Posted: Feb 25, 2005 5:44 AM
by XtannerXm535iX
does anyone know where the inside temp sensor is?
...is it important/usefull?
Posted: Feb 25, 2005 9:13 AM
by Steve Haygood
far left lower kick panel above the driver's left foot. If it isn't working , you will get either full heat or no heat, you won't be able to moderate the heat.
Posted: Feb 25, 2005 11:11 AM
by XtannerXm535iX
really? it seems everything is the source of no heat
thermostat, heater valve, bad connections, etc...
...is there anyway to test the interior thermo, before i decide to replaced it?
Posted: Feb 25, 2005 2:57 PM
by pdx 528e
The Bentley lists Interior temperature sensor test values. chap 21 pg 7.
green/yellow and brown wires: (1 and 3)
@ 77F = 33+/- 8.5 ohms
blue and brown wires: (2 and 3)
@104F = 4700-5400 ohms
@86F = 7500-8400 ohms
@77F = 9500-10500 ohms
@68F = 12000-13300 ohms
@59F = 15100-17200 ohms
@50F = 19400-22100 ohms
@32F = 32400-37700 ohms
Hope that helps, so you can at least rule out the sensor.
Chris
[Edit by pdx 528e on [TIME]1109361919[/TIME]]
Posted: Feb 25, 2005 9:23 PM
by XtannerXm535iX
it does... thanks for your help
