p/w power steering pump woes
Guest
Post by Guest »
I began with a leaking shaft seal and ordered the p/s rebuilt kit (seals) from steve h. I replaced the shaft seal, and the two odd "h-shaped" seals inside the pump. this went well, but I believe I did something foolish (that's fairly normal for me) while taking it apart to clean it. I removed the small clip on the backside that holds the spring-loaded dildo thing in place. I put it back together the way it came out, but now my pump is noisy and it gets really hot. I only ran it for a maximum of 15 mins or so, but I think I may have screwed it up.
does anyone know anything about the spring-loaded dildo, it's function and what I may have fucked up during the rebuild?
TIA,
Jacob
Guest
Post by Guest »
additional question; do I need to prime the pump somehow?
Blue Shadow
Post by Blue Shadow »
The pump gets hot due to friction which the fluid should reduce so there are some clearances that are incorrect in the rebuild. The pump has a flooded suction so a primp should not be necessary.
