fresh rally tires for cheap? Oh, and a set of forged Style 46 wheels that weigh ~13 pounds?
Oh yeah, and we picked up a pair of new seats (PS not installed yet). And you might notice I pulled the steering wheel from my I30 and put it in here. More on the seats later.
I don't have pics of everything, but here's a quick list of other things that were fixed.
-Oil change with Rotella T6 5w-40
-Fresh coolant
-Adjusted the valves (one rocker was loose, the rest were in spec)
-The hubs were so rusted up that the rally-x wheels wouldn't get close to flush on the hub so much sanding ensued.
-Some magic with the seats (like I said, more on that later)
-That elusive ABS problem has been solved! The one ABS sensor we replaced on the DS front was apparently defective, so that explains why it didn't solve our problems when we installed it. Thankfully, I had racked up quite a pile of spare ones, and we threw one on, and viola! We finally have ABS again!!
-Threw some Seafoam in the gas, because why not? The gas was a few months old and I wanted to clean things up a bit.
-Got all new tail light bulbs and sockets, which seemed to fix most of our problems.
I think that's it, but I'm probably missing something. Next up, a seat/steering wheel update!
Posted: Mar 18, 2014 3:14 PM
by 95maxrider
Well after doing all that work, we still had to install new motor mounts to replace the one cracked one (the other was just old) and mount the summer tires before heading off to a BMW test and tune on 3/8. As per usual, we were stuck doing this on the Friday night before the event in the cold, and as usual, I managed to find a way to fuck something up. The motor mount install was going pretty well until I over torqued a bolt for the motor mount bracket going into the block on the DS, which left that mount attached with 3 bolts. I hoped it would make it through the TnT the next day.
Then we tried to mount the 16x8 Style 4 wheels with 225/50/16 Hankook V12s. This required using spacers, which REALLY didn't want to fit over our rusty (but already heavily cleaned) hubs. The 5mm spacers seemed to give them enough clearance, so I didn't bother trying out the 12mm ones I had also bought. After much banging with a rubber hammer I got them on and went for a drive. Holy crap do these tires make the car feel good! Granted, we have been used to snow tires, so most anything would have been an improvement. By this point it was about 10 PM and we had to be at the TnT by 8:30 the next morning.
The car makes it to the TnT without issue, and I was really enjoying myself on the new tires. The car actually behaved like a proper BMW! Even on fresh rubber, the car felt composed on the course and put down very respectable times. After ~5 runs I parked the car to go to the bathroom. When I came back, the clutch pedal went to the floor and didn't come back up. Crap! Popped the hood and looked under the car to be greeted by a puddle of brake fluid. Double crap! After wiggling a couple things around it was determined the the clutch line had a hole in it. Of course, this being a 26 year old 528e, nobody stocks clutch lines for it, so we had to get it towed to a shop (thank god I did that instead of to my house) and wait for parts.
I ordered a SS clutch line as well as brake lines from Ireland Engineering, since I figured the brake lines wouldn't be too far behind the clutch line. Unfortunately, IE sent the wrong clutch line and the rear brake lines didn't match my calipers either. Suffice it to say that the customer service at IE is pretty horrendous and I don't think I'll be ordering anything from them in the future. So I had to overnight a stock line from Pelican and held off on the brake lines. And of course, when the new clutch line arrived, my mechanic couldn't get the old one off the slave cylinder without stripping it, so we had to get a new slave.
After many problems refilling and bleeding both systems (we did put new SS brake lines on the front since they actually fit), the car felt great! Apparently the fluid that came out of my calipers was watery and filled with rust particles. With new fluid in the pedal felt perfect and the ABS seemed to operate much more smoothly/quietly. I reattached the skid plate, test fitted the rally wheels (they needed the 12mm spacers) and drove it home, not 12 hours before the first rally-x TnT. See a pattern here?
I'll post up a recap of the rally-x filled weekend along with plenty of pics later!
