-1985 BMW 745i- Turbo Executive- CA title, Lots of New Parts
CMG
Post by CMG »
I have had this car for about 3 years or more. I had a for sale posted two years ago here: http://www.mye28.com/viewtopic.php?t=82887
This is my second 745i which is the only reason I am selling this car. It is the euro executive with all the cool power options and buffalo interior. I purchased it from the daughter of the original owner after he passed away, it had been in the States since 1986 and California since around 1988. It was all stock and came with some receipts that showed it had been well taken care of, it has about 178K miles. I've put alot of work into the car since I've had it I take care of and improve all my cars. Car has clear and current California title registered until July 2013 and smog was done less than a month ago so none is needed for transfer. The car was just painted so I am in the process of finishing putting stuff back on then gonna detail it then I will have better pictures and I'll take some vids too. All work and parts noted are new and installed within last 2000 miles. There's also some small stuff needing fixing that I noted below that I will try to take care of before sale. As always I'm sure I'm forgetting some stuff so if you're serious you can come check it out and look thru the paperwork. Car will also come with spare parts and extras. Price is $4000 with the 15" MSW/OZ wheels. I also have other parts I can work a deal with buyer such as Bavauto front strut bar, Dinan sway bars, etc. I will also possibly consider a trade for a pre- '74 import car like a Datsun 510 or BMW 2002.
---Exterior
-Fresh paint, OE color, all mouldings and trim removed for paint. All new OE clips and grommets used for reinstall. New roundels. Door handle gaskets replaced. Window lower strips replaced.
-No federalized sidemarkers
-Euro headlights with Silverstar Ultra bulbs. LED driving lights in corner lights.
-Car had dent in right rear door which was pulled when painted.
-Car has euro bronze windows and sunroof. Sunroof does not work at the moment. It worked previously and motor still works but not moving. Also have new sunroof weatherstrip seals included but not installed, and a spare sunroof motor.
-Central locking works but driver side locks but not unlocks.
-All power windows work but just started having issue they don't get power when ignition is turned, looking into it now.
---Interior
-Water Buffalo Interior gray/black. Fading from sun, leather good with some wear on driver seat and small hole in butt area, cracked dash but covered with dash mat, rear headrests have loose stitching, new floor mats. Interior is not really worn, just old.
-Wood is still good some very slight cracking but not worn.
-Old School Nardi steering wheel and hub w/ BMW horn button
-New Ignition switch
-Gauge cluster gears replaced, all gauge functions and lights work, same with OBC.
-Rear sunshade does not work but I have replacement one not installed
-All power options work including reclining rear seats work fine except passenger front seat does not move front to back but motor works (I think it's just jammed), still has becker radio in rear.
-Good Sony/JVC stereo with new speakers, power antenna works
-HVAC has issues. When I first got it it worked fine, now it is intermittent. AC compressor kicked on previously but not cold. At least needs microswitch replaced at most also needs pods replaced.
-Original spare metric in trunk, complete tool kit
---Engine
-All belts, plugs, fluids, filters, battery, etc. replaced, synthetic in Engine.
-Alternator bushings replaced
-Coolant hoses, water pump, thermostat etc. replaced.
-Most vacuum lines replaced
-Most power steering lines replaced
-Fuel system and lines cleaned out, Walbro 255 external pump, new in tank pump, new fuel level sensor, fuel filter
-Tranny 4hp22zf serviced non synthetic fluid. Tranny sometimes slips going into third if car is cold, once warm no issues tranny shifts smooth, it's always done that, never any check lights. Differential fluid changed.
-Turbo replaced by PO
-New custom full 3" Magnaflow exhaust and catalytic converter from downpipe back, could use better tips but works.
---Suspension
-New pitman arms, idler arm, tie rods and center, etc.
-New Bavarian Autosport springs and Bilsteins, all strut mounts good
-Brakes and rotors are good at least 50% or more life left
-I have two sets of wheels: 17x8.5 AC Schnitzer or 15x7" OZ/MSW, both have good tires.
