Because I'm now neck deep in the swap I'm looking for advice from anyone with knowledge regarding the electrical system and especially the fuse boxes for the E28 and late (1989) E24 635's. My intent with the swap is to get away from the old torpeado-style fuses and upgrade to the new blade fuses. Also, the circuit board in the E24 fuse box does aways with a lot of wiring. Therein lies part of the problem: which wiring is redundant? The next problem I have is in identifying which wires from the E28 chassis belong in each fuse location in the E24 fuse box.
Below are diagrams from Mike in Louisville from whom I purchased the E24 fuse box in February. He supplied a few diagrams of the E24 fuse box seen below. The relays were marked and transfer of the E28 wiring to the relays appears fairly straightforward.
Here is the text accompanying the above diagram:
1. High Beam, Right
2. High Beam, Left
3. SUPPLEMENTARY FAN
4. FUSE 5
5. FUSE 13
6. FUSE 6
7. High Beam, From Fuses 1 and 2
8. FUSE 4
9. Fog Lights, From Fuses 29 and 30
10. Low Beam, Left
11. Fog Light, Right
12. Low Beam, Right
13. Fog Light, Left
Questions:
- Do the numbers on the left (1 - 13) correspond to the fuse position on the E24 fuse box?
- Does the description on the right relate to the E28 wiring to be attached to the fuse position on the left?
- Is it the other way around?
- E28 fuse position on the left and the description on the right is the fuse position for where the wiring should be attached in the E24 fuse box?
- Are the wiring colors the same between E24 and E28? Is 'VI/BK' in an E24 the same circuit as 'VI/BK' in an E28?
Here's a diagram of the E24 635 fuse box but aside from the coloring of the wires there is no description of which circuits are attached to each fuse position. Could definitely use some help here also:
E28 fuse box cover: 17 fuse positions numbered vertically from left (1 - 6), center (7 - 14) and right (15 - 17)
E28 fuse box underside (several of the connectors had melted)
E24 fuse box top. Relay positions marked. E28 wire terminations marked. Where to place the terminations in the fuse box fuse positions in question.
E24 fuse box bottom.