Posted: Apr 07, 2014 2:45 PM
by 95maxrider
We left off around 9 PM on the Friday night before the first rally-x TnT and race, with a new slave cylinder and clutch line in the car. I got the car home and started packing for the long weekend ahead. I was on the road at 6 the following morning to meet up with Josh and the other E30 guys, and it seems we have a new member to the club. It's a GRM Challenge car, a turbo E30 ETA, and proved to be quite capable.
Our new racing venue is in Frostburg, MD, which is much further out than the old Summit Point location. We arrive to a constant 20 mph wind, which didn't let up the whole day. Our venue is the top of an old strip mined mountain, and it's just a wide open field of gravel. It's a far cry from the hard packed clay we had at SP, and proved to be quite annoying since it rutted up so easily.
After some difficulty in removing the 5 mm spacers, I eventually got the 12 mm ones on (damn rust/corrosion), and had all four rally wheels/tires on the car for the first time. I just had to snap some pics.
They will never look this clean again.
After a lot of runs at the test and tune, the car looked like this:
Sunday was the race, and thankfully the winds had died down to normal levels and you didn't have to struggle to walk into the wind. The results after the first run basically previewed the finishing order for the day, with Josh and his 318 in first, me in second, and Chris and his insane 5.0 (ok, 4.9) Fox body Mustang in third. The Mustang is new this year and was untested before we began, but is gutted beyond belief (no rear hatch whatsoever) and has a heavily modded motor probably putting out about 320 HP. It has by far the best power to weight ratio in our MR class, but it struggles to put it all down. In fact, probably about half of the cones he got penalized for were from his rooster tails, not for any body contact. Chris is fundamentally opposed to adding any weight to the Mustang, so my (our?) only hope is that he doesn't wise up and get some mudflaps. The turbo ETA E30 was on AS tires, but by the end of the day it actually posted the fastest time in the afternoon in the class! If and when he gets real tires on that thing, the E28 is really gonna be in trouble.
Everything was going smoothly until my third run in the afternoon, when I finished the run and noticed some steam coming from the hood and my temp gauge slowly rising. The culprit was a rerouted coolant hose that got caught by the alternator fan blade. Josh, being the good sport and generous guy that he is, let me finish my afternoon runs in his lovely 318, allowing me to not get a DNF for the day. Driving his car is worlds different than the E28; the steering is tight and quick, body motions are well controlled, and the car just seems to float over deep ruts where my much heavier car would want to sink into them. It's so nimble I didn't ever think twice about hitting a cone when driving. It was really quite eye opening.
Thanks to the generous help and supplies from Chris and Josh, we got the car fixed up after the race without having to go to the parts store by shortening the hose to go over the head, and we began our caravan back home with the snow beginning to fall. Of course, the one time it snows during a rally is the first time I've ever had summer tires on the car, as my old snow tires were all I had to commute and race on. Even so, the car made it home just fine, and I was glad to be home.
Overall, I was very pleased with the car. While the new rally tires didn't quite do what I was expecting, they were a necessary addition as the new surface is so rough that any snow tire would only last a race or two. The suspension on the car really feels better and very tight after installing the rubber spring spacers, and I think is pretty close to ideal. If the car was bottoming out, it was not nearly as noticeable as in Josh's 318, so I think we have a good combination of wheel travel and suspension firmness. Even so, I can't help but think about cutting a coil off the front springs....
Oh, and how about a video?
http://www.youtube.com/watch?v=t1WVBp3L ... D7LGc5McKA
Posted: Apr 09, 2014 8:36 PM
by 95maxrider
So Saturday we got a lot done to the car, including gutting the sunroof and gaining 2" of headroom, getting the Recaro PS in the car, and getting the old FSTB to fit over the bigger 885 IM.
First off was finding a way to remove the stock passenger seat without hacking it apart with a saw. You see, the previous owner decided to weld the two front seat nuts to the frame, which were obscured by the sliders on top of them. Oh, and the motor that controls forward and backward movement was broken. After about an hour of trying everything to get it out normally, we disassembled the power seat reclining gears and made the seat manual, and were able to get to the bolts and cut the welds.
Note the new homemade seat adapters, made to drop the seat ~2" from the riser it was on before. Thankfully, our seats adjust for height too :D
The Recaro stands alone, victorious after a grueling battle.
