Living with a Legend ///M5: Year Seven 02/10/20
geordi
Re: Living with a Legend ///M5: Year Three 1/2/16
Post by geordi »
Looking good Pavie!
Re: Living with a Legend ///M5: Year Three 6/16/15
Pavel wrote:Before the end of the Old Year 2015, I decided to start my latest project.
Here is a shot of the engine on the stand and its replacement from 2791695.
The replacement engine has gotten a new chain, guides, S52 tensioner, B36 cam on the intake side, A100 gear on advance, euro headers. And 96k miles on the clock. The matching cluster is going into the car. The engine was originally sold by TCD to rollcenter, and then it landed in my hands after I sold my E39 M5 to rollcenter.
I am currently in the process of moving all the bits and pieces from the original motor over to the donor.
Stay tuned....
You've got 'til 10-14-16 to get 'er done. ;)
Hffvdbl
Post by Hffvdbl »
That's not much time!
Pavel
Post by Pavel »
Last day before going back to work was busy.
I got the originally motor stripped from all the auxilaries and put on the storage stand. The replacement went on the other stand and I started my progress of reassembly. I believe I got everything I need to finish the job.
Pavel
Post by Pavel »
One picture a-day-update. :laugh: :cool:
Pavel wrote:One picture a-day-update. :laugh: :cool:
basket of snakes.
beautiful!
Pavel
Post by Pavel »
I was able to get some progress done!
The engine is pretty much ready to go back in. I have to work on the transmission - seals, clean up.
Not going to install the AC compressor right now. Planning on refreshing the whole system next. I believe R12 is the choice of refrigerant.
Pavel
Post by Pavel »
Well in the preparation of another February 9th, I am still putting the car together. Yay 3-year anniversary with the M5!
:cool:
Last week was days off week from work, so I was able to catch up a bit.
I started with the steering box mount. It was cracked on the outside, or so I thought. Once I removed the bolt, it literally broke off on the other side, and was showing clear cracking through out.
So I went ahead and got creative. This was my first serious welding project, so bare with me. I build the mount from a flat piece, a little bit of hammering on the vice.
Also I pulled my injectors and sent them for rebuild
I am about to mate the engine and the transmission back together and hopefully drop all that back in the car by end of week.
Pavel
Post by Pavel »
Engine is back in the bay.
LeiseyJr
Post by LeiseyJr »
Nice! Glad I had an extra alignment tool for you
Pavel
Post by Pavel »
LeiseyJr wrote:Nice! Glad I had an extra alignment tool for you
Saved the day, right there!
Pavel
Post by Pavel »
The injector results are here.
Before:
After:
#4 was a little weak as you can see. MEPEH did a good job, and communication was very easy. The package should be at my doorsteps pretty soon. All set and done $55ish dollars with sending them to CA.
Last night, I was able to wrap up with the underside - guibo, drivershaft, shifter console, sway bar, transmission mounts.
I can see the neon light at the end of the tunnel.
Pavel
Post by Pavel »
Almost there. Last night, I was able to finally muscle in the cats back in. After some significant rework, I was amazed they fit from the first time.
All that left is harmonic balancer, new belts, radiator, intake, fluids.
:D
Excited for you!
dsmith
Post by dsmith »
I'll be down there over Easter next month. Hopefully I can see the "finished" project!
Pavel
Post by Pavel »
All the fluids are in. I should fire it up tonight. All that is left to install, fingers cross all is good, are the hood, front and rear strut towers and the skid plate (and the windshield washer fluid reservoir).
And then from tomorrow on DD duties. First things first are inspection and registration renewal. This will be the best birthday present :D
Pavel
Re: Living with a Legend ///M5: Year Three 2/29/16
Post by Pavel »
IT'S ALIVE!
First day of DD duties. The engine fired up right away, on Friday! This was a pretty exciting moment. I was slightly nervous after all the work done to it, if I have not messed something up. This was my first ever engine refresh. The chain rattle was nerve-racking but after a good 10 minutes idle-ing it started going away, as expected. I still have a slight rattling noise, which I believe might be a loose heatshield or probably exhaust leak somewhere in the area of my homemade welded flanges from the cats to the headers. The sound mostly goes away after the car gets moving. I can still hear it when at idle at a traffic light.
