Page 28 of 68
Re: "Vlad": The Zinno '87 535is (now with a B35)
Posted: Sep 01, 2014 9:27 PM
by tig
It's "You're" and your quotes are screwed up.
Posted: Sep 01, 2014 10:04 PM
by Kyle in NO
Your a smart guy? Seem to be that wasn't ATF.... Brake clean, battery acid etc ATF will not hurt paint...
Sure it won't...your car must not have large scale ATF leaks then.
Posted: Sep 02, 2014 2:55 PM
by Vinox
Waw, this car is so incredibly clean, I love it! I really respect attention to detail like spraying the spot below the battery!
Posted: Sep 02, 2014 3:55 PM
by 2 5's and a 7
yep I screwed up the quote and the your instead your'e but I've seriously never seen ATF harm paint.....has anyone else? just curious
Posted: Sep 02, 2014 4:02 PM
by tig
2 5's and a 7 wrote:yep I screwed up the quote and the your instead your'e but I've seriously never seen ATF harm paint.....has anyone else? just curious
I saw this:
https://www.youtube.com/watch?v=Er7gzj0BbSE
Posted: Sep 02, 2014 4:42 PM
by bkbimmer
Pretty much anything left on paint long enough will damage it.
Posted: Sep 02, 2014 4:44 PM
by 2 5's and a 7
Access deined lol.....I'll watch it when I get home. By the way I hope I didn't come off as an asshole. Just something new to me, and I'm old!
Posted: Sep 02, 2014 5:15 PM
by tig
2 5's and a 7 wrote:Access deined lol.....I'll watch it when I get home. By the way I hope I didn't come off as an asshole. Just something new to me, and I'm old!
Don't worry. I don't take ANYTHING here that seriously.
Posted: Sep 04, 2014 5:45 PM
by leadphut
cek wrote:2 5's and a 7 wrote:Access deined lol.....I'll watch it when I get home. By the way I hope I didn't come off as an asshole. Just something new to me, and I'm old!
Oldskool will be heartbroken.
Posted: Sep 09, 2014 2:16 PM
by tig
Went to start Vlad this morning and heard a loud CRACK.
Shut her down and opened the hood. Found this. My radiator fan detonated:
Does this just happen sometimes?
There's nothing (obvious) in there that it could have hit.
Posted: Sep 09, 2014 3:17 PM
by leadphut
WTF?!? every blade?!? i've seen one blade let go. perhaps it shredded the others?
Posted: Sep 09, 2014 3:35 PM
by slammin_e28
OE fan from BMW?
Or was it a non-OE one?
Posted: Sep 09, 2014 3:36 PM
by tig
slammin_e28 wrote:OE fan from BMW?
No idea. Service records only show fan clutch had been replaced (several times).
Posted: Sep 09, 2014 3:45 PM
by slammin_e28
Aftermarket ones, from WorldPac I know of, have been known to blow apart randomly.
Posted: Sep 09, 2014 7:35 PM
by LarryM
Any animal parts laying around?
Posted: Sep 09, 2014 9:18 PM
by tig
No obvious animal carnage. But I actually didn't look close under the car yet.
How easily should a fan spin by hand? The remants on Vlad seem pretty tight. How can I tell if it was the fan clutch that seized causing this? I've read some threads that indicate this can happen.
Posted: Sep 09, 2014 9:35 PM
by tig
Ok, got a chance to look at the car. No dead animals or evidence of animal dismemberment apparent.
Seems to be a lack of blades. I only count the tips of 4 blades present. I found one down by the battery. Hmmm... I wonder where the other 5 went?
Posted: Sep 09, 2014 9:47 PM
by tig
After moving the car I found one more blade and...
This washer.
OMFG.
You know what this means, right?
That I'm a hack mechanic who should't be building engines?
It also explains the oil leaking into the crank pulley. I sure hope that driving several thousand miles without a tight crank nut (which is nowhere to be found) didn't do any damage.
Posted: Sep 09, 2014 10:05 PM
by Kyle in NO
If the woodruff key isn't sheared, you should be fine.
Oh, and don't touch my engine.
Posted: Sep 09, 2014 10:17 PM
by tig
Kyle in NO wrote:If the woodruff key isn't sheared, you should be fine.
CJ asks "if the woodruff key is sheared, what do we do? Crush the car?"
Posted: Sep 09, 2014 10:52 PM
by Kyle in NO
cek wrote:Kyle in NO wrote:If the woodruff key isn't sheared, you should be fine.
Dig the sheared piece out of the crank snout with a pick and install a new key. They are cheap.
http://www.autohausaz.com/search/produc ... 7119951485
Posted: Sep 10, 2014 2:37 AM
by bkbimmer
Looks like you got off easy.
Posted: Sep 10, 2014 10:08 AM
by 2 5's and a 7
Wow!
Posted: Sep 10, 2014 12:12 PM
by leadphut
you said "crank nut"
hope it all turns out minor!
Posted: Sep 10, 2014 2:40 PM
by demetk
cek wrote:It also explains the oil leaking into the crank pulley. I sure hope that driving several thousand miles without a tight crank nut (which is nowhere to be found) didn't do any damage.
Holy crap. You mean you never tightened that nut? Don't you have a checklist or something?
Me, I don't do checklists but whenever I install something I make sure to finish that particular process. Less chance of forgetting something.