Ahhh
For the sunroof, we considered doing the aluminum sheet method, but ended up retaining the stock one for rigidity. A big part of the reason why we wanted to remove the sunroof was to gain headroom, since my co-driver/owner Bobby is about 5" taller than me at 6'3". By removing all of the interior metal supporting the sunroof and most of the sunroof itself, we gained a little over 2" of headroom, which I think is awesome. However, we ran out of time and some things obviously aren't done. To reattach the sunroof, Wayne (mechanic) did some welding:
WE'RE NOT DONE YET DAMMIT!
This is also just a test fitting. Much more welding needs to be done.
I'll leave you with this
Posted: May 29, 2014 8:55 PM
by 95maxrider
Well it's a few weeks late but I'll post up a little recap of the second event.
The temperature had warmed up quite a bit for the second event but the wind was still blowing pretty good on top of our "mountain". While I was installing the rally tires I noticed that RSB had come out of the DS end link, and it really didn't want to go back in there. Chris helped out by lending tools and his hands, and after a while we were able to wrestle the bar back into the end link. I have no idea how or when it came out, but judging by how well the car drove afterwards, I'm guessing it came out sometime during the test and tune/1st race weekend a month earlier. The tech man (Mike) noticed my throttle cable was a little loose too, since we never readjusted it after getting the motor to sit correctly, and throttle response improved slightly after we tightened it up.
The course was pretty dry compared to the first event which limited rutting, but the AWD cars were still digging pretty good trenches for the rest of us to slog through. This made for a generally rough course, which beat up some of the cars pretty good. Josh managed to bash up a section of the floor in his E30, and I'm willing to bet that the rough terrain had something to do with the fan relay failing in Chris Nonack's monster Mustang. Chris was running fast but dirty, and after the relay blew he decided to call it a day and put the car on the trailer in case he blew a HG or something.
In the past, I almost never posted a faster time than Josh (run to run), but this day I beat him in 6 of our 11 runs, which was quite surprising. At the first event I averaged something like 2 seconds slower than him per run, but this day we were neck and neck, trading 1st and 2nd place all day. I got called for two cones on my last AM run, but I really didn't think I hit any that run. At the end of the day, I was 4.6 seconds behind Josh, so the cones wouldn't have saved me.
We had some people taking pictures this day, and I bought some pics from last season that I forgot to buy, so enjoy some pro pics!
Last season at Summit Point:
Is this what bottoming out looks like?
Pics from Frostburg by Jason Catterton
A perfect picture of the shark nose
Remember how I said the course got a bit rough? Well some cars fared better than others.
The croo
Can't forget the videos! Does this site not support embedded YouTube videos?
https://www.youtube.com/watch?v=Iq12L_ABYCk
https://www.youtube.com/watch?v=XB_ttLSvbFw
Re: Rally-x 528e build (caged, head swap, and more!)
Posted: Sep 01, 2014 1:26 PM
by 95maxrider
Long time, no updates!
So at the #4 event the car decided to spit out one of the circlips holding the rear Bilsteins together, which caused the rear of the car to pretty much drop to the ground. After many calls to parts stores, we were unable to locate a new rear strut, so the car got towed to Patrick's house and I finished up the race in Josh's E30. Thanks to both of them for being such good sports! Who knew that finding parts for an E28 could be so hard in the middle of nowhere? Oh wait, I did (see: leaking clutch line earlier in the season). I had the lead when the car broke, and I was able to maintain it over the next day (#4 was a two day event) which tied me up with Josh for the lead in season points.
Slammed, yo
Goodbye for now
So after fighting with Bilstein to send us new circlips for about a month, they finally arrived with new spring perches, and with Patrick's help we got the suspension back together without too much fuss. Repairing the torn axle boot was another story.
It has been over a year since we did the two outer boots, and in that time we forgot everything we learned in the process, so fixing this PS inner boot was a major PITA. Again, Patrick to the rescue!
