E12 M535i Project - 08-21-19 Update
Re: E12 M535i Project - 01-03-17 Update
The entire car looks great, but man, those stripes!
Stunning quality and attention to detail, and it's sad to think this thread might be running out of updates! The story can't end!
That's sooo sexy.
Truly awesome Chris.
Awesome progress!
The stripes look great and I can't express how impressed I am that you did it yourself. I've had e30 Hartge stripes sitting around for years because I don't have the balls to even think about trying to apply them without professional help (and i'm talking shrink and pro vinyl guy) .
Me too. I would even move everything out of my garage so it could park undercover.cek wrote:Dayum.
I sure hope you bring this to St. Paddy's day. I want to fondle it.
Looks great, Chris! Your garriage is something else!!
Just stunning...Great job!
Re: E12 M535i Project - 01-04-17 Update
Thanks! I took some photos of it outside today. Just in the driveway, but it was kinda tough getting work done since for some reason, all I wanted to do was look at the car.
The trunk spoiler isn't finished yet. Still a stripe, roundel and badging that need to go onto it, even though it's technically acceptable as is.
Pure wow.
Wow.
Wow.
I could never drive it.
Wow.
Wow.
This. Except the last part. Exceptional!leadphut wrote:Pure wow.
Wow.
Wow.
This is the second thing I like about Kohler: He drives his cars.hugh1850 wrote:This. Except the last part. Exceptional!leadphut wrote:Pure wow.
Wow.
Wow.
checking back in. still wow!cek wrote:This is the second thing I like about Kohler: He drives his cars.hugh1850 wrote:This. Except the last part. Exceptional!leadphut wrote:Pure wow.
Wow.
Wow.
luckily the amount of win in the thread will overlook cek's sexual innuendos.
DAAAAANG
Outstanding work! Congratulations sir
Chris, That is beautiful. It would be so great if it was sitting rt next to Eddies at Tedfest this summer.
Gary
Gary
Its just dawned on me that you probably have one of the most impressive and expensive collections of vintage BMW's on this forum. This and the B7 just put it over the top.
How many of these e12 M535i's are known to be in the US? Like 30?
Do like, would fondle
ElGuappo wrote:Do like, would fondle
2nds.
I hope it does brodies.
The before/after pic series is just amazing.
Really nicely done. Be proud of that.
Exactly. The car couldn't be in better hands. Well done, sir.Tammer in Philly wrote:The before/after pic series is just amazing.
I can see how it's hard to get work done with that around; I'd want to look at it all day too.
Re: E12 M535i Project - 01-13-17 Update
Thanks guys. It's been a lot of work and it hasn't always been fun.
Haven't done a lot of big stuff over the last few days, but we are getting kinda down to the piddly crap now.
I figured out the 2500 rpm hesitation issue. I bought a new old stock AFM from a guy in Germany and hopefully I'll receive it sometime in 2017. Everything was pointing to the AFM being the issue. Given tracking status hasn't changed in over ten days (WTF), I decided to look at other things. I swapped Ignition modules, ECUs, did a bunch of other checks on stuff and finally said, "I need to adjust the TPS again." I put the meter on it and I had "001" with the throttle closed. I couldn't rotate the switch anymore, so I was thinking it was bad. I decided to move it the other direction. The number shot way up, then gradually came down and then I got "000." Runs really smoothly now. It was off quite a bit. I guess when the motor was hitting about 2500 rpm, the TPS was saying idle. So, as long as the AFM shows up sometime, I can relax a bit.
Next, I had to do the sun visors. I had a brand new pair I had gotten a few years ago. I went to put them in and discovered that the brand new pair weren't for an E12, rather an E21, so they were useless to me. I went through the stack of visors and found the originals from this car. Of the E12 visors I had, they were actually the best ones.
After lots and lots of cleaning, a huge improvement for sure, but next to the new headliner, a bit of a let down.