CMG
Post by CMG »
Here's some pics and vids. You can hear wind noise in the driving vid cuz I haven't finished putting the weatherstrips and mirror back on.
http://youtu.be/mCr_nVXlNXI
http://youtu.be/HUnhAW3jxws
http://youtu.be/BrVaBbj_TXo
D Unit
Post by D Unit »
Great looking car... GLWS!
CMG
Post by CMG »
FYI, Seems there's a scammer cruising the forums, got this email:
Hello,
I am using this medium to notify you of my interest in Purchasing your item Which i will like to ask few questions Some
still available for sale?
What is the Asking price?
What is the condition?
Has this Before Involved In Any damage?
do i need to repair?
I Would like to pay using PayPal, After payments has-been made ​​i will arrange for pick up of the item as soon as possible, will you let my pick-up agent to come to you house for the pick up? Because i do not want you to worry yourself about the shipment.
Thanks
CMG
Post by CMG »
CMG
Post by CMG »
Bump, $5400 OBO for just the car with your choice of wheels and no extras.
CMG
Post by CMG »
Washed the car and took a few more pics. Looks great with the ACS wheels but I put too much rubber on them so they rub a bit sometimes in front wheel wells. Nothing some lower profile tires couldn't solve. I still am looking for that front passenger side window strip which is why that door doesn't have mirror or trim on it. Also as you notice I don't have much interior pics, that's because I still am doing some work in there and haven't cleaned it up nice. Fixed the OBC light bulb and trying to fix driver side door lock now. I'll be trying to fix as many of the little things as possible before selling the car.
CMG
$5000 OBO with 15" OZ/MSW Wheels
Post by CMG »
CMG
Post by CMG »
gooten1
Post by gooten1 »
Wow, gorgeous! Good luck with sale, this looks like a great car!
ssf1342
Post by ssf1342 »
Sent you a pm.
CMG
Post by CMG »
Sent u pm back, lemme know if you need any other info.
CMG
Post by CMG »
Good news, I was able to replace that last door trim so now car is 100% back together and ready to go. There's a few weeks left on the smog certificate then after that I'm just gonna give ebay a try.
cinnamonandgravy
Post by cinnamonandgravy »
sent an email a day or two ago.
im local - would love to see it in person this weekend.
any rust? CA car its entire life?
CMG
Post by CMG »
Haven't gotten a message, send me PM, car can be seen. No rust on car at all, was CA car since about 1987 or so, and it was out in the desert area inland.
cinnamonandgravy
PM sent
CMG
Post by CMG »
Got your PM and sent you a text last night.
CMG
Post by CMG »
Now on ebay
CMG
Post by CMG »
Last chance two days left and has one bid low price
CMG
Post by CMG »
That so called bidder was a non paying bidder as tends to happen on ebay. Still for sale and keeping the price at $4000.
gmb49all
Post by gmb49all »
Is the lower valance supposed to be a different color?
WilNJ
Post by WilNJ »
gmb49all wrote:Is the lower valance supposed to be a different color?
It's faded some, they all have but no they were not painted body color from the factory.
CMG
Post by CMG »
Bunp
CMG
Post by CMG »
I like to eat small children
CMG
Post by CMG »
SOLD
Corner Carver
Post by Corner Carver »
CMG wrote:SOLD
:banana: Glad to hear it! Anyone we know?
CMG
Post by CMG »
You might know him or know of him, he's real big in the bimmer scene here in socal so even if the car is not on the forums it will be around.
hubble1953
Sold?????????????????????????
Post by hubble1953 »
Does anyone know if this car really sold? A friend of mine is trying to buy it and it appears as if the seller is using the same thread that is posted here on mye28:(. Now if the owner, CMG, still has the car, everything is ok, if not something does not seem right to me :?
jm
CMG
Post by CMG »
Replied to your pm. I did sell the car and new owner is keeping it. If there was another for sale thread with pics of the car then it was a scam.
hubble1953
ok
replied back; My friend bought another car. He thought it was a scam also.
thanks,
john
