Some enthusiasts calling me on this car advised me to also post it on mye28.com and bigcoupe.com. Here is my listing from bimmerforums.com:
So, unfortunately I need to sell the e32. Lost my job, and its gotta go. Looking to get $3500 out of it. 170k miles, gray on black.
The Good:
-Runs strong, shifts smoothly (just had shift bushings/linkage done)
-Paint is in great condition, though has been repainted by P.O. (8/10)
-Interior is in amazing condition (8/10)
-Front suspension is almost brand new with some spare parts in trunk (all done and from P.O.)
-Haven't had any issues with any leaks since I had my mechanic do some work on replacing gaskets on both engine and tranny. The car sits for weeks at a time at my dads right now, and no puddles under it at all that I've noticed.
-Passes CA smog like a boss
-All the windows work!
-New Fuel pump, and fuel pressure regulator
-Have new fuel filter in trunk, along with new oil filter that I haven't put in yet (Mahn or Mayle, can't remember which)
-New O2 Sensor
-Tires are fair
-Breaks in great shape
-No slipping on clutch
The Bad:
-Drivers side air not working. Broken servo brackets according to my mechanic and no power going to heater valves
-Reverse lights stopped working.
-Turn signals are intermittent. I've tried switching the relays, however it seems to persist meaning it is likely either a cluster issue, or the relay in the turn signal stalk. Not sure
-Seats are not twisted right now, but do twist if adjusted too much.
-Stereo was stolen out of car since before I got it
-Sunroof needs adjusting. I have a spare motor sitting the in trunk in case it needs it.
-Airbag light is on. P.O. had some hack job done on the airbag, disconnected it, and put tape over the Airbag light. I've put a replacement airbag and steering wheel on, and connected everything, but don't have the tool to reset the light, so the tape remains on it.
That is literally everything I can think of. Overall, it is a solid driver, and I think would be a great car to anyone looking for one who is willing to sort those things out. I have driven it on/off for a while now, and have no hesitation driving it for long periods of time myself.