I had never mounted the trunk spoiler. Reason being that there were two holes that needed to be made on the underside of the trunklid so I could put nuts on the outermost spoiler studs. The original had them but in all the commotion, Mike lost track and I wasn't thinking about them either. I was going to wait and let Mike make the holes, but I got tired of nothing getting done, so I sprung into action. The current owner of my old white M535i was nice enough to take some measurements of the holes in his trunk lid and I figured out the diameter of the hole and started shopping for a hole saw or something to make it. I soon discovered that the big drawback to hole saws is the bit that drills the pilot hole. There isn't enough of a distance between the bottom layer of metal and the top of the trunk lid. After conferring with a friend, he suggested I use a cutter with a spring loaded locating pin and said to look at the Rotabroach. So, I bought a set from Amazon and the largest size in the smaller set was sufficient.
I bought the stick lube as well. I used a small drill bit and drilled a pilot hole through the hole for the stud in the top of the trunk though the bottom layer. That was perfect for setting the locating pin.
Then I chucked up the ol' Rotabroach and voila!
Super clean hole. Very impressed. Made quick work of it too. I touched-up the bare metal with some primer and then later some polaris and good to go.
I mounted up the spoiler. So interesting.
Once the spoiler was on the car, I affixed the stripe, the roundel and the model badging.
I hadn't yet mounted the lower left dash panel. Reason being that I didn't have a reverse light harness. I have no idea what happened to the one that was on the car. I decided to pull the one out of the 6er in the backyard and use that as a guide to make one. Turned out it only had half of one. Fortunately, it had the grommet and the part that connected inside the car. I had an E28 one, so I combined the two to make a good one and then spent an hour feeding it into some heat-shrink tubing. Hooked it up and everything worked. Awesome. With that done, I attached the fader, switch for the power antenna and the power window circuit breakers and then the panel to the car. I can't find my new pedal pads, but they're cheap enough and easily available that I can just pick up a new pair.
I while I had the front of the car in the air, I put the lock wire on the front strut to knuckle bolts and called it a day.
Just a couple of piddly things left. I should be able to drive the car now, but it's still insured for like $6500, so I need to figure all of that out before it leaves the garage again.
The few times I've needed to drill holes into a trunk lid or other body sheet metal, the "pucker factor" is pretty high when the drill actually starts cutting into metal. I always fear some huge screw up, even though you measure two, three, eleventy times first. Congrats on getting that spoiler mounted perfectly the first time!
Just an awesome, super impressive result on this car Chris!
Jim
Jim
I love the Arizona historic plates.
Beautiful, love the spoiler. Does the exhaust get chrome tips or stays as is? You're going to be bored, whats the next project?
Car is a stunner...The wheels look great on it.
I thought the wheels would look good as well. I had never put the RAs on the car before and I had them refinished a few years back. Lately, I was thinking more and more about putting the original 14" BBS-Mahle wheels on and I might still get them refinished and do something with them. For now, they're holding up the E28 parts car.
The exhaust is supposed to get chrome tips. I found a pair and paid about $200 for them only to receive the wrong 42mm ones for a 533i that are about $20 ea. Sadly, I only got a portion of my money back on them and I think the language barrier is a big part of that.
I don't think I'm going to be bored since I still have to get this thing broken in (about 95 miles on it now - it's ok). I've got plenty of projects and there's still some tweaking and some other stuff that will have to be re-visited on this car. At this point though, I feel pretty burned out. It felt good to get rid of that 635CSi though. Now I just need to get rid of the parts.
Here's a photo of the car somewhere other than in my driveway.
LOOOK-ING GOOD!
Right? They look antique-ish. Perfect on these cars.bkbimmer wrote:I love the Arizona historic plates.
What's the reaction driving on the street? It has to get some stares especially with the stripes!
Is the suspension settling a bit and are you happy with the wheels and ride height?
Looks great!
Can you restore my NK please?
All kidding aside, you've done an amazing job with that car. I'm very impressed by the level of detail and polish.
Niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiice
