I picked up a head from an 81 euro 733i at the Pull A Part. It looks to be almost new. No varnish and very bright under the valve cover. But it looks to be a reproduction, not a BMW part. The only markings I have found on it so far, are the letters AMC cast into the intake manifold side. The intake runners are not real smooth. They have some pits from casting in them. The engine did have the high compression pistons in it. will this head work and is it worth using on a 1988 535i? I am planning on rebuilding a head, with some agressive porting and polishing, a 280 duration cam and a B35 intake manifold. I also have a BMW head off of a US 85 735i, but it has an extremely worn cam lobe. Would I be better off using the US head? I also got the 001 ECU from the car. I don't think it is Motronic. Is it worth anything? Any help would be appreciated.
Thanks,
Mike
1988 535i