I still kick myself for not buying Supersprint track pipes in November, when TMS had them on sale in the mid $200..
The list of improvements goes like that:
- ~96k miles S38B35 + Matching Cluster
- S38B36 cam on the intake side
- A100 gear set on Advance, paired with Jim Conforti
- M88 headers
- Valve Adjustment
- New Chain
- New Guides
- New S52 tensioner
- New Throwout bearing
- Reconditioned Injectors
- All gaskets/seals/o-rings on the engine replaced - minus HG.
- Some auxiliary hoses
From the date of delivery of the engine it took me almost 10 months to finish this project. Took me a few months to accumulate all the parts, and reading all the little details of how am I going to achieve this end result. Thanks goes to all the people that have contributed to this community and the yahoo group with their S38 knowledge. To name a few of the guys that I talked to directly - Phil Conrad, Doug Park, Dean Caccavo. Of course Sherman with having me work on his S38B36 earlier in 2015, and all the other numerous tips and tricks he has taught me.
Next project - get my AC working. Going to keep it R12.
And get on with the 745i...
:D
:beer:
dsmith
Post by dsmith »
So cool. Congrats. You must have the most expensive/cheapest M5 by now. :rofl:
Pavel
Post by Pavel »
leadphut wrote::beer:
:rockon:
dsmith wrote:So cool. Congrats. You must have the most expensive/cheapest M5 by now. :rofl:
They definitely don't make them that cheap anymore :D
Swing low, sweet chariot... :haul: :haul:
Pavel
Post by Pavel »
Trouble free few days of driving. I went to an exhaust shop based on some local BMW-buff's recommendations.
We ended up tightening up the flanges between the CATS and the headers a little more. There was definetely an exhaust leak there, plus I had some small pin holes in my welds that got fixed. The rattle noise turned out to be a piece that I added to change the curve of the CAT pipes. So I think I decided to go ahead and get a track pipe made for now, and later in the year get the VSR Dual Cats from Mario.
As nice as it is to have a lift, I also found out that my transmission is still slightly dripping. Not sure if it's from the selector seal that I just replaced or is it rear seal around the output shaft.
Also I noticed at really low speeds when going about 5 mph when turning hard left or right there will be a grinding noise from the rear.
Nice work! Check the level of the oil in the diff.
I have been informed that my last post could lead to confusion. I would check the oil level in the REAR diff. Good luck.
LeiseyJr
Post by LeiseyJr »
Glad to see Manny hooked you up on that exhaust work. S38 looks nice!
When my LSD failed, I :bawl:
When cornering, it sounded like the exhaust was dragging.
Pavel
Post by Pavel »
wkohler wrote:I have been informed that my last post could lead to confusion. I would check the oil level in the REAR diff. Good luck.
Thanks Chris. I will look at this over the weekend. I had that flushed and refilled a few years ago - probably 2 now.
So far in my troubleshooting I have noticed if I am going slow in a circle almost full lock, the sounds will be there (no matter direction) however if I press the clutch - nothing.
Bare with me here but if it's the diff it should still make soundtracks regardless if the transmission is separated from the engine, no?
And I think I know why transmission is leaking - almost positive it's the selector seal and mainly because of the delrin bushing in the back of the shift arm. It's probably time to revert back to a stock setup with a rubber bushing.
Post by rmiddendorf »
Could also be trailing arm bushings.
Pavel
Post by Pavel »
LeiseyJr wrote:Glad to see Manny hooked you up on that exhaust work. S38 looks nice!
I need to give you back your clutch tool.
rmiddendorf wrote:Could also be trailing arm bushings.
Those are still the original ones, I have not touched them. I can see this possible, too if pressing the clutch is not actually doing anything and I am just losing speed hence not noticing the noise.
I did notice my passenger rear side tire has lost a bit more thread than the left side. And I know it's usually a problematic area for the E28s without mods to the rear subframe.
LeiseyJr
Post by LeiseyJr »
Does your diff fluid have the limited slip additive in it?
