E28 Alpina B7 Turbo/1 #0083
Sorry for the lack of detail in the post. I was just sitting down to eat dinner.
Friday morning, my case of Knecht AG164 air filters showed up. I've got enough for the next 40 years. NOS. I changed that out. The filter is for a 924 Turbo. I guess stock air filters are so popular with those guys that they don't make them any longer.
Anyway, yesterday morning my fuel pump assembly arrived from Moosehead Engineering. I had to make a couple adjustments to the pump attachmentto get it through the hole in the tank which is considerably smaller than the US one for some reason. He did a fantastic job on it. We ended up going with a Walbro GSS-340 instead of the TRE pump.
I discovered I had routed the hoses incorrectly (I didn't have the pickup in front of me when I did that). Alpina put a funky bend and added some material to the return line, so I guess it's a good thing I decided to reuse this piece. So, I dropped the tank enough to get the hose through from one side of the elbow to the other. I was hoping to not have to put the car in the air again, but whatever.
I got that straightened out and ran the pump. At first, there wasn't anything getting up to the rail in the supply line, so I swapped stuff around in the rear. That pressurized the return. Swapped them back and it worked. Weird. So, knowing I had fuel, I pulled the relay and cranked the car for about 10-15 seconds. Pulled the oil cap and oil was getting to the top, so I put the relays back in and fired it up. It took a while of feathering the throttle to keep it running, but after a few seconds, it settled into a nice, smooth 750rpm idle. I let it run for a few minutes in the driveway, bled the cooling system (I had to remove the bottle to change the fuel hoses). Then, I decided it was time to drive it. I took it easy. Knob was all the way on the lowest setting. It still did a good job moving, though I didn't want to get on the boost. I will gradually work on that once the car is sorted mechanically. I just wanted to make sure things functioned. I have to say it sounded pretty cool without the rear muffler. Just two gigantic cats(one for each pipe - which will be removed) and a resonator.
I will post up a few photos later now that the car is a bit cleaner and the trunk is back together.
- Beamter
I am not quite with you.wkohler wrote: I have to say it sounded pretty cool without the rear muffler. Just two gigantic cats(one for each pipe - which will be removed) and a resonator.
Are you sure they are Cats, and not just ordinary silencers? As you have the #083, you were not supposed to have catalysts - they did not come until the TurboKat-edition from serial #237...
Anyway, I am glad you got it running - it is about to be my turn soon. I just have "some" electrical issues first.....
Most likely when it was federalized a shop in the US added the catalytic converters.Pedi wrote:I am not quite with you.wkohler wrote: I have to say it sounded pretty cool without the rear muffler. Just two gigantic cats(one for each pipe - which will be removed) and a resonator.
anyway, I am glad you got it running - it is about to be my turn soon. I just have "some" electrical issues first.....
Over the last two weeks, some progress has been made on the car.
-Valve adjustment (two exhaust valves were a little tight, but everything else about dead-on)
-Oil change (Castrol TWS 10w60)
-New plugs (Bosch WR6DP0)
-New plug wires, cap, rotor
-Complete cooling system sans lower radiator hose (honestly, the original looks and feels like new, though I'm working on sourcing a new one)
-New brake booster
-25mm master cylinder
-replaced front calipers with a good set of M5 calipers (the originals are actually M5 calipers, which I'll rebuild)
-stainless brake lines
-changed the alternator
-reattached the rear muffler for the time being to keep it from sounding like a WRX and blowing exhaust at the fuel tank.
-mounted some Continental Extreme Contact DWs
I drove the car to a local CCA show in Scottsdale today. It got some positive reception from a few people. Many people had no idea what it was (despite my sheet explaining that). I learned that a 1995 M3 is considered a "classic" as well, though a 1996 M3 is not because it's OBDII.
The car drives quite nicely. I've put about 80 miles on it since getting it running. I'm very surprised at how tight it is. There is virtually no play in the steering box, no creaks, moans, etc. No shimmy, either. It's actually a pleasant car to drive. I've been driving it quite conservatively.
I'm going to take some more photos of the car showing it's cleaner demeanor and post those soon.
-New brake booster
Looking forward to see more pics.
How much difference did you actually feel from changing to the 25mm sylinder?
And yeah, you are totally right about the exhaust also - my bad. Only the B9 was given an option, I read wrong long time ago, and I have been convinced about it ever after.
Could you do me an favor if possible?
Could you take a picture of the ECUs in the glovebox, I cannot remember the exact location of the installation...??
I don't see this car at 5erWest. It's just too many miles.
As far as changing the master cylinder, the brakes work now, so there was a pretty big difference from before where you'd push the pedal to the floor because the fluid boiled. I have to say it's a definite improvement over using the handbrake.
In all seriousness, it makes a difference. Some say that it makes the pedal harder to modulate, but I find that to be a non-issue with 4-piston calipers. I used a 25mm unit on my 535is with E31 Brembos, so I'm very used to it. My other E28s have stock brakes and a stock master. I don't notice any real difference in pedal between those and this car. The car stops well, though.
There's no difference between this car or any of the others with how the ECU is situated compared to a 535i. The ECU is an 061 with a sticker over it and an Alpina chip inside. I imagine your car might run an 059 since you have a kat. I can get photos next time I pull the car out.
There's no difference between this car or any of the others with how the ECU is situated compared to a 535i. The ECU is an 061 with a sticker over it and an Alpina chip inside. I imagine your car might run an 059 since you have a kat. I can get photos next time I pull the car out.[/quote] Chris, I would urge you to get the chip copied. Alpina does not suport it (as you know). Nothing about an 061 that can't be replaced, but if the chip cooks, it could be difficult to get one made. I planned to get the one in the B9 copied before I sold it to Mike. It would probably run better with a stand alone sustem, but if you want to stay stock, it might be worth getting it copied. One of those things you don't need...well until you do.
Here are a couple of photos of the car at the show yesterday courtesy of one of our local members (freshbread here on MyE28).
Not a lot of room around it, but here's proof it was there! It doesn't look that exciting, though.
^Just realized I forgot to put the plaque on the handbrake console. It's in the ashtray, wrapped in a tissue.
Also, since most of my time has been spent under the hood, under the car and cleaning the interior, you can compare these to the photos in the original post to see some progress.
