You might give this a try.davintosh wrote:I think I finally figured out my screwy idle problem on the 528... Last night I replaced the cracked intake boot and the hoses from the intake to the idle control valve and to the valve cover, but it was still revving up & down between 1500 and 800. Gave the ICV one more good cleaning, shot some WD-40 in it and left it sit overnight, and it was much better this morning. Still not perfect though, so I may need to replace the ICV, but I'm closing in on it!
My car kept having a weak battery after leaving it in the school parking lot between weekends and it wouldn't have enough juice to turn over.
After a couple weeks of ruling factors out I discovered that it had to be the fact that I was parking downwards on a hill and the (waaay overly sensitive) brake light sensor would be engaged by gravity over the week and would drain the battery. Jamming a 2 liter soda bottle between the floor and the pedal confirmed my hypothesis after it started right up the next week.
So, I went out and removed the dash and placed a bunch of folded over electrical tape in the shape of a square on the pedal where it meets the sensor.
I had originally planned on adjusting the sensor's position like it says in Bentley, but that diagram is of the clutch sensor even though I triple checked that I was in the brake section.
It seems to put a little bit of stress on the clutch and brake sensor but it will have to do until I get back home and can search some pick n' pulls for a good sensor
Doing this stuff makes me feel good. Fuck reliable Camrys
Cleaned all the cluster grounds in the car, pinned out the wiring harness for ohms, volts & ground continunity.
Removed and replaced the injectors & seals with new fuel lines to and from the rail, ordered a new coolant temp sensor, thermo-time switch & coolant temp sender. Replaced the Conforti chip with a stock chip, threw away the K&N, installed a paper filter. Changed the oil & filter and lowered the car another 1/4 inch in the back after rolling the fender lips the other day. It's time to relax for the day.
Wow that is quite a bit for one day! Nice!w0014170 wrote:Cleaned all the cluster grounds in the car, pinned out the wiring harness for ohms, volts & ground continunity.
Well, that's in addition to eleven E28 M5 wheels, and a bunch of others.wkohler wrote:Yeah. That's a fetish.California Dreamin' wrote:
I have a wheel fetish, you might as well know.
So, yeah, I have a wheel fetish. It's not yet at the stage where I'd classify it as a problem, but that's only because I haven't yet run out of room.
Last edited by California Dreamin' on Oct 21, 2009 5:19 PM, edited 1 time in total.
On the Is I replaced the fat short coolant hose and the long one that goes under the intake to the t joint which in turns goes to the heater. I also checked to see why my power comfort seats slide backwards everytime I get in.And no I am not fat! The bracket on the right rear comfort seat is broken that holds the seat to the power seat tray. Does any one know how to fix or replace this? Ted
