CA: e23 1985 745i turbo 5-speed manual
yert315
Post by yert315 »
SOLD!
Still need to finish a couple things on this, but I wanted to get it out there.
It's a 1985 BMW 745i turbo with a 5-speed conversion. I have owned it for about a year now and have put a lot of time, money and effort in this car. Selling in order to get a smaller car and a motorcycle.
Specifics are as follows:
M106 engine - stock everything
running 6psi 252bhp (stock). You can upgrade the Chip and install a boost controller which will net ~14psi reliably. All vacuum hoses and lines have been replaced.
Cat has been removed and replaced with dual 2" pipes (how they came from Germany). You will need some "help" from your smog guy because of this. Sebring muffler out back for a little noise.
Factory trunk spoiler installed.
Manual Conversion:
G265 2-piece transmission, very strong.
Resurfaced flywheel.
SPEC stage 2 clutch. Stiff pedal, but holds nicely. Good for daily driving.
Bosch Bypass valve routed to intake boot.
M3 shifter conversion (still need to install).
short shift lever.
wood shift knob from an e39
2.93LSD
Interior:
Executive package
Water buffalo leather. Front seats have split. All electric functions work.
Cruise control does not work.
rear armrest with radio controls (not hooked up) and passenger seat controls (which work).
Clarion head unit.
Dash has cracks, like many BMWs of this vintage.
Rear sun shade
Factory first aid kit in the trunk.
TRX spare wheel/tire
Custom coilover setup utilizing Hypercoil springs. E28 setup in the rear with bilstein sports (should be revalved or use a softer spring rate as it bounces). Front strut housings are sectioned 2" with shortened struts (this is one of the things not yet done) and 500lb 5" springs.
Magnetic boost control valve is upgraded to a volvo unit for Better turbo response. I paired this with 3 ports on the wastegate plugged for quicker spool up.
AC Schnitzer type 2 wheels. 17x8.5 et13 with BFG 235/45 tires. Some curb rash.
The car all around:
Drives great with no shaking or bad vibrations. Engine revs up smooth and does not hiccup under boost. Vacuum at idle is at 18-20hg (solid, no vac leaks). HVAC system was disconnected and plugged. It only blows on defrost. Microswitch needs to be fixed ($4 Radioshack part). Heater does work. A/C belt was removed. Never looked into the system, but from what I'm told it's just a few vacuum pods and it should be functional again. Started showing signs of worn turbo seals -- good escuse to upgrade the turbo wheel. Sunroof guide broken. Windshield is cracked. It was repainted by PO somewhat poorly. May be able to come back with some color correction (wetland, buff, etc). Originally Diamondshwarz. This car is not a show car. Good project while you drive it car.
Autocheck is a bit spotty. Shows over 300k miles since 2001. Not sure if this is accurate based on the amount this car has driven since then (~15k in 12 years). Only issues from autocheck are failed emissions tests in 2005 and 2007. Odometer is indicated 336k miles. I performed a valve adjustment this past week and the engine looks to be absolutely spotless. Looks more like a 100k engine than a 300k.
No rust on this car anywhere. Dry as a bone. I have the factory manual and some other paperwork that will come with the car. Spare key included. Turn-key and go. I have driven this car to San Diego and back multiple times without issue. Wouldn't hesitate to get in and drive anywhere!
$3500
If you have any questions shoot me a PM or Call/text 818.434.2478.
Thanks for looking,
Trey
pleasefixitup
Post by pleasefixitup »
I want it. If it doesn't sell in the next month or so--expect me to have it shipped to me in Chicago.
But nevertheless--GLWS!
thespeedfactory
Post by thespeedfactory »
How far off Cali emissions is it. I would need it to pass Utah.
Pavel
Post by Pavel »
:drool not another cool e23! Thats the only chassis i would consider putting my 540 for sale again.
GLWS
Cactus
Post by Cactus »
I hope I get to see this at some kind of fest somewhere. Man-conversion and coilovers? Lots of goodies for the money.
