A quite ingenious way to bleed the clutch
http://www.youtube.com/watch?v=wdf--suw ... e=youtu.be
Of course, the question I have is if this would work with the shared reservoir our cars have.
I see no reason why it wouldn't work as long as you had a turkey baster to make sure you didn't overfill the reservoir. That said, I think there is nothing better than the Motive Power Bleeder. You'll never have the problem he describes. Best $50 you can spend.
kinda seems to do the same thing as disconnecting the slave and depressing the piston, i did this and it worked there might have still been some air in it but if felt great. i pumped forever and blead alot of fluid through and couldn't get any pedal, but the depress the slave method worked instantly
The Porsche master tech I know told me about this and I did try it...and it does work. But don't buy the cheapest oil can as they make a mess with brake fluid. It's the easiest method I know, other than removing the slave from the bell housing and depressing the slave rod while opening the valve covered in other write ups here.
I, too, vote for the Motive bleeder.
Anyhow, this is nothing new. This has been on the market for dozens of years: http://braketools.com/max-pro-brake-bleeder.html
Re: A quite ingenious way to bleed the clutch
Works great! I have been doing it this way for years. The last time I did it, I used a very large syringe I bought from a tack store instead of the oil can.wkohler wrote:http://www.youtube.com/watch?v=wdf--suw ... e=youtu.be
