Show us your insides!
BMWgiant
Post by BMWgiant »
wkohler wrote:Well, first off, that's Llama. Secondly - that's how it looks from the factory. There's no Llama carpet, dash or door panels. There is a Llama shift boot - as you see in la picturas. The M5 has the same carpet your car has as well - with Natur seats.
Oh :oops: ... Well I was really just going by the door panels... I figured that in a llama car, they wouldn't be the same as a pearlbeige..
Either way it goes, it looks easy enough to acheive this looks with a different color seats.. llama or Natur would look good in my car..
Edit: If you are right, than why is the llama interior/door panels in this car all matching? I think that the seats in the car I commented on were not in that car from the factory.. I think we need the owner of those seats to comment to know for sure..
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Huh? Llama is a complete interior color just like any other with door panels, center console, carpet, etc. Based on the pristine Llama vehicles I've seen, the carpet is also a shade different than Natur. I agree that Natur carpet is pretty close in color to Llama, though, and with sun/fading they may look similar. But in nice condition, Llama biege is a more orangish brown than Natur carpet. Maybe the carpets are the same but that doesn't seem to be true to what I've seen in person.
Wierd. I've seen two other cars that look just like that first picture. Guess I was incorrect.
m535i on ebay.co.uk with a very interesting interior. anyone seen one like this before?
http://cgi.ebay.co.uk/1987-BMW-535I-SE- ... dZViewItem
bmwm3n528
Post by bmwm3n528 »
c_meyers wrote:m535i on ebay.co.uk with a very interesting interior. anyone seen one like this before?
I've seen this color before in M535i's, I suppose it's the Piniengruen that's mentioned on RealOEM. That upholstery definitely doesn't look original though.
EricM535i
Post by EricM535i »
My interior and the BMW blanket (if the car ever broke down) on the rear seat :)
Russianblue
Post by Russianblue »
jcmass
WOW
Post by jcmass »
Russianblue...that is very impressive. Nice work. DIY? Covers or new leather? Very nice job.
wow what a nightmare those electrics look like to sort out.. kudos, very impressive job
philip1
Post by philip1 »
I've seen his car in person the interior is amazing and the underhood fun looks impressive.
Russianblue
electrics were not that bad to tell you the truth. as long as you know what goes to the cluster, then the OBC, radio and friends...i was worried about it myself, and didn't even label anything because when i was taking it apart, i just took a mental note of where things went. it ended up being not all bad. i did refer to the Bentley a few times, but again, could have been a lot worse.
The leather is standard issue Kevin Chinn - the Artisan. His stuff is top notch. Can't say enough good things about it.
Those are e30 sport seats. Kevin sent me the little adapters and they 'bolt right in' - sorta. Takes a little bit of TLC. I covered the rear seat myself. It was a lot of work, but turned out nice. The e30 sports (manual) are awesome. WAAAAY lighter than the power comfort seats i had. probably 20 lbs or more per seat lighter. i don't really miss the power option, because i am the only one who drives the car and never really move them much anyway. They just hold you in place SO much better.
bmwm3n528
Post by bmwm3n528 »
Russianblue wrote:electrics were not that bad to tell you the truth. as long as you know what goes to the cluster, then the OBC, radio and friends...i was worried about it myself, and didn't even label anything because when i was taking it apart, i just took a mental note of where things went. it ended up being not all bad. i did refer to the Bentley a few times, but again, could have been a lot worse.
Very impressive!! I take it you did all the upholstery labor yourself? Also, the leather wrapped console, is that Chinn's work also?
redstu
uk sep 87 528i Blue cloth
Post by redstu »
still in good shape but only after 96K miles
The wires from the top of the dash are power and AV for an in car video , and power fro my road angel GPS speed camera advisor.
The wire taped through the door is for a temp sensor as I've been noting under bonnet temp to determine if I need to do anything about air intake temp.
Kameix1
Post by Kameix1 »
Russianblue wrote:
Is that a focal speaker I see there?
M5ZEALOT
Still under construction
Post by M5ZEALOT »
Here is some work on my M5 interior, I chose to go two tone. Rears and other trim work to be completed soon.
M5ZEALOT
Re: Still under construction
Post by M5ZEALOT »
M5ZEALOT wrote:Here is some work on my M5 interior, I chose to go two tone. Rears and other trim work to be completed soon.
New rears.....dyed not re-upholstered:
t-race
Post by t-race »
As promised, here are pics of my seats. At the time these pics were taken, the seats were still attached to my friends M5. I'm not quite sure about the color, some say that is is called "Oxblood". But what I'm sure of is that these seats are the only set in Finland of this color.
zundfoldge
Post by zundfoldge »
nice. i think i got to see some damn good examples. :D
DaRedRocket
Post by DaRedRocket »
Nothing special. Interior is the last thing on the list of things to do ;)
psportoveloce
Post by psportoveloce »
t-race wrote:As promised, here are pics of my seats. At the time these pics were taken, the seats were still attached to my friends M5. I'm not quite sure about the color, some say that is is called "Oxblood". But what I'm sure of is that these seats are the only set in Finland of this color.
if i'm not totally batty, i believe this color is called taurusrot (taurus red)
zundfoldge
i like the collor. an that the back seat has the head rests.
psportoveloce
more pix:
BMWgiant
Post by BMWgiant »
psportoveloce,
That interior looks amazing, but you should really consider blackening the headliner!.. I think it would look amazing in that car!! The tan just seems to throw it off a bit, since there is no other tan inside the car.. It's make it look similar to the M5s headliner.. You should message Skip, he blackened his headliner pretty easily and I'm sure he could share some tips!
psportoveloce
BMWgiant wrote:psportoveloce,
thanks. yea, i know. i've been thinking about it and i really would prefer to use a genuine M5 one which means removing the windscreen, and i'd like to have the car repainted and what better time than when the windscreen is already out and while we're in there, we should make the holes for the euro parcel shelf integrated rear sunshade i have and and and....$15,000 later my headliner ends up black. it's on the list...
TheManInTheBox66
Post by TheManInTheBox66 »
