Tried fitting my new design fan shroud to my new radiator .
Dave_in_VA
Post by Dave_in_VA »
I discovered that the upper flange is on backwards. The mounting holes for the shroud are on the wrong side.
There are 4 holes on the top flange on the engine side and none on the other side. Mine has the 4 holes on the forward side and none on the engine side.
I guess I will be drilling a couple of holes.
shifty
Post by shifty »
[QUOTE="Dave_in_VA"]I discovered that the upper flange is on backwards. The mounting holes for the shroud are on the wrong side.
I guess I will be drilling a couple of holes.[/QUOTE]
Is this shroud something you designed yourself, or is it from a newer BMW? I must've missed your original post on this.
Dave_in_VA
It is a improved designed from Aug 87.
The old part number is 17 11 1 177 834 the new design is number 17 11 1 712 240.
The old fan shroud could be deformed and displaced from it frame. Cause: High ambient temperatures and high speeds.