Rich in Tupelo
Post by Rich in Tupelo »
Very nice looking. Wish it was closer
thespeedfactory wrote:How far off Cali emissions is it. I would need it to pass Utah.
The OP can correct me if I'm wrong, but if the photos are current, then his registration isn't: that looks like a August 2012 sticker.
But if it's anywhere near close to passing CA, then you shouldn't have any issues passing UT.
There is the no cat thing, don't know if that's an issue in UT?
These sure are starting to grow on me.
Glws!
Greg E34
Post by Greg E34 »
C'mon, someone jump on this thing. I love my E23!
Is it just me, or is this an insanely good deal?
Greg E34
Post by Greg E34 »
Doo ett Dafy!
yert315
Post by yert315 »
Thanks for the compliments fellas. I still need to take care of the front struts and find a shift carrier for the late style conversion. Other than that it is as described.
Updated with an interior picture.
Post by unt0uchable »
I sure hope one of these dope ass e23's are around in a few months. These cars grow on me more every day.
Nice car!
thespeedfactory
PM'd
Very motivated buyer as I am without my e28 until May.
yert315
Post by yert315 »
never received a PM.
By the way the pictures are from various times of my ownership. The tags are good through Aug 2013.
Rich in Tupelo
yert315 wrote:never received a PM.
Current pics of interior and exterior would be helpful to interested parties so as not to expect it to look like prior pictures.
TonkaTruck
Post by TonkaTruck »
Great price, if I had room I'd buy it.
thespeedfactory
Why the hell are my PM's staying in the outbox?
thespeedfactory wrote:Why the hell are my PM's staying in the outbox?
http://www.mye28.com/viewtopic.php?t=45630
yert315
Post by yert315 »
Got both PM's and responded.
The car hasn't changed from the pictures I have posted.
To reiterate, I still need to address the shifter and front struts. I plan to get these done this week.
ssf1342
Post by ssf1342 »
Any local folks willing to take a look for me? I need a replacement for the Gross Polluter.
Corner Carver
Post by Corner Carver »
This car will easily pass CA SMOG with a fresh catalytic converter. CA buyers should not be afraid of this car. It has a BAR sticker. Make the factory duals into a "track pipe"and bolt in the new cat. Seems like a deal at $3500. The 5 pd swap is a bonus! :banana: If I didn't already have enough headaches, this would already be in my driveway. :cool:
Also, to whoever buys this car, I have matching front seats in good shape for you.
blindlemon77
Post by blindlemon77 »
That thing looks awesome, if i did not just start a huge project i would probably snap it up! glws
BMWgiant
Post by BMWgiant »
Would it be worth passing up a 3 month backpacking trip for my dream car? Sadly, no. Why can't cars like this be up for sale when I'm actually looking for a car, dammit! Gorgeous car. Definitely my dream car, down to the color, engine and transmission. Good luck!
dolomiti
Post by dolomiti »
Since Yert narked the original post as "SOLD," i'll go ahead and chime in, "BOUGHT!"
I can't wait to see it, on Monday or Tuesday.
Greg E34
Post by Greg E34 »
dolomiti wrote:Since Yert narked the original post as "SOLD," i'll go ahead and chime in, "BOUGHT!"
Welcome to the club.
As an aside, another mye28 745i changed hands this weekend as well.
Not mine though.
Hit Man X
Post by Hit Man X »
And to a fellow Texan, if you are off 10 and 6 maybe I will see the car on the road.
dolomiti
Post by dolomiti »
Wow, you are an e23 junky! I live near Sherman (1st Fiver) up on the NWside, off of 249 between Willowbrook and Tomball.
blindlemon77
Congrats on buying that e23, the thing is gorgeous!
dolomiti
Post by dolomiti »
I was going to fly out to LA and drive it back but Trey wanted to take one last road trip and who am I to deny that...
Should get it tomorrow. Of course, Trey had to send me this teaser picture from out in West (110mph) Texas.
Lord, that car looks delicious. At least i'll get to knock out 500 miles tomorrow.
