Woohoo! Working headlight Wi/Wa system.
Yes, it fits Euro lights only.
There's a hole in the headlight bucket thru which the motor shaft goes thru, and out thru the grill. The grill has a cut out there especially for it too. Also, you need the flat lenses of the H1/H4 headlights so the wiper blades sit well.
One could probably retrofit them to US buckets with H1/H4 conversion...but it'd be a semi-pain.
The wiring is actually very easy and "retro-fitable". There is a "gotcha" in the wiper stalk wiring, but that's it.
-Chris
-Chris
Well...I've got it completely working.
The car originally came with it, but when it got federalized they screwed up a bit of the wiring. So I had to fix that, and then find the motors, wipers, etc. Then troubleshoot why it wasn't working.
Hey, do you think you can send me your wiring diagram with the multiple relays? I'm going to try to write a DIY procedure for this and want to include as many options as possible.
-Chris
grafff1 at gmail dot com
-Chris
Oh I'll credit you. Don't worry. :-)
I want to offer as many options to people as possible. I already have the OE wiring diagram, and will go through how to wire that up, and the wiper stalk wiring as well. But, I'd also like to offer your option which may be cheaper. 3 relays of $10 ea is 1/3 of what that stupid control unit (which does the same thing, basically) cost me - although mine is wired as it was originally from the factory.
If you offer people options, then they can choose whichever is best for them. And yours is a viable alternative.
-Chris
-Chris