Our diff cover has been leaking since we put in the 3.73, and I was hoping to replace the gasket. Patrick checked the diff cover bolts and found a few to be loose, so we decided to hold off on the gasket and see if this fixed the problem. It didn't. But it did do one amazing thing: it seemed to eliminate most of the whine coming from the diff! Don't ask me to explain how, because I don't know, but it's awesome! Once we get a proper muffler installed (Borla ProXS 19") the car might actually not be a penalty box to drive to events!
Oh, and check out the awesome steering the car has! I can't imagine either of these things to be good. Damn steering box.
https://www.youtube.com/watch?v=T3NYwhV ... e=youtu.be
https://www.youtube.com/watch?v=InhWzrT ... e=youtu.be
Posted: Oct 10, 2014 3:31 PM
by 95maxrider
Even though nobody seems to read it or care, I'm going to do another update, this time of the Northeast Regional Rally-X Championship, held at our local venue in Frostburg, MD a few weeks ago.
Fresh off of coming in third in the Ohio championship event, I was hungry for a win at home, and I was feeling pretty good about the car after FINALLY getting an O2 sensor in the car. We couldn't remove the one from the stock location, so Meineke welded in a new bung and threw one in, along with a new Borla ProXS muffler. I was sorely disappointed by the lack of noise reduction from the "quietest 3" muffler available," but thoroughly impressed by the results of installing a working O2 sensor. The car now idles like a normal car, instead of rocking itself to bits, and throttle response is MUCH better.
The championship was a 2-day event, but I didn't make it through the first AM session on Saturday without a problem. Just after starting my fourth (?) run, I felt the car start dying on me. Lights were flashing on and off on the dash, and the car struggled to stay alive. I babied it through the run, somehow only adding ~2 seconds to my fast time so far. I had a feeling it was battery related, and sure enough, both of the battery terminals had come off the battery. Apparently my co-owner went a little crazy with the dielectric grease and didn't quite tighten the bolts enough when he installed the new terminals a few weeks prior. I used up my 10 minute tech session and got back out there.
The guys in my class for the event were:
-Josh (Turbo Josh) in his home built turbo ETA E30
-Stephen in the ETA E30
-And some guy from NY in an E36 325i. This was only his second event, so I wasn't too worried about him.
Josh, with the E30 318i (and my usual competition), couldn't make it due to a wedding, but that didn't mean I was going to have it easy. When turbo Josh's car runs properly, it's fast. Very fast. Unfortunately for him, he broke his ghetto wastegate spring bar-thingy and was without any boost for all of Saturday. As such, I was able to keep a pretty good distance between myself and the others. Stephen was running pretty clean, but about a second slower than me.
The rest of Saturday was pretty uneventful, and I finished the day something like 6 seconds ahead of Josh. Unfortunately for me, he was able to super-ghetto fix the wastegate with some Loctite, and was making boost on Sunday. Unfortunately for him, he then noticed two small tears in his intake elbow, which bled off most of the boost he was making. Still, he was clawing back time on Sunday morning, and was putting down faster times than me by the end of the AM session. If he kept that up, he was going to pass me after a few runs in the PM.
I was going to have none of that. I removed the passenger seat, and spent my time working the course figuring out how I could drive faster in the final PM session. Whatever I did must have worked, because I was on a roll in the afternoon. I was laying down clean, fast runs, and Josh and Stephen couldn't get close to me. It didn't help that Josh was coning like crazy. He was in a close second all weekend, but ended up falling back to third behind Stephen by the end of the day. At least the car was able to make the drive home!
My car took some damage though. Midway through Saturday I heard a clunk coming from the back of the car when going away from a stop. A little investigation revealed a completely blown center support bearing on the driveshaft. Without much of a choice, I pressed on, and it made it through the weekend and the drive home.
Oh, I should probably mention that we got something like 30 runs in over the course of the weekend, which I believe is the most of any of the regional championship events, so hats off to Adam and the others who put the event together! I can't seem to get the results to load, but IIRC I was the fastest RWD car there as well, beating out a fast Miata, so that's something. It looks like this car is finally coming together. Who would have thought?
Now for what you have all been waiting for...pics and video!
Winnar!
https://www.youtube.com/watch?v=gMz8IkR ... D7LGc5McKA
Posted: Oct 10, 2014 7:25 PM
Congrats! Enjoyable read!
